Pages: 1 2 3 [4] 5   Go Down
Author Topic: F2B & H2B nonsense build thread (LOTS of pictures & nsfw)  (Read 225453 times)
Re: F2B & H2B nonsense build thread (LOTS of pictures & nsfw)
« Reply #90 on: March 14, 2013, 12:45:07 AM »
Bad news - I sold everything and bought a Prius. Fuck you. :noel:
« Reply #91 on: March 14, 2013, 07:59:11 AM »
Yeah right  :?:
« Reply #92 on: March 14, 2013, 08:46:13 AM »
About fucking time. You tell your mom you're out of the closet yet?
« Reply #93 on: March 14, 2013, 09:06:34 AM »
Reminds me of this:
http://youtu.be/KiPyMciRWQQ
Thank JD for this,  FUCK You  :noel:
« Reply #94 on: April 02, 2013, 09:38:06 AM »
List of things left:
*Finish IACV work - block-off plate and relocator flange (only needed because I'm starting with the F22B2)
*Weld & drill rear T-bracket (cuts already made)
*Pound the frame edge in 1-2mm (there's a chance for rubbing with these sloppy motor mounts)
*Finish the harness & post up what wires to modify
I wish I could work on this, but I've had my business taking my time & I have to go up north this weekend. I also have my EJ that's getting a new front end & paint.
The F22 *will* make it into my DD Integra this month, and the H23A will replace it before June. I will also be sending in cores to Delta next week, one will be for a F22 272...
« Last Edit: April 02, 2013, 09:39:52 AM by HiProfile »
« Reply #95 on: April 02, 2013, 11:16:50 AM »
Pass on the delta cams go colt!
Had a delta cam go flat on a motor I built for a friend. Tons of zinc in the oil, valves last to delta recommendation. Bent some valves/ killed some guides......
« Reply #96 on: April 02, 2013, 08:15:27 PM »
For the extra $200, I'll pass. It's just an F22B2, and anyone can have a cam go bad be it a regrind or billet. John said the only cams that really have issues are vtec heads where the cam lobes are too narrow. King down the road says Skank2 Pro 1 & 2's have the same issues w/o half a bottle of zinc added per oil change.
I'm debating if I should switch from the 55mm TB to 60mm. With the 272 it could be worth a few ponies.
« Reply #97 on: April 03, 2013, 09:50:46 AM »
I have a delta 272-2 in the GRM car. Been in there for 3 years with no issues.
« Reply #98 on: April 12, 2013, 12:55:49 AM »
I got the last major chunks of work done...finally! It's been raining non-stop for almost a week, and hasn't moved out of the 30's that entire time. It's not that easy when the garage is unheated.
First I worked on getting the IACV relocated on the F22B2. It will be in the way of the firewall brake lines, and this was much easier than doing a brake line tuck.
This shows the 64mm LS TB I bored years ago, along with the IACV plate below it near the thermostat. Once I get the Delta 272 cam, I'll be putting a 60mm TB on it & port-matching the upper plenum. The 64mm TB will end up on the H23A or the built F22A.
This shows the plugged IACV holes, and the locations for in & out on the manifold. I'll be running 3/8" vac line behind & below the manifold, or on the other side if I don't put 90* elbows under the IACV nipples.
The biggest bump in the road was modding the rear T-brace. DONE! I put a shim in it while welding so I can later fit it over a B-series block again, of course after adding a 2nd set of holes. For some reason the F/H tab is 1mm narrower. I used 3/16"x1.25" bar like on the trans/block bracket with a 9/16" hole.
Now all that's left is taking pics of the harness & fitting it into the del sol again. I'll have to fab a 6" exhaust section behind the header, route the vac & coolant lines, then take it for a rip.
« Reply #99 on: April 12, 2013, 09:48:52 AM »
Oh yea get that bitch running already!
« Reply #100 on: April 12, 2013, 12:39:22 PM »
very informative thread. I know its hard as fuck to do step by step shit and take pics of everything and then do a write up about it. Good job mang!
« Reply #101 on: April 25, 2013, 06:23:46 PM »
After 2 weeks of rain, hail, sleet, and snow (wet nearly every day!) I finally got the F22 back into the del sol. Nothing to really see, looks like the first time it was in. I got the frame rail pounded in a 1/4" in case I make a bracket for the Civic 3-bolt driver's mount. Now there's almost 1/2" next to the pulley. The modded t-bracket and upper trans/block brace both do their job.
