Pages: 1 2 3 [4]   Go Down
Author Topic: EG F2B Turbo :)  (Read 102107 times)
Re: EG F2B Turbo :)
« Reply #90 on: June 23, 2014, 03:27:39 PM »
Very far from stock.
Laid 472whp iirc on Jdoggs dyno.
CP Pistons
Ported/Polished Head
Greddy Manifold
Q45 TB
Z Brakes
D2 Coils
GT32 Garrett Turbo
Koyo Radiator
SPAL Fans
Greddy FMIC
Greddy BOV
HKS Exhaust
Stock oil pump???
94EGCoopey
  • Eternal noob
Re: EG F2B Turbo :)
« Reply #91 on: June 24, 2014, 05:05:45 PM »
CP Pistons - 8.5 Compression Bored .020 over
Calico Rod & Main Bearings Standard Size
1.2mm Greddy Head Gasket
ARP Head Studs
Ported & Polished Head
5 Angle Valve Job
Shot Peened Rods
Extended Crank Collar & Crank Balancing
Power Enterprise Timing Belt
Nismo Timing Belt Tensioner
New OEM Water Pump
New OEM Oil Pump
New OEM Gasket Kit
Mines Short Shifter
RPS 6 Puck Clutch w/ New Clutch Disc
Greddy Intake Manifold
Custom Dual Feed Fuel Rail
Q45 90mm Throttle Body
I have a complete build and break down, just says new oil pump. I caught a glimpse in a search of their oil pumps being garbage but havent read up on it.
Re: EG F2B Turbo :)
« Reply #92 on: June 24, 2014, 09:35:06 PM »
It's there main weak link!
My buddy made 850 on a stock block these motors can take a beating while making good power but there oil pumps are shit.
94EGCoopey
  • Eternal noob
Re: EG F2B Turbo :)
« Reply #93 on: June 24, 2014, 09:37:18 PM »
94EGCoopey
  • Eternal noob
Re: EG F2B Turbo :)
« Reply #94 on: June 24, 2014, 09:53:38 PM »
oh and forgot the pronz
Hybrid_Theory
Re: EG F2B Turbo :)
« Reply #95 on: June 24, 2014, 09:54:25 PM »
Fuck that POS..
Needs a Holset
And the corn  :noel:
Minor Threat
Re: EG F2B Turbo :)
« Reply #96 on: June 24, 2014, 10:14:11 PM »
The early RB26 motors had crank snouts that were undersized for the oil pumps, would cause harmonic issues and shatter oil pump gears at high rpm. IDK if RB25 has the same problem.
94EGCoopey
  • Eternal noob
Re: EG F2B Turbo :)
« Reply #97 on: June 25, 2014, 01:09:19 AM »
Ah ok.
So I could assume that's why the list has a machined crank collar and balanced crankshaft on it then. Possibly to help with the oil pump issue?
Re: EG F2B Turbo :)
« Reply #98 on: June 25, 2014, 01:34:19 AM »
or just jibberish that people say to make there cars sound better and to sell the car....?
Minor Threat
Re: EG F2B Turbo :)
« Reply #99 on: June 25, 2014, 11:16:09 AM »
Ah ok.
The crank collar is the other fix to the problem, aside from going to an aftermarket pump.
Pages: 1 2 3 [4]   Go Up
