Author Topic: 0.30mm decked piston?  (Read 37539 times)
walter
« on: June 10, 2015, 06:40:06 PM »
Hi, got a new Oem pistons, 81.5mm (+0.5mm), sent block to shop for overbore it, i see in the box show 0.30mm DECKED, what that means exactly? piston to wall clearance?
Re: 0.30mm decked piston?
« Reply #1 on: June 10, 2015, 08:13:54 PM »
Generally that means that they cut that much off the top of the block to square it up and make it flat. https://www.google.com/search?ie=UTF-8&client=ms-android-verizon&source=android-browser&q=decking.a+blocm&norc=1&zx=1433981591892#q=decking+a+engine+block
walter
« Reply #2 on: June 10, 2015, 08:23:51 PM »
that means pistons are 0.30mm shorter? :?: i know what means deck a block, but what i dont understand is what exactly means "0.30mm DECKED" writed in the pistons box.
« Reply #3 on: June 10, 2015, 09:00:04 PM »
You'd have to talk to the machinist. Nothing should be in the 0.3mm range for those pistons - piston to wall, piston to deck, etc. 0.3mm is ~0.011", which can be needed on some warped blocks.