To make sure the tranny was lined up properly, I tipped the engine onto the driver's side (on a 3/4" thick anti-fatigue rubber mat), loosened the trans, twisted it on the motor a bit, then tightened it all back down. The only issue I can see is the PP clamping the clutch disc didn't let the input shaft line up to the pilot bearing. I made sure the ISB and pilot bearings had zero play, and also made sure the clutch alignment tool was dead-center.
I've got some prothane inserts coming soon, so I'll be using the rear & pass side with a pass side torque mount insert from Energy Suspension. Then it's just a matter of tossing the harness back in, connecting fuel/vac/coolant hoses, and bolting the axles/knuckles back on. That will let me get the Integra's ITR rear sway & 60mm exhaust on, and if all goes well - the H23A dohc vtec motor too.
« Reply #102 on: April 25, 2013, 06:35:01 PM »
Oh yea do work!
« Reply #103 on: April 28, 2013, 04:55:35 PM »
The weather finally broke into the 70's on a day off, so I finished the wiring outside.
Here are the changes I made to a 92-95 OBD1 Civic harness:
Alternator: 30" total, 18" added, moved to where the injectors branch off
Oil Sender: 11" total, 7" added (either swap your H22 to a plug-type or use a ring terminal)
IAT: 8" total, separated from Purge
Purge Solenoid (for IAB control): 6" total, 6" removed, separated from IAT
MAP/TPS: 17"/11" total, move to VSS spot on main loom
IACV: 11" " total, move to VSS spot on main loom, separate from MAP/TPS
Thermoswitch: 7" total, separate from GROUND wire
VTEC: 7" total, separate from Distributor wires 4" back; Pressure Switch ends up with 6", Solenoid ends up with 7"
O2 sensor: 12" total, separate from the Distributor cluster, move to the main loom (extend 4-8" to be fully compatible)
Injectors: partially separate #1 & #2 from each other (about 1-2") to route under the rail
I started with a 92 D15 wire harness, so I had to add the VTEC Solenoid wire and the MAP wires. I will be running eCtune so I'll be disabling the VTEC Pressure Solenoid and running the IAB Solenoid via the Purge wires. This way I only have to add a single wire on the chassis harness on my Integra LS.
obd1 Civic & Integra H22 swap harness all taped up:
H22 swap harness vs obd1 Civic EX sohc vtec harness:
My workspace with plenty of light (I got hooked on dog treats back in 'nam lol):
My Prothane inserts also arrived, just in time too. I got a full set plus an extra side trans insert. I need enough for 2 car's worth, and already have the Energy Suspension rear/torque insert kit. I'm not 100% sure what I want to do with the driver's side, but at least one will have the modified Prothane kit. I plan on drilling most of the center puck's material out, and possibly some of the material from the 2 outer pucks. It won't be a race car, but I'll definitely need to keep the motor from rocking. The F22B2 manifold & IAT are only ~1" from the brake prop valve & lines.
« Last Edit: May 02, 2013, 02:59:27 PM by HiProfile »
« Reply #104 on: April 29, 2013, 09:02:26 PM »
I got the rear & side inserts installed, but the rear was a PAIN to get in. In the end I had to modify it since it was just too thick on the bottom tabs to fit. The red arrows point to the areas I ground off. I just stuck both on the bench grinder and went to town.
I was checking into the Speedfactory D2B kit, and found it VERY interesting: http://www.speedfactoryracing.net/store/#!/~/product/category=472454&id=2975787
Quote from: Speedfactory
designed and tested in our 9 second D16 racecar ... The use of the factory dowel pins is no longer retained
They use the block/trans braces to line up the crank & input shaft. Given they've used it on their 9-sec car (one block actually split in half from the power), I presume a plateless solution for the H2B now has a bit more validity.
« Reply #105 on: May 05, 2013, 04:58:49 PM »
IT RUNS!! (edit: check a few posts below for the "fixed" video)
(open header)
http://youtu.be/qAJWj3vTIVA
http://youtu.be/Hxa5ZXcgFF4
I just need a 37" alternator belt and some exhaust clamps.
« Last Edit: May 09, 2013, 01:33:04 PM by HiProfile »
« Reply #106 on: May 05, 2013, 09:49:11 PM »
Anyways I got the exhaust sealed up and a 37.3" belt on the alternator (no AC or PS). Either it has a weak cylinder, badly needs a lifter adjustment, or the injectors are in various states of being clogged. It really lopes at idle, and I doubt it has an upgraded camshaft.
