Pages: 1 [2] 3 4 ... 9   Go Down
Author Topic: Ohisofly's 91 Crx  (Read 356493 times)
ohisofly
Re: Ohisofly's 91 Crx
« Reply #30 on: November 21, 2013, 04:00:33 PM »
http://www.ebay.com/itm/251303514718?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
says it'll be here Friday
Do not forget to roll your own bead on the IC piping.
Gives your hands a workout, couplers stay on, and if you have trouble w/ couplers getting over the bead use vaseline or di-electric grease.  :noel:
Thanks for the heads up, that looks like a really good idea. Is there a specific name for those pliers or did you just get lucky and it worked for that situation?
Im in the same boat right now with an hx35
The last one I kept soaking, then hit the housing with some heat
Then I tightened that bolt in the picture
Stuck a pry bar between it and the flange above it
Backed out the bolt into the pry bar and let it push the center out
Once it broke free a little bit I could work it off
Thanks for the details man, I'll give that a try. I honestly had no idea if this was a somewhat-common problem or if I was just really unlucky haha
91 Crx Si - turbo ls vtec
« Reply #31 on: November 22, 2013, 02:29:36 AM »
Common. This one is being a cunt and still won't budge
n/a mike
  • Mr. Hotpocket
« Reply #32 on: November 23, 2013, 01:24:21 AM »
I made my own back when I had my turbo crx, used hairspray too.
good old 1980's aquanet
ohisofly
« Reply #33 on: November 25, 2013, 05:50:13 AM »
Could you explain? Sorry I'm confused  ???
I did some work this weekend, if I'm not too lazy I'll put up some pics tomorrow  O0 what do you guys think about getting an ebay ram horn manifold and then getting my uncle to go over the welds and 'reinforce' it? I searched and found a few threads of people running ebay ramhorn manifolds; I'm thinking about this one
http://www.ebay.com/itm/Honda-CIVIC-CRX-B16-B18-T3-Turbo-RAMHORN-MANIFOLD-/160643182543?pt=Motors_Car_Truck_Parts_Accessories&hash=item2567146fcf&vxp=mtr
« Reply #34 on: November 25, 2013, 08:21:46 AM »
Explain which, aquanet or bead rolling?
ohisofly
« Reply #35 on: November 25, 2013, 09:27:08 AM »
I just don't understand how hair spray is related to bead rolling haha
« Reply #36 on: November 25, 2013, 09:47:27 AM »
Old skool solution if you do not bead roll then you glue the shit together.  :noel:
n/a mike
  • Mr. Hotpocket
« Reply #37 on: November 25, 2013, 10:35:11 PM »
Exactly, spray that shit all over the coupler and piping, it slides on super easy then when it dries it's almost like glue. expensive hair spray doesn't work, but the cheap crap does.
it's an old trick I learned when I was a kid riding bmx bikes. putting new grips on the bars. hair spray makes them slide on and when it dries they won't come off.
I made my own bead roller with a pair of pliers, jbweld and some small nuts. I tried to find the pic I took but couldn't.
« Reply #38 on: November 25, 2013, 10:46:25 PM »
paint works well too. you paint all your pipes. let them dry. then hit the ends before you slide it together. think that was the Jeff Frank method.
ohisofly
« Reply #39 on: November 28, 2013, 10:34:02 AM »
Thanks for the info guys, that's definitely something I'll keep in mind. I got my bov flange, downpipe flange, wastegate gasket, some random intercooler piping stuff, etc. so I think now I have just about everything. After I see what I have left from black friday I'll be ordering the ramhorn manifold and boost controller
Could someone give me a link to info on boost controllers, or is anyone willing to explain them in detail to me? I've searched on here but couldn't find much. I know they trick the wastegate so you can run more boost, but what makes a $80 hallman boost controller so much better than a $15 ebay one? I assume someone would only need an electronic boost controller for boost by gear?
« Reply #40 on: November 28, 2013, 11:56:12 AM »
Proper couplers and clamps with good fitting pipes works pretty solid. I have 3" chargepipes with no bead or hair spray/glue of any kind. Holds solid to 30psi, maybe more. Never pushed it harder
n/a mike
  • Mr. Hotpocket
« Reply #41 on: November 28, 2013, 03:05:19 PM »
This is RHMT not Honda Tech, we use what ever we can find for charge piping. do you forget the brake kleen can charge pipe?
« Reply #42 on: November 28, 2013, 05:11:47 PM »
I made my charge pipes from aluminized steel from Columbia River and mig welded it. It's pretty RHMT.
« Reply #43 on: November 28, 2013, 08:37:36 PM »
mine is made from left overs from Columbia River purchases, and previous builds that have been cut up and used again... FLUX CORE  O0  cuz this is RHMT...
btw. i just weld little stitches/dimples on the end of my pipes. use worm drives clamps from Home Depot, 4ply Mishimoto couplers. shit works fine...even on the Galant at 25psi...
ohisofly
« Reply #44 on: December 04, 2013, 11:08:19 AM »
Here's where I'm at right now, looks like the car is just going to sit until it's turbo. I went to put on my b16a throttle body, but the fast idle valve is located on the throttle body instead of the intake manifold. So now I have to put back on my obd0 intake manifold, which I was too lazy to do at the time
Close enough right?
