Pages: 1 ... 3 4 [5] 6 7 8   Go Down
Author Topic: new drag car  (Read 151950 times)
tekno
Re: new drag car
« Reply #120 on: November 18, 2012, 10:23:18 PM »
sexy im currently looking for one first mod will be turbo and rear end swap
Re: new drag car
« Reply #121 on: November 19, 2012, 11:49:44 AM »
DO WORK!
hatchbone
Re: new drag car
« Reply #122 on: November 19, 2012, 12:01:36 PM »
Doing it ;DDD
walter
Re: new drag car
« Reply #123 on: December 26, 2012, 07:18:30 PM »
nice!! it's still runing on block stock?  :o
hatchbone
Re: new drag car
« Reply #124 on: December 27, 2012, 08:05:44 PM »
Ran up untill I parked it for the rebuild, might sleeve it still kinda up in the air (funds) but ill see.here is a intake manifold fbm designed for the s2000 chassis that we are testing on my car here is tbe plastic fitment piece real one should be here shortly
carkrazed
Re: new drag car
« Reply #125 on: December 27, 2012, 11:10:57 PM »
Is that going to be cast or billet? Looks good.
hatchbone
Re: new drag car
« Reply #126 on: December 27, 2012, 11:13:40 PM »
Casted, should be a cheap option with good fi performance for the s2000 cause as of now there os not much out there for manifolds
walter
Re: new drag car
« Reply #127 on: December 29, 2012, 10:58:54 AM »
wow! how it's made in plastic one?  :o
carkrazed
Re: new drag car
« Reply #128 on: December 30, 2012, 10:09:19 PM »
Cmon Walter...................3D printer, lol
hatchbone
Re: new drag car
« Reply #129 on: April 02, 2013, 08:45:11 PM »
transmission showed up today at fbm,so stealthmode thought he would try rwd out
-8 an trans cooler with thermostat switch for the fan
hatchbone
Re: new drag car
« Reply #130 on: April 02, 2013, 08:46:29 PM »
Torque conver finally showed up (6200rpm stall) and also my freshly sleeved f22 from benson
hatchbone
Re: new drag car
« Reply #131 on: April 02, 2013, 08:47:30 PM »
Finally got every thing bolted together to get the backspacing measurements for my billet flex plate today, should look like this when done.kinda excited
hatchbone
Re: new drag car
« Reply #132 on: April 02, 2013, 08:48:20 PM »
ot all my head parts for my new head today so send that and the rotating assembly out and should be good to go in a week or so
hatchbone
Re: new drag car
« Reply #133 on: April 02, 2013, 08:49:14 PM »
Found a little time to work on the car today, got the bay almost were I need it to be pass side tuck is done tomorrow I just have to do the driver side wires and she should be good to start running all the new brake lines while im waiting for my new head to get built and assembley balanced, got some diff injectors today also.the 2150's were almost maxed last year at 800 so yhese 3000cc should be judt what I need for this year
Heres a before shot
And this is how far I got today
Really the only place these all fit
Clutch pedal ? Aint no body have time for that
And my injectors if 3k aint enough they are upgradable to 5000cc lol
hatchbone
Re: new drag car
« Reply #134 on: April 02, 2013, 08:50:11 PM »
ot the tuck 100% done today, cant see a single wire in the bay test fitted my cf fenders also seen to work good all ready to start test fitting trans/engine next
Before
After
Not sure if this is what they ment by white power lol it will work though
And the start of my cluster setup
hatchbone
Re: new drag car
« Reply #135 on: April 02, 2013, 08:50:53 PM »
ell wavetrack lsd for the 8.8 showed up so I got it installed today and got the back lash set also finished up my cluster and down pipe yesterday, gonna test fit my engine/trans tomorrow if I aint working then if all clears with no issues im assembling my engine sat
hatchbone
Re: new drag car
« Reply #136 on: April 02, 2013, 08:51:32 PM »
Didn't have to work today so I pulled my car out of halfblown and got it in to fullblown so I could get this trans test fitted and get the mount made for it. turned out well though nothing my 2lbs hammer couldn't solve for me lol also got a pass side harness for my pass so they have a little piece of mind when we out on the streets and my revised mounts showed up also
hatchbone
Re: new drag car
« Reply #137 on: April 02, 2013, 08:52:43 PM »
been a while since i had time to update this thread so if the words dont make since fuck you pics explain it all
Re: new drag car
« Reply #138 on: April 02, 2013, 08:53:13 PM »
This thread delivers  :noel:
What is the goals this year?
hatchbone
Re: new drag car
« Reply #139 on: April 02, 2013, 08:58:47 PM »
Should make more power and be faster im thinking, well thats the plan  anyways
Re: new drag car
« Reply #140 on: April 02, 2013, 09:30:30 PM »
Like what 1/4 times or mph you going for?
Do you have to build to the 10.5 rule?
Re: new drag car
« Reply #141 on: April 02, 2013, 09:31:41 PM »
I have been wondering about those Moran injectors. Supposed to atomize better than others.
hatchbone
Re: new drag car
« Reply #142 on: April 02, 2013, 09:45:54 PM »
Car ran a 10.2@135 last year at mid 500ish hp and I was shifting 3rd at 4k after I noob shifted it, but there are cars with the same builds running 8's with the setup I had last year I just had to ditch the manual trans after I had to drop 3k to rebuild it so when I got it back I sold that slut asap and started on this t400 swap figured if the 1000hp supras use them ill give it a shot also,but should run atleast low 9's this year without to much fuckin around
Re: new drag car
« Reply #143 on: April 02, 2013, 10:07:54 PM »
looks fucking sick
Re: new drag car
« Reply #144 on: April 02, 2013, 11:16:43 PM »
Badass  :noel:
Re: new drag car
« Reply #145 on: April 03, 2013, 10:32:08 AM »
Shooting for 1000hp?
boosted 00 black si
Re: new drag car
« Reply #146 on: April 03, 2013, 08:15:36 PM »
Ur the man 8)
go fuck your self
BORN TO BOOST
LITTLE B16.400whp on 16psi
hatchbone
Re: new drag car
« Reply #147 on: April 03, 2013, 08:26:45 PM »
Thanks
hatchbone
Re: new drag car
« Reply #148 on: April 10, 2013, 03:05:58 PM »
Custom sfi certified billet flexplate finally showed and thats all I needed to get this slut up and running boo ya
Re: new drag car
« Reply #149 on: April 10, 2013, 04:28:30 PM »
Do WeRk niggugh!!!
Pages: 1 ... 3 4 [5] 6 7 8   Go Up
