Pages: 1 ... 6 7 [8]   Go Down
Author Topic: Jacer's 63' Nova Twin build.. Update..Parts showed...  (Read 196000 times)
JACER63
  • well shit..
Re: Jacer's 63' Nova Twin build.. Update..VID's ..check it
« Reply #210 on: September 13, 2013, 04:24:15 PM »
well i guess ill add the fab of the 7.5 in cowl to the steel hood...
mock up
and more...
time to cut and start molding the glass... shit was smooth to work with..
all i did was a good tight fit, then rivet the cowl through the hood and used straight resin sandwiched between the two flange and hood under the hood for the first step.then i applied some mesh the next day to it..
theni let it set up for a day or so.. then some touch up and blending,sanding and glaze bondo..
and all primed and ready to wet sand and paint...
well more to come when parts arrive on mon. finish the motor and break the bitch in ....
Re: Jacer's 63' Nova Twin build.. Update..added some hood pics ..check it
« Reply #211 on: September 13, 2013, 05:32:37 PM »
Looks good.
If you would have knocked that high spot on the ridge in the front down and blended it would be perfect IMO.
NoPistons!
« Reply #212 on: September 13, 2013, 06:25:14 PM »
Expecting 8's out of this eventually.  Living the dream.  Sick car, supportive fam, kickass neighboors.  Count your blessings every single day. Good shit.
« Reply #213 on: September 13, 2013, 06:53:35 PM »
This thing is a couple solid shake down passes away from being out of cage.  :noel:
JACER63
  • well shit..
« Reply #214 on: September 14, 2013, 10:24:25 PM »
Looks good.
that was the factory line so i had to work with it..in person it looks ok...
« Reply #215 on: September 16, 2013, 01:27:21 PM »
This
JACER63
  • well shit..
« Reply #216 on: September 17, 2013, 04:03:25 PM »
This
thats this winter's project.. adding tubing and door x'es and gussets to be 8.50 cert..
JACER63
  • well shit..
« Reply #217 on: September 17, 2013, 04:29:06 PM »
pushrods came in so i started to put it all together...
the new roller rockers.. 1.6 in 1.52 exh comp ultra magnums
all installed and looking good.. the roller tip is centered all the way through the lift. all good..
intake installed and all sealed up, dizzy stabbed and phased...
back to work i goooo
should have the motor all ready to fire by weds. then off to bremerton..
Re: Jacer's 63' Nova Twin build.. Update..Parts showed...
« Reply #218 on: September 18, 2013, 02:43:01 PM »
Make sure the tune is dead on!
« Reply #219 on: September 18, 2013, 02:52:44 PM »
This
The way this thing is looking, I would be looking at a 25.5 cert for 7.50's.
JACER63
  • well shit..
« Reply #220 on: September 26, 2013, 06:06:59 PM »
well decided to pick up some stud girdles for peace of mind..cheap and easy..
car fired right up and ran tits.. then went to work and when i came home to laod it on the trailer, the cunt would not fire..?
checked all the usual shit and found no spark. damn pickup/module on the dual sync dizzy shit the bed.. fuck
ordered a new one as the tech guy says its the culprit.part should be here today/tom.
man iam running outta weather to shake this thing down before winter ...
« Reply #221 on: September 28, 2013, 08:29:45 PM »
Please tell me you do not run with those filters at the track.
« Reply #222 on: September 28, 2013, 08:59:46 PM »
Take a look at those and then think to yourself, would these Briggs and Stratton mower air cleaners feed 1000hp?
« Reply #223 on: March 26, 2014, 02:44:23 PM »
NOVA!
this gonna make it to the meet?!?!?
« Reply #224 on: April 06, 2014, 01:48:12 AM »
Better get your mind right! Fuck camping! You can go camping the next weekend. Don't give me the bs story that you can't make it to the dyno day. You better have that mother fucker at the dyno day or leave your key for it with me and I'll make sure I get you a printout if your numbers.
JACER63
  • well shit..
« Reply #225 on: April 26, 2014, 01:18:55 AM »
Well iam going to see if I can reschedule my trip... I sure hope I can make it.. aready booked this trip months ago.. I'm trying here..well see
« Reply #227 on: April 26, 2014, 01:26:56 AM »
this is our day... your wife/family gets you the other 364days... its not a bad deal... ;)
« Reply #228 on: April 26, 2014, 12:20:34 PM »
Jace will bitch and moan about it untill the night b4 the dyno day. And then show on the dyno day without his nova and some excuse that his truck is already loaded with camping/trip gear so he cant pull the nova on his trailer because his tow vehicle is packed.
« Reply #229 on: April 26, 2014, 03:09:44 PM »
Hahahahaha!!!
JACER63
  • well shit..
« Reply #230 on: April 26, 2014, 08:21:49 PM »
Yes Dustin...but this is our anniversay weekend so bad timing
« Reply #231 on: April 26, 2014, 08:53:47 PM »
Yes Dustin...but this is our anniversay weekend so bad timing ON MY PART
Fixed it for you.
« Reply #232 on: April 26, 2014, 09:55:18 PM »
Lol
« Reply #233 on: June 23, 2014, 05:37:36 PM »
Bump because you never made it to the rhmt dyno day. So what's the deal. You ever get it tuned?
« Reply #234 on: June 24, 2014, 01:32:01 AM »
It runs and smells pretty fuckin nice
« Reply #235 on: June 11, 2015, 11:48:26 PM »
Need titty ripper vids now!!!!!
« Reply #236 on: June 13, 2015, 10:56:52 PM »
Fixing rear end right now.
« Reply #237 on: December 16, 2015, 12:59:40 PM »
Failed project or what?
« Reply #238 on: December 18, 2015, 12:22:31 AM »
Naw about 5k in damage when the rear let go be back together for next season
Pages: 1 ... 6 7 [8]   Go Up
