Author Topic: 2000 silverado 2500 LD (sloppy mechanics)  (Read 119317 times)
denmah
« on: February 16, 2013, 02:25:10 AM »
so i picked up this truck
2000 silverado 2500 light duty.
6.0, 4l80e, 14 bolt rear, 212k miles young!
pulled the evap, isntalled a IAT sensor since im removing the maf
3 bar map from EFI source
 twin walbro 400s in the tank
twins!
 started the tear down
custom cam from martin @ tick performance
 80lb injectors
alum 317s with pac 1218 springs
pulled the 4l80e for some work
 circle D triple bilelt lockup
 meth kit in the stock washer fluid tank
 removed the clutch fan and installed LS1 fans
intercooler piping
 out on 12psi valentines day
2-14-13 12 psi in the 2500
idle video
2-15-13 cold start and work truck idle
Re: 2000 silverado 2500 LD (sloppy mechanics)
« Reply #1 on: February 16, 2013, 02:39:03 AM »
Sexy beast!
« Reply #2 on: February 16, 2013, 02:42:24 AM »
nice!
side note. wtf on those china turbos. could they think of a worse spot to put those tags. you did remove them right?
denmah
« Reply #3 on: February 16, 2013, 03:22:05 AM »
haha nope i left em on there, figured they would be good for grip
« Reply #4 on: February 16, 2013, 10:30:54 AM »
Now that is doing work.
Info on the water meth setup,  pump, lines, nozzles, location of nozzle before or after turbo, hobb  switch being used or not.
« Reply #5 on: February 16, 2013, 12:35:50 PM »
Loving these builds!
« Reply #6 on: February 16, 2013, 12:36:04 PM »
fuck yes!
denmah
« Reply #7 on: February 16, 2013, 05:41:28 PM »
it was a base cooling mist kit off ebay.
i set it at 6psi hobb switch that came with it
single nozzle, i dont even know what size, you can see it right there before the 90 into the throttle body.
« Reply #8 on: February 16, 2013, 05:57:31 PM »
My nigger... You made it here huh? Nice.
« Reply #9 on: February 16, 2013, 06:27:08 PM »
Fuck yea! I been thinking of turbo'ing my 03 yukon (same motor). More info on the iat/3bar? Also with the turbo mounted in that location how do the return lines look?
denmah
« Reply #10 on: February 16, 2013, 06:32:14 PM »
its a buick 3800 sensor and pigtail out of a junkard, thats where i get all my sensors when i do megasquirt builds,
the 3 bar and pigtail is from EFI source, its like 40~ shipped.
i have a turbowerx scavenge pump pushing the oil back to the oil fill cap in the valve cover.
79fairmont
« Reply #11 on: February 16, 2013, 09:52:14 PM »
Awesome!
« Reply #12 on: February 17, 2013, 11:30:33 PM »
Have you dyno'ed it yet?
denmah
« Reply #13 on: February 18, 2013, 12:01:47 AM »
nope i just got it together the other day, built it in about 2.5 weeks start to finish, had some problems with my wastegates getting stuck open haha!
« Reply #14 on: February 18, 2013, 12:53:51 AM »
WTF hahaha
Well to bad they closed down Island drag way. Im sure if you can get it to hook it will fast!
EG-MIKE
« Reply #15 on: February 19, 2013, 12:55:30 AM »
This is a sweet truck, In for dyno numbers and some vids from outside the truck. Getty a buddy to tail you with a camera  ;DDD
my girl has the 5.3 was thinking of what to do with it. 4wd is beast, lol.
Theres a guy out my way with a 5.8 i think it is. With corvette heads and twin turbo etc etc idk all the details of his build but i do know that at 60mph in 4wd he blisters all 4 tires. First time i seen him do it i thought he blew the motor there was so much white smoke
« Reply #16 on: February 19, 2013, 04:46:02 AM »
Wow, that looks like fun.
Am I seeing that right, 211k on the odo???? FUCK!
denmah
« Reply #17 on: February 19, 2013, 05:57:53 AM »
yeah i bought it with 211,866 or so. and immediately turbo'd it
its over 212 now haha
i have only had it 4 weeks now
i was out beating up these drilled chinese wastegates, they are holding boost great.
« Reply #18 on: February 19, 2013, 07:56:32 AM »
Fucking bitchin. Buying an lm7 here as well soon O0
denmah
« Reply #19 on: February 22, 2013, 01:03:49 PM »
stock rear was pretty worn out and i hate 1 leggers so i pulled a junkyard unit and welded it up, slammed it in last night
« Reply #20 on: February 22, 2013, 06:17:20 PM »
You fit in here like paranoia on Johnny.
 O0
« Reply #21 on: February 22, 2013, 08:05:48 PM »
lol drift machine with a welded diff. Definitely going to be nice with traction in a straight line though
« Reply #22 on: February 24, 2013, 02:05:21 AM »
Fucking titties!!!!!!!!
Nice work sir.
denmah
« Reply #23 on: February 24, 2013, 02:19:09 AM »
i wanted to do some sick burnouts today but it rained forever
« Reply #24 on: February 24, 2013, 03:23:05 PM »
What is that blinking light
denmah
« Reply #25 on: February 25, 2013, 12:10:24 AM »
security and battery light
schim187
« Reply #26 on: February 25, 2013, 02:49:05 AM »
Sweet Build  ;DDD
« Reply #27 on: February 25, 2013, 04:01:57 AM »
DO none of you faggots kowe who this asshole is? LOL..
Fuckin homos.
« Reply #28 on: February 25, 2013, 06:15:39 PM »
Fuckin homos.
An rhmt Pa nog I can go hopefully harass into helping my turbo my 03 yukon? :P :evil:
denmah
« Reply #29 on: February 27, 2013, 02:02:36 AM »
Pages: [1] 2 3 ... 5   Go Up
