Author Topic: Digi-Key Part #'s 4Bar MAP Sensors  (Read 70074 times)
« on: March 08, 2009, 11:05:57 PM »
Anyone know the Part #'s for the 3/4 Bar Map sensors on Digi-key?
« Last Edit: May 06, 2009, 09:23:12 PM by 88dx »
Re: Digi-Key Part #'s
« Reply #1 on: March 08, 2009, 11:31:56 PM »
thats what im looking for J/E wants Crack money for a gm 3bar
« Reply #4 on: March 09, 2009, 12:18:00 AM »
found this 3 bar
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail?name=MPXH6300AC6U-ND
The pic dosent show the Circuit board I wonder if you have to buy that separate?
« Reply #5 on: March 09, 2009, 12:39:41 AM »
the board is a xenocron part.... :-\
turbo4life
« Reply #6 on: March 09, 2009, 01:51:11 AM »
i got the part numbers for 2 bar and 2.5 bar and 3 and 4 bar map sensor holla nogs
End the fake food.
« Reply #7 on: March 09, 2009, 02:27:25 AM »
Just post them up nagger.
Would be awesome if they were doing the free map sensors from freescale again.  :noel:
« Reply #8 on: March 09, 2009, 02:28:04 AM »
post them up
« Reply #9 on: March 09, 2009, 02:38:21 AM »
yeah i doubt that will never happen again
« Reply #10 on: March 09, 2009, 08:58:36 AM »
Freescale (Motorola) no longer sends free samples of any chips to generic email addresses, unless you pay shipping which exceeds what the chips could be purchased for + shipped from Digikey.  I tried to get some 1815's the other day and was denied.  :(
« Reply #11 on: March 09, 2009, 10:06:44 AM »
JD what do you mean by Generic email addresses? If I send from my work email would they?
« Reply #13 on: March 10, 2009, 03:54:43 AM »
I'm going to free you nogs from Xeno-domination of the Freescale (not motorola, n00bs) MAP sensors. I'll try to post a new DIY to make your own MAP using the stock housing. I already have five special edition PINK omni 4bars, so I'll probably make a 3bar. Madmax did the original write-up, but the pics weren't all that great. Anyways, here's the google cache on it. If it doesnt' work, google "madmax motorola sensor" and click "cached" right below the URL.
http://209.85.173.132/search?q=cache:ZY9NJ4evngYJ:www.homemadeturbo.com/forum/index.php%3Ftopic%3D74311.msg879279+madmax+motorola+sensor&hl=en&ct=clnk&cd=1&gl=us
turbo4life
« Reply #14 on: March 10, 2009, 02:42:41 PM »
ya already beat me to it
mpx4250ap  is the 2.5 bar    $12.7
mpx2200gp   is the 2.0 bar   $9
End the fake food.
« Reply #15 on: March 11, 2009, 04:04:51 AM »
mpx2200gp Is a GAUGE sensor. Gauge reads the difference between the port and normal atmosphere. Differential is the difference between the 2 ports. Everything besides ABSOLUTE is useless.
BTW search digikey for "freescale", select "Pressure" under "Sensors, Transducers" section, select "absolute" & filter, then select all voltages besides the 0-40mV. Subtract ~14.5 psi from the max pressure and that's your boy.
« Reply #16 on: March 11, 2009, 10:03:03 AM »
gmail, hotmail, yahoo.  I bet an .edu address would work, so should your company.
Good tech, you n00bs better eat this shit up.
« Reply #17 on: March 11, 2009, 12:56:18 PM »
i've got a .edu email thats worked for national semiconductor before.  freescale dont' have shit that we can use for free samples that i've found
« Reply #18 on: March 11, 2009, 03:56:48 PM »
Freescale is what became of Motorola's IC and component branch, there's quite a bit of logic/MCU I'd like from them.
« Reply #19 on: March 11, 2009, 04:31:19 PM »
let me know if theres a sample you want me to try to get, maybe we can work a trade out for those shift forks
« Reply #20 on: March 13, 2009, 02:01:37 AM »
They still offer the g-sensors last time I looked. I've already tried one on my SSI-4: give it voltage, ground, and read the output. They are instant response, and only need the extra resistors/capacitors if you want an ultra-clean output. They're the cheapest g-sensors you'll ever find (~$15 IIRC), if you can't get samples at least. :somb:
As for the MAP sensors, they range from $11-16, and usually $6 for shipping. I should have my DIY MAP Sensor write-up posted soon, so you can have a bolt-on 4bar MAP for a FRACTION of the cost of an Omni/Hondata 4bar.
J. Mills
  • Not a fuckin noob
« Reply #22 on: March 15, 2009, 04:48:48 PM »
you should post 28pin sockets as well....
Zeniceguycrx
« Reply #23 on: March 15, 2009, 05:58:47 PM »
They want deposit money now, I tried to start it again but orig
 xeno crushed us
The 30psi king of rice
Re: Digi-Key Part #'s 4Bar MAP Sensors
« Reply #24 on: May 06, 2009, 09:26:21 PM »
OK so this is the 4bar I ordered.
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=MPXH6300AC6U-ND
When you check out make sure you use USPS as shipping, because it is way cheaper.
And here is the spec sheet:
http://www.freescale.com/files/sensors/doc/data_sheet/MPXH6400A.pdf
BoostForLife
« Reply #25 on: May 07, 2009, 01:58:49 AM »
That's the correct sensor. I just did this about a month ago, worked perfect.
Practice soldering very small fucking shit before attempting to put this in.
Your car will need a retune completely.
« Reply #26 on: May 07, 2009, 02:31:21 AM »
I love 4 bar sensors.
« Reply #27 on: May 07, 2009, 11:49:29 PM »
caged
« Reply #28 on: May 08, 2009, 05:49:27 AM »
So would these 3 bar sensors be a cheap substitute for a GM 3 bar sensor for a Haltech? or will that not work?
walter
« Reply #29 on: May 08, 2009, 11:59:21 AM »
do u have any how-to for wire to stock one?