This is with the intercooler in the orientation that it's in when on the evo
The piping isn't going to go like this I was just seeing what it would look like
ohisofly
« Reply #45 on: December 04, 2013, 11:12:19 AM »
Again the piping isn't really going to go like this just getting a feel for things
Ebay swag
I'll have fun with the intake manifold this weekend hopefully
At this point I had my Uncle come over and we were trying to figure out the best way to do the intercooler piping
ohisofly
« Reply #46 on: December 04, 2013, 11:52:48 AM »
Making room
Intercooler will be moved back to the red area and the rad in the green, only reason for this is to have the sleeper look because I won't be cutting away at the bumper at all and the intercooler will be painted black
Original picture for reference
This is where things get complicated, but this is option #1 which assumes I'm using a ramhorn manifold. It has as little piping as possible, and on the drivers side still has the piping down low which will be needed for a ramhorn manifold
ohisofly
« Reply #47 on: December 04, 2013, 12:18:12 PM »
This is option #2, assuming I would be using a top mount manifold. Yes, I already know a top mount manifold is pointless and a waste of money considering the power I'm trying to make. But this summer I'll probably be throwing a forged bottom end and maybe going lsv or a p8r head so she'll definitely be seeing more power. At that point when I get a bigger turbo I understand that I may be going twin scroll, but even then I wouldn't have to completely redo my intercooler piping setup if it was already made for a top mount. Plus top mount just looks baller  O0
My uncle said he could probably make one using this manifold I have at my house along with some random piping
Or I could buy one on ebay and most likely just cut off the v band wastegate flange and weld on a 2 bolt flange since I already have my wastegate. Either way, a ramhorn manifold is already roughly $150 on ebay so I'm perfectly fine with spending $300 to go topmount.
Assuming I went topmount, this is how the intercooler setup would be. I didn't have a pic of the intercooler flipped but it would be flipped from the option #1 orientation. No the downpipe will not exit the hood haha
I'd much rather go the topmount route solely because it looks much better in my opinion, and would make things easier. But I'm open to all suggestions. I know this intercooler is overkill for my setup but again down the road I don't want that to be my limiting factor and then have to redo everything for a bigger intercooler. That's all I have for now, what do you guys think?
« Reply #48 on: December 04, 2013, 12:37:18 PM »
Remove fast idle valve, make a block off plate and gasket..... Problem solved
The 2 piece 4-2-1 headers are much easier to make top mounts with. Don't make it harder than it has to be
« Reply #49 on: December 04, 2013, 01:13:19 PM »
I hope the turbo really isn't going there.  :?:
Opt #2 with a elephant top mount is in the spirit of RHMT gangster.
or Sinktrap
ohisofly
« Reply #50 on: December 04, 2013, 01:38:52 PM »
Having no fast idle valve and having my car as a daily in the winter isn't very fun, that's the only reason I want to keep it because it makes things so much easier under cold starts. I didn't know people even did that, I need to start thinking more rhmt style  :mexi:
or Sinktrap
Yea I was just messing around putting the ebay turbo there. Thanks for all those pictures, that was going to be my next question haha. I'll show those to my uncle this weekend. It looks like those first two have a twin scroll design, is that intended for those setups or just how it ended up working? Regardless I'll definitely be going this route
« Reply #51 on: December 04, 2013, 02:30:13 PM »
They just merge at the flange, they aren't twin scroll.
You don't need a fast idle valve. The iacv will idle the car plenty high enough. Stop being a pussy.
« Reply #52 on: December 04, 2013, 04:25:57 PM »
Sinktrap FTW! Keep it twin scroll!
n/a mike
  • Mr. Hotpocket
« Reply #53 on: December 04, 2013, 10:19:08 PM »
I made one like this, I wish I could give you more info, but it was like 5 years ago and I don't remember.
google "diy mbc" and you should be able to figure it out.
Took me 5 street runs to get it dialed into 12psi, just make sure you keep the wrenches with you to adjust all the time. just in case you need to adjust it a year down the road
« Reply #54 on: December 05, 2013, 12:09:51 AM »
QFT.
« Reply #55 on: December 05, 2013, 12:27:41 AM »
Or try this http://web.archive.org/web/20071018023421/http://homemadeturbo.com/forum/index.php?topic=75418.0
I've been wanting to try this for some time.  :noel:
n/a mike
  • Mr. Hotpocket
« Reply #56 on: December 05, 2013, 12:55:36 AM »
yeah I've wanted to make something like that too.
Shit I forgot the pic I found online of the kind I made
ohisofly
« Reply #57 on: December 09, 2013, 01:00:27 PM »
Ah ok I see, and does the iacv have some type of adjustment then or what? My brother and I both have ls swapped efs and neither will stay running without holding down the gas during cold start. If you turn up the idle screw enough to keep it running then it's idling over 1k even when warmed up
Thanks for the heads up, I'll definitely be looking into this and making a trip to lowes soon
Looks like it would be baller, pretty interesting that's for sure
Right now I have finals so there won't be much to update with this week, I ordered silicone couplers and an ebay 4-2-1 along with the t4 and wastegate flanges so maybe I can get started on making the manifold this weekend
« Reply #58 on: December 09, 2013, 02:18:47 PM »
The only adjustment is in the tuning software
« Reply #59 on: December 09, 2013, 06:57:34 PM »
my EK just magicly hold steady at just below 1000rpms with no fast idle valve, and no idle screw. its been like 10-30° here for a week or so, rocks the remote start with no issue. idles at 1200-1300ish on first startup.
Pages: 1 [2] 3 4 ... 9   Go Up