Regardless there are no codes, the radiator fan comes on, and revs nice. I *will* be driving it this week.
« Reply #107 on: May 06, 2013, 12:51:29 AM »
Mine loped like fuck at idle when it was open header.  Bone stock.  Mine probably was an issue with the O2 sensors being generally unhappy about the whole experience if I had to guess.  Sounded a bit smoother than that though.
I actually really liked how it sounded at idle open header.  The displacement gave it a nice rumble.  Sounded like ass everywhere else though.
« Last Edit: May 06, 2013, 01:48:31 AM by Phate »
« Reply #108 on: May 06, 2013, 09:03:55 AM »
I got the exhaust hooked up and it still lopes pretty bad, and it isn't pulling much vacuum at idle. The idle screw is full-out and it still dies w/o the IACV. I doubt it came with a 282 cam in it, but I can hope. I'm guessing a bad cylinder due to ancient platinum plugs that sat in oil for 1-2 years or it badly needs a valve adjustment. I'll be doing further tests today once I swap the starter. This starter rarely works even if you bang it with a hammer.
I ended up using a 5040373 belt on the alternator, 37.3" long. A 37.7" belt may have been easier to get on, and only 4 ribs are needed since it's driving a single accessory. :Jew:
« Reply #109 on: May 06, 2013, 12:10:07 PM »
Oh yea!
« Reply #110 on: May 06, 2013, 12:52:49 PM »
Mechanical timing is good?
« Reply #111 on: May 06, 2013, 01:40:09 PM »
heard a similar issue on an accord I was working on and it was a pulled injector wiring harness wire near the injector.  :noel:
« Reply #112 on: May 07, 2013, 01:02:27 AM »
I hate to say it, but I'm presuming mech timing is good. DasPoop sold this motor for his friend because the trans died. I tried pulling the plug wires off and #1 & #2 removed makes no difference, which makes sense with the heavy loping sound. I'll try my 370cc injectors after the compression test.
« Reply #113 on: May 09, 2013, 01:24:33 PM »
FIXED!
Turns out having the EGR connected to vacuum with a non-EGR ecu sucks it open. The problem was compounded by the EGR system likely being clogged.
H2B F2B F22 Civic Del Sol - running 100%
All that's left is to grind a hair more by the driver's axle since this axle has much larger clamps on the boot. I just got a cheap-ass ebay header ($60 shipped) I plan to add too.
« Reply #114 on: May 09, 2013, 10:45:02 PM »
Do work, btw I still want a set of those home made brackets!
« Reply #115 on: May 15, 2013, 10:08:49 AM »
+$250: LS trans, clutch, linkage, axles
+$200: F22B2 w/harness & auto trans
+$10: plate for halfshaft & IACV
+$20: bits & bolts & steel
+$10: intake hose & fittings (IACV)
_____________________________
$490 for >130lb/ft of torque at the wheels.
$1290 for >170whp if you get an F20B shipped from HMO instead.
$1690 for >200whp if you get an H23A vtec shipped from HMO & ebay bolt-ons.
I'm also getting my brother's GoPro cam soon to get some hi-def rippers. I'll also try to get some showing my LS Teg up against this F22 del slow.
« Reply #116 on: May 16, 2013, 09:46:02 AM »
Rippers FTW!
« Reply #117 on: May 26, 2013, 11:54:58 AM »
Today was nice out and I had the day off, so I figured I'd toss on the $60 header. It fits up to the stock cat well, besides pushing it back about 1". I will forgo tuning for the header until the Delta 272 is installed.
It hangs down a little, but so does any header.
It's about as low as the bolts for the front sway bar. It will have a little more clearance when I make a driver's motor bracket for the Civic driver's mount, that will pull that side of the motor up an inch.
BTW I took some measurements, and the F22 head gives you an EXTRA 1" of clearance between the exhaust flange and the core support VS a d16z6!
« Reply #118 on: May 26, 2013, 11:24:10 PM »
Is that because the F22 is tilted back in the engine bay vs the D series?
« Reply #119 on: June 08, 2013, 12:36:22 AM »
Yeah, the  F/H blocks sit tilted back. This H2B method keeps it tilted almost as much as they do in a Prelude/Accord. D/B blocks tilt forward.
Speaking of tilted back... a SECOND H2B for me! (H23A Integra)
Still lots to do before tomorrow, and then a lot after that. I have 13hrs into it today, and I expect another 5-6hr before it's road-ready.
Pages: 1 2 3 [4] 5   Go Up
