Pages: 1 ... 39 40 [41] 42 43 ... 47   Go Down
Author Topic: UI's 703hp Purple beast - She is injured  (Read 832424 times)
Re: UI's 703hp Purple beast - She is injured
« Reply #1200 on: June 18, 2010, 11:56:31 PM »
why is there no grills?
« Reply #1201 on: June 19, 2010, 12:20:59 AM »
becuhuszzzzzz a canadian indian hasnt tried to polish it yet duhhhzzz
« Reply #1202 on: June 19, 2010, 01:36:22 AM »
I pulled the bottom end apart this afternoon, everything looked pretty good. I took some pictures for JD but left my camera at the shop, updates in thee morning.
« Reply #1203 on: June 19, 2010, 02:28:55 AM »
did it bend valves or drop them? ???
« Reply #1204 on: June 19, 2010, 04:34:50 AM »
all valves bent or damaged.
need a new set. Trying to find what pistons these are because I forget and there is a weird number on the bottom.
Says 82 but its an 84mm bore
« Reply #1205 on: June 19, 2010, 09:14:35 PM »
Ok so here are some carnage pics. For some reason no pics of the head on this memory card so those will have to come later.
Pistons 4 through 1:
And here is Thursdays random emergency welding job, added only because blown engine pics are lame. (for some reason the pictures of the parts with the tube standoff didn't save except for the one weld closeup.)
« Last Edit: June 19, 2010, 09:17:19 PM by Passenger »
« Reply #1206 on: June 19, 2010, 09:24:54 PM »
I've decided that im going to beg you to give me an hr or so of welding instruction when i come back.
Pretty please with cherrys on top  :-*
« Reply #1207 on: June 19, 2010, 09:41:50 PM »
No problem, you supply the Tacos, I supply the welding instruction.
Speaking of Tacos, its time to leave the shop and go make some Tacos :mexi:
« Reply #1208 on: June 19, 2010, 09:46:58 PM »
About 10 Jack in the Box taco's with an oreo shake sounds amazing right now.
« Reply #1209 on: June 19, 2010, 09:55:11 PM »
Jesus fuck... Looks like a box of rocks got dropped inthat fucking tthing, again
« Reply #1210 on: June 19, 2010, 10:18:53 PM »
No doubt, I am too lazy to drive across the border right now so I just got back from Taco Bell.
« Reply #1211 on: June 20, 2010, 01:16:41 AM »
I'd be more than happy to jump the border to get some Jack in the Box Tacos right now  :mexi:
« Last Edit: June 20, 2010, 01:27:23 AM by sewell94 »
Crackdown
  • Resident Heterosexual
    • REAL Homemade Turbo
« Reply #1212 on: June 22, 2010, 10:13:45 PM »
More carnage pics, I got my friend to hone the cylinders today and this is what we found after we took .0005" of each cylinder:
#1
#4, intake side:
#4 exhaust side, .017" deep :o
Looks like a set of upside down boobs.
« Reply #1213 on: June 22, 2010, 10:20:10 PM »
5/10,000ths?
Crackdown
« Reply #1214 on: June 22, 2010, 10:22:41 PM »
« Reply #1215 on: June 22, 2010, 10:36:29 PM »
Ok either way, no amount of anything would get that out
Crackdown
« Reply #1216 on: June 22, 2010, 10:43:13 PM »
Well I could bore it .040" over, but I have a couple issues with this:
The .017" valley is large, and it is not worn that deep, it was THRUST that deep, so it has been formed, seriously altering the grain of the sleeve, and likely causing a great deal of stress to the sleeve carrier.
Also this sleeve is getting thin, if I punch these out to 85mm I think the wall thickness is going to be around .100"
« Reply #1217 on: June 22, 2010, 10:45:12 PM »
You COULD, but like you said, the walls are getting thin at that point
Crackdown
« Reply #1218 on: June 22, 2010, 10:48:20 PM »
Exactly. I have doubts on my success of removing the #4 sleeve, without disturbing things too much.
« Reply #1219 on: June 22, 2010, 10:50:18 PM »
People make great power on 85mm turbo B-series, but I don't think they make the power Levi wants.  I've heard of a bunch of 500-600 whp setups, though.
« Reply #1220 on: June 22, 2010, 11:22:40 PM »
Fuck it jump that fucking thing into a lake.  If Benson wont do anything for you... Get a GE block and start over....  Im still not convinced that that will entirely fix things, but when you uys were looking at the head(s) as possibly being machined wrong, I kindof suspected the block... Wonder if its just a shoddy block/sleeving. It IS the one constant...
Gay levi.
Sorry bud.
« Reply #1221 on: June 22, 2010, 11:34:34 PM »
Levi that sucks to hear. Hope you get something figured out.
Dave log out of Crackdown...  :P
Crackdown
« Reply #1222 on: June 22, 2010, 11:47:15 PM »
I'm wondering if the reason the sleeve pushed out had anything to do with the fact I already bored these sleeves out 1mm oversize :(
The sleeve thickness at current is .090", if I took .040" out of the sleeve I'd be left with a .070" wall :o Too thin.
So BDV, GE is the block to have?
« Reply #1223 on: June 22, 2010, 11:48:23 PM »
I'd go with ERL.  Favorable results, and the owner isn't a fourteen year old douche making up lies on the internet.
Crackdown
« Reply #1224 on: June 22, 2010, 11:55:43 PM »
Like this?
http://www.azht.net/forum/showthread.php?t=97453
« Reply #1225 on: June 23, 2010, 12:04:07 AM »
One of the staff being Douchebag or not... GE blocks are unarguably solid as fuck.  If I were to do another....  Id DEFINATELY go with GE again.
« Reply #1226 on: June 23, 2010, 12:07:24 AM »
As are ERL blocks, and you don't have to put up with peniswhistle Robert sucking Bisi off and claiming that Ryan89crx and Chuck hacked his Photobucket.  It's not like there isn't a glut of talent in the Honda scene, Spikey, so it becomes VERY easy to drum undesirables like the faggot that bought GE out of the business.
« Reply #1227 on: June 23, 2010, 12:08:22 AM »
I've been using golden eagle sleeves for years with great success.  I also like the AEBS sleeves, i had them in another engine of mine that I sold.  The erl stuff is very nice, and have heard alot of good things about them.
I have the GE hd sleeves in my engine now. I had repeated back to back 55lbs runs on the dyno, no overheating no issues, except for the 235 MT that blew out :)  If i were to buy again it'd be GE again or the AEBS.
The lies from the GE guys really hurt themselves in my eyes, but the products stand for themselves.
Crackdown
« Reply #1228 on: June 23, 2010, 12:09:38 AM »
Do any of these guys have a block you can just buy off the shelf, or is it a core exchange, or send your block in deal?
« Reply #1229 on: June 23, 2010, 12:12:44 AM »
You can buy one without a core... Think its 150-200 extra depending on the block though...
Pages: 1 ... 39 40 [41] 42 43 ... 47   Go Up
