Author Topic: getting car to idle with 3 wire IAC, drill TB blade??  (Read 10945 times)
bouncinofftherevlimiter
« on: June 24, 2009, 07:22:41 PM »
the intake on my car is off a F20B, (from accord sir-t) and it has a 3 wire IAC. i cant seem to find any way to make it work with OBD1 and crome. right now im just using throttle cable tension and i hate how it is unreliable, it is all over the place and you constantly have to slap the pedal coming up to a light or any sort of stop so it dosent idle at 2500...
i remember an old trick from the domestic days was to drill a small hole in the primary blades of the holley carbs to help big cam cars idle. should i try that or is it going to cause problems? dont know how it will but just thought i would ask. i think im still going to have to use cable tension, but i thought maybe this would make it better.
No longer own a turbo car...
HX35 18lb 486hp/391tq
Re: getting car to idle with 3 wire IAC, drill TB blade??
« Reply #1 on: June 24, 2009, 07:58:58 PM »
Just disconect it, adjust your idle screw and adjust your throttlestop and call it a day.
« Reply #2 on: June 24, 2009, 10:14:22 PM »
Numerous companies make a flange so you can add a 2 wire iacv to that manifold
« Reply #3 on: June 24, 2009, 10:25:50 PM »
i searched all over with no avail.
if you could please send me a link i will appreciate it
thank you very much
« Reply #4 on: July 06, 2009, 06:26:19 PM »
locashracing.com
