Author Topic: Does anyone have a DIY for a resistor box.  (Read 58418 times)
AstroVannin
« on: March 11, 2009, 02:51:06 PM »
Just somthing I thought would be helpfull to have in here.
I got the basics via PM, but for anyone else that comes in new, it might be nice to have.
Annihilator
Re: Does anyone have a DIY for a resistor box.
« Reply #1 on: March 11, 2009, 03:51:24 PM »
See I was originally going to wire in an actual resistor box, but a lot of people do the inline resistor setup, so I'm probably going to go that route, just because it's cheaper, and IMO easier.
SDRAWKCAB
  • D series BALLA!
  • Rhino
« Reply #2 on: March 11, 2009, 03:53:37 PM »
(4) 7ohm, big wattage  resistors.
wire them inline on a common injector wire (ie 12v+ or gnd)
and done
FIXED
« Reply #3 on: March 11, 2009, 04:32:07 PM »
how is it cheaper and easier?  honest question I want your opinion.
If we're talking a honda, pop off the deadend plug and plug in a box off an accord.
Or if you have an obd0 box, cut off the plug and solder an obd1 dizzy plug on, then plug into the dead end plug.
cost me next to nothing to go either way with parts from a you pull it.
I personally try and NOT cut a stock wire on my harness at all costs, the fewer splices the fewer chances for future little gremlins to surface.
AstroVannin
« Reply #4 on: March 11, 2009, 05:25:13 PM »
SO, hang on a minute. The Accord (mines a 1991) already has a resistor box?
« Reply #5 on: March 11, 2009, 09:14:24 PM »
yeah it should
SDRAWKCAB
  • D series BALLA!
  • Rhino
« Reply #6 on: March 12, 2009, 03:32:57 AM »
and done
FIXED
2 ohm + 7 ohm = 9 ohm, not 12 ohm.
2ohm + 10 ohm = 12 ohm, that of high imp injectors.
you fail at math
How about I measured 3 resistor boxes that came out of hondas and they are all between 6.5 and 7.5 nig nog.
FUCK YOU!
BITCH!
« Reply #8 on: March 12, 2009, 10:46:49 AM »
90+ Accords are OBD1. It's the only Honda that obd1 started that early. And yes, All accords have resistor boxes arlready. It's that amp looking box on the drivers side shock tower.
Are you on cb7tuner.com?
AstroVannin
« Reply #9 on: March 12, 2009, 12:21:10 PM »
Yeah, Im on CB7tuner .... same name.
heres a pic of my bucket
« Reply #10 on: March 12, 2009, 01:27:54 PM »
that's an interesting roof rack.
AstroVannin
« Reply #11 on: March 12, 2009, 01:36:42 PM »
The new one is nicer ..... Ploished, with hardwood slwats for the bottom.
« Reply #12 on: March 13, 2009, 01:53:43 AM »
I helped a friend do this recently, he was on a shoe-string budget and short on time. He picked up four 10ohm, 15watt white ceramic resistors - wattage can be higher but not lower. Once we figured out the injectors were clogged ( :-X), it fired right up. 2k miles later no issues.
1) cut the yellow/black wires for all injectors (one each, nog!). He did it right at the fuel rail, but anywhere before the deadend connector works
2) solder a resistor into each spot you cut - doesn't matter which direction, just don't mix the wires up.
3) Grind out mini-tab inside the connector on each injector for obd1 honda connectors, they usually have one. Install injectors.
4) start car up with basemap, adjust load cells or dead time corrections if you have them (like in eCtune)
5) have a beer...or start with turbo kit install. :noel:
snarf
« Reply #13 on: March 19, 2009, 08:04:07 PM »
« Reply #14 on: March 22, 2009, 08:20:04 PM »
i use 10 watt 10 ohm inline resistors with zero issues :)
MADMAX
« Reply #15 on: March 25, 2009, 01:55:42 AM »
All you are doing is making the injector open slower and not capable of supporting higher fuel pressures.
« Reply #16 on: March 25, 2009, 04:25:05 PM »
It all depends on which injector he is using.
http://injector-rehab.com/kbse/resistor.htm
« Reply #17 on: March 25, 2009, 06:45:22 PM »
Same here.
MADMAX
« Reply #18 on: March 26, 2009, 01:37:44 AM »
No shit Sherlock. But chances are, they aren't 2 ohms.
clwtwizted
  • Fuck You!!!
« Reply #19 on: March 28, 2009, 09:43:56 PM »
Maby he meant harness not ecu. Thats the way I did my resistor box
