Author Topic: holset h1c or hy35  (Read 45716 times)
Re: holset h1c or hy35
« Reply #30 on: February 08, 2013, 05:06:21 PM »
I belive the smallest h1c IVE seen is 12cm. I know that there is a aftermarket .63 I belive, but they are $$$$$ best bet is to pick up somebodys used splog/log/mini ram or something, and dump your ac to make room.
check my build thread, I think I have pictures of the manifold and turbo mounted with the clearance of the radiator.
If you don't run a backdoor style intercooler you will have plenty of room to move a half core in there and move it over some, but you will probably have to run a pusher fan to make room for the downpipe.
maleek
« Reply #31 on: February 08, 2013, 05:21:27 PM »
My intercooler isn't a backdoor setup, so i should have a decent amount of space. Its pretty tight in there with the full size and then those giant fan shrouds. Hopefully with a half size ill have more then enough room.
Speed Phreak
  • I'm an OG because I say so.
« Reply #32 on: February 08, 2013, 06:21:53 PM »
HY typically comes with a 9cm2 exhuast housing but the same coldside IIRC...
Depending on chassis, be prepared for clearance issues, housings are pretty large on Holsets.
SSAC Like a boss...
No front rad support and 1/2 width radiator, but different manifold same relative placement though... ED chassis. Front end was pretty much cut to shit to make everything fit on mine. I would've probably done it different in hindsight, since my old swap mounts move the engine forward a bit too much and over the years I was a little to happy with the sawzall.
« Last Edit: February 08, 2013, 06:30:31 PM by Speed Phreak »
1988 CRX HF - Turbo deathtrap
maleek
« Reply #33 on: February 08, 2013, 07:32:47 PM »
It seems that most people who have clearance issues, are running a swap, that moves the motor a bit forward (ef, ej chassis) from my research anyway. Ill probably run into them as well, but hopefully won't need to go sawzall happy lol
Speed Phreak
« Reply #34 on: February 08, 2013, 11:51:16 PM »
Yes if you're blessed with a factory b-series chassis(or newer d-series), then you'll probably have less issues...But more weight. Thank your government and auto manufactures for all the crash protection and useless gob. Personally I like knowing I could die on impact in my 1700lb deathtrap, more fun that way.
« Reply #35 on: February 09, 2013, 01:02:19 AM »
The .63 housings are on ebay all day for less than $200. Honestley i would go with a .70  and have fun. The hy why has a smaller comp then h1 or hx. I stick with the h1c cause they are cheaper then the hx.
maleek
« Reply #36 on: February 09, 2013, 01:46:53 AM »
Can the hy comp housing be swapped out for for a 12cm housing?
Aero
    • Turbotalk.org
« Reply #37 on: February 11, 2013, 07:03:32 PM »
  You mean turbine housing?  No, HX is attached via bolt down clamps, hy with a vband.
maleek
« Reply #38 on: July 10, 2013, 10:09:23 PM »
just picked up an hy35.. pics to follow, looks pretty minty.  Does everybody just use a -3AN line with no restrictor? Also is -10 suitable for a drain line on these things?
carkrazed
« Reply #39 on: July 10, 2013, 10:45:48 PM »
I ran a -4 feed (no restrictor) and a -10 return.
Never had any issues.
« Reply #40 on: July 11, 2013, 12:10:34 AM »
I ran a -4 with restrictor, and a 3/4" barb for the return. Wich is much larger than a -10an fitting. But I know lots of people running -10 returns with no problem.
« Reply #41 on: July 11, 2013, 01:24:51 AM »
I'm pretty sure holsets are more tolerant of big oil feeds than other turbos.  Diesel stronk, run forever
« Reply #42 on: July 11, 2013, 01:31:46 AM »
But what oil pressure do they normaly see in factory form?
« Reply #43 on: July 11, 2013, 09:56:04 AM »
-3 and a -10 return.
Fyi twin scroll if you can, I made a ton more power and full boost was almost 1000rpm sooner.
« Reply #44 on: July 12, 2013, 08:52:12 AM »
80-90psi cold
« Reply #45 on: July 12, 2013, 01:00:11 PM »
80-90psi cold
Wow, that's impressive. Do u happen to know what it is hot? Just wondering if a restrictor is neede or not. Don't want to over press it with to much but also don't want to stave it of the oil it needs.
« Reply #46 on: July 12, 2013, 07:57:26 PM »
80-90psi cold
At idle when hot min spec is 15psi iirc and at 2500rpm is 30psi. So on a healthy engine 20-25psi idle hot, and 40-50psi operating rpm.
« Reply #47 on: July 12, 2013, 10:32:06 PM »
80-90psi cold
Troof my Cummins idles at about 25psi and operating rpm 55-60psi.
« Reply #48 on: July 13, 2013, 12:41:00 AM »
80-90psi cold
Same on my He351ve  :noel:
