Pages: 1 2 3 [4] 5 6 ... 8   Go Down
Author Topic: new drag car  (Read 151894 times)
Re: new drag car
« Reply #90 on: September 25, 2012, 04:55:24 PM »
but why?  :'(
hatchbone
Re: new drag car
« Reply #91 on: September 25, 2012, 06:09:09 PM »
With the irs suspension every time I shift the car gets mad squarely on the top end so installing a t400 with trans brake so I dont have to shift so much at the track, should help with the launch and keep the car more consistent at the track I already have the plate to bolt it to the engine now just need a custom flex plate made and figure out what stall to run on the converter, im new when it comes to stalls so any input would be greatly appreciated
Re: new drag car
« Reply #92 on: September 25, 2012, 06:52:35 PM »
Any vids of it on the track?
hatchbone
Re: new drag car
« Reply #93 on: September 25, 2012, 07:01:30 PM »
Found one this was a 10.2 pass with a fucked 60ft and shifting 3rd early cause I noob shifted it the day before, next day I just worked on my short track dailed the 1.44 60ft in this video down to consistent 1.36 60's, I  couldn't  get 9's though cause 3rd was toast at this point so was pointless to turn the power up .so after I wait two months to get the v160 rebuilt I decide to go t400 lol so this is the only vid I have car only made about 20 passes this year next year big dog style for sure
hatchbone s2k 10.2
Re: new drag car
« Reply #94 on: September 25, 2012, 07:22:08 PM »
Why not a glide?
What rpm do you have your launch control set at? It will be close to what you need for stall.
hatchbone
Re: new drag car
« Reply #95 on: September 25, 2012, 07:27:12 PM »
7500 I dont think it needs to be that high any more I would still like to take it out on the street I was thinking 6.5k launch with 4k stall maybe? Some were around there any ways if that would work like I said im noob auto/stall guy
Re: new drag car
« Reply #96 on: September 25, 2012, 07:57:17 PM »
thought you wanted to keep it manual cuz its still a street car?
Re: new drag car
« Reply #97 on: September 25, 2012, 07:59:17 PM »
If you were to three pedal it, when could you build boost buy? When you were dynoing what rpm was peak torque at?
hatchbone
Re: new drag car
« Reply #98 on: September 25, 2012, 08:40:40 PM »
I looked at my dyno sheet on previous page but its in mph not rpm id say 5500-6000 best guess
hatchbone
Re: new drag car
« Reply #99 on: September 25, 2012, 08:42:38 PM »
still has ac and a radio so its a street car to me this car is about 80/20 track street to me
Re: new drag car
« Reply #100 on: September 25, 2012, 09:07:44 PM »
I hope FBM fully blew you. Prob should have put in an auto but the 6spd will be fun on the street.
called it
hatchbone
Re: new drag car
« Reply #101 on: September 25, 2012, 09:10:47 PM »
Touche` sir
Re: new drag car
« Reply #102 on: September 26, 2012, 10:34:27 AM »
I would start at about 5500rpm for a final stall speed then. Now some places when you ask for a 5500rpm stall will have it start to stall at 5500rpm and you will end up at 6500rpm+ on the trans brake, and some places will start to stall it at about 4000rpm so you end up at 5500rpm on the trans brake. I would probably start with the latter, and work from there.
I recommend pro torque converters http://www.protorque.com/ they work with a lot of turbocharged race cars, and have a good understanding of what a turbo car needs. They will probably even have a better recommendation for initial stall speed.
hatchbone
Re: new drag car
« Reply #103 on: September 26, 2012, 10:48:33 AM »
Now with a 5k+ stall could you still drive it on the streets if need be? I like to beat on bikes and spendy v8 builds via highway pulls on the occasional weekend
Re: new drag car
« Reply #104 on: September 26, 2012, 12:58:14 PM »
I'm sure you could, not sure how drive able it would be, but if you get too much lower you might have trouble building boost on the line.
hatchbone
Re: new drag car
« Reply #105 on: September 26, 2012, 04:35:26 PM »
This is the trans Im having built right now, has a little slimer bell housing so firewall modifications should be slim to none I hope either way shits going in ,
http://www.atfspeed.com/store/index.php?main_page=product_info&cPath=193_194_49&products_id=259
Re: new drag car
« Reply #106 on: September 28, 2012, 03:26:33 AM »
that seems like a really reasonable price
hatchbone
Re: new drag car
« Reply #107 on: September 28, 2012, 11:06:12 AM »
I thought so, comes with a milled down bellhousing also to fit in the supra tunnel so im hoping tunnel/fire wall modifications are slim to none
Re: new drag car
« Reply #108 on: September 28, 2012, 11:35:26 AM »
Damn $2500... thats more then I have into my crx.
Re: new drag car
« Reply #109 on: September 28, 2012, 02:49:17 PM »
Or about a 1/4 of what it costs to build a race transmission for a diesel, or a 10.5 car, or ect...
Re: new drag car
« Reply #110 on: September 29, 2012, 12:59:12 AM »
Shit a 10g diesel race trans might be lucky to even get a convertor and valve body with it lol.
Re: new drag car
« Reply #111 on: September 29, 2012, 02:56:21 AM »
its about 5,500 for a totally built 48re with billet everything and triple disk converter
Re: new drag car
« Reply #112 on: September 29, 2012, 08:26:19 AM »
Sounds like a solid dd transmission, a 48re that will hold up to 9.51@149mph at 6800lbs, and then go sled pulling the next day is a little more money then that.
hatchbone
Re: new drag car
« Reply #113 on: November 15, 2012, 09:00:12 PM »
been a while since i updated this thing just been waiting for parts but here is what i got going so far
adapter plate showed for the t4oo
Missing link
stealthmode thought he would try rwd out
-8 an trans cooler with thermostat switch for the fan
also swooped a nice set of cf fenders just cause they were cheap sad thing is i think there heavier then my stock ones, oh well ill just have to drop a deuce before i race to make up the diff
had a exhaust made for the street runs cause open dp is dope but loud as shit at 10k
Only exhaust pic I got right now single 4'to duel 3' all stainless with vbands
picked up a 1000hp intercooler also, shits crazy on the car takes the whole front end up you could rock it without the bumper and shit looks way good
last thing i need to get this bitch in and done is flexplate and for atfspeed to finish my torque converter. i ended up going with a 5200 stall 10' and got a guy to make the flex out of billet as soon as the converter shows so i can take a few measurements for
it should look like this when done
thats about all for now im waiting for some more shit to show up so ill keep this up to date as shit shows, i only have my build here and mine and stealthmodes forum
Re: new drag car
« Reply #114 on: November 15, 2012, 11:40:54 PM »
that intercooler looks badass!
hatchbone
Re: new drag car
« Reply #115 on: November 16, 2012, 07:35:57 PM »
Should work
hatchbone
Re: new drag car
« Reply #116 on: November 16, 2012, 08:58:33 PM »
should we move this to open forum?
Re: new drag car
« Reply #117 on: November 16, 2012, 11:03:05 PM »
your call. ill move it if you want.
hatchbone
Re: new drag car
« Reply #118 on: November 16, 2012, 11:12:03 PM »
We can move it maybe it will give the rest of the site some thing to look at
Re: new drag car
« Reply #119 on: November 17, 2012, 03:40:41 PM »
done. now edit the first post subject line?  :-*
Pages: 1 2 3 [4] 5 6 ... 8   Go Up
