Author Topic: holset silencer ring  (Read 15787 times)
Atticus
« on: June 10, 2009, 02:57:22 AM »
other then noise do these make a difference?
rebuild manual says it makes no difference in cfm (any one confirm this?)
also how loud can it get on a D ?
BoostForLife
Re: holset silencer ring
« Reply #1 on: June 10, 2009, 03:00:18 AM »
makes no difference at all, just spools louder.
Took mine off the HX35 the moment it arrived in a package.
Take it off, the only reason it's there in the first place is that diesels run huge amounts of boost and whistles loud as fuck, dodge got complaint for loud noise and these were put in to quite it down. Didn't affect or improve anythign other than the noise level.
« Reply #2 on: June 10, 2009, 09:39:24 AM »
They sound sick with them off :noel:
« Reply #3 on: June 10, 2009, 10:11:05 AM »
Take it off. You will thank us.
« Reply #4 on: June 10, 2009, 10:36:16 AM »
Holset's with silencer rings are only found in passenger vehicle applications. 95% of the industrial equipment I have come across does not have a silencer ring. There is absolutely no difference either way, other then the sound. On a gasoline engine where you don't here the turbo when cruising I like the ring out, on a Diesel where you do hear it cruising it gets tiresome pretty quick.
BoostForLife
« Reply #5 on: June 11, 2009, 03:16:35 AM »
You haven't seen a daewoo power diesel generators, have you. Kind of rare, but I have an HX35G from one. Had the ring which I took out, and it IS also water-cooled, bitches. Sounds fucking sweet!
caged
« Reply #6 on: June 11, 2009, 03:29:13 AM »
I took mine out as soon as it arived also, havnt got the car running yet tho. ;)
Rob.K
« Reply #7 on: June 11, 2009, 03:32:29 AM »
When i take them off the cummins deisels at work it's fucking loud, 30psi+ and they fucking hum. I get erections from it, is that bad?
3tc, tin can, holset, trailor wheels
« Reply #8 on: June 11, 2009, 06:02:52 AM »
nope
« Reply #9 on: June 11, 2009, 10:33:15 AM »
my brand new hx35 came without one still in the cummins box
caged
« Reply #10 on: June 12, 2009, 02:54:28 AM »
Are you shore its genuine? The copies dont seem to have them :?:
« Reply #11 on: June 12, 2009, 12:59:12 PM »
I have bought them from Cummins western Canada, just like that. Like I said lots of industrial applications come with out them.
