Author Topic: Cheap turbo - your roots  (Read 21595 times)
« on: May 23, 2014, 10:14:00 PM »
I want to cheaply turbo my CRX.. the more I talk to people the more I see that the ITB idea is not a great one
I have a TDI intercooler,  I have been told that an integra ECU and injectors from the same Gen fit the bill...    So lets discuss.. not trying to make a ton of power.. 160whp in the CRX would work well for what I want.. I have an old Alpine tape deck, Fosgate amp and Vaurnet Decal in the back window.. I don't want to change a harness, I don't want to chip an ECU , or get an ostirch.
cheap cheap cheap...  cheap.
« Last Edit: May 23, 2014, 10:17:22 PM by Lowerit »
n/a mike
  • Mr. Hotpocket
Re: Cheap turbo - your roots
« Reply #1 on: May 23, 2014, 11:35:37 PM »
I don't feel like searching.
What engine do you have?
if you don't want to tune it then go with an fmu.
14b is a good sized small turbo, but I'm not sure about only 160hp
« Reply #2 on: May 24, 2014, 02:21:15 AM »
Afc, dsm 450s and a msd btm.
« Reply #3 on: May 24, 2014, 04:33:03 PM »
Rhb5 no intercooler map bypass and a sk2 na chip that was my first set up ran great
« Reply #4 on: May 24, 2014, 10:11:59 PM »
I dont understand not tuning it. it could be much better tuned than not
« Reply #5 on: May 24, 2014, 10:24:06 PM »
Im lazy
« Reply #6 on: May 24, 2014, 10:35:37 PM »
couple check valves, fmu, and a btm dialed back a degree or so isnt tuned?  :o
« Reply #7 on: May 24, 2014, 10:37:43 PM »
ps:  i vote IHI RHB5 also. plus whatever intercooler fits, if none fit, perfect too.
Sedrostyle
  • Turbine Noob
« Reply #8 on: May 25, 2014, 02:52:32 AM »
I'd go t28 or t25 whatever it is. Seems like its easier to find manifold adaptors for.
HF manifold everyone else stated the rest.
I have a integra ecu if you wanna buy it.
« Reply #9 on: May 25, 2014, 10:32:02 AM »
I like blown up shit
FIFY
« Reply #10 on: May 25, 2014, 11:14:30 PM »
Is it mpfi or dpfi?  Supposedly, in the mid/late 90's, Stephan Papadakis ran 11's w/dpfi, I've been wondering how.  I think he used a much larger side feed injector for the secondary.  Sized a turbo to match so it would light when the secondary opened.  Then it would be fish store check valves on the map sensor n something to retard timing in relation to boost...
« Reply #11 on: May 25, 2014, 11:16:11 PM »
its a 87 CRX Si...  ::)
« Reply #12 on: May 25, 2014, 11:18:25 PM »
nevermind then...
« Reply #13 on: May 27, 2014, 03:09:00 PM »
Considering the fact that he knows multiple people that will properly tune it for free, that method makes no sense to me.
n/a mike
  • Mr. Hotpocket
« Reply #14 on: May 27, 2014, 07:22:34 PM »
At minimum run a basemap "tune"
gonna buy an ecu anyway
« Reply #15 on: May 28, 2014, 10:07:52 PM »
post pics of your sisters ass.
I Will see you this fall Kneeee Grow
« Reply #16 on: May 28, 2014, 10:13:46 PM »
SWEEEEEEETTTT!!!! Bringing that pedophile asian boy lover?
« Reply #17 on: May 29, 2014, 02:37:32 PM »
Being an 87 makes it a bit harder. The irony is a FMU costs more than a set of DSM450's and a chipped obd0 ecu running turboedit or BRE. Even a basemap will run better & make much more power than an FMU.
« Reply #18 on: May 29, 2014, 05:25:04 PM »
I have an fmu and missing link if someone is shopping
Burntrubber87
« Reply #19 on: June 09, 2014, 08:06:39 AM »
Hobbs switches and Volvo cold start injectors.
Adjustable FPR for the csi fuel circuit, Bleed valves and like others a BTM for "finetuning"... nog.jpg
