Author Topic: Anyone have actual experience with walbro 190lph pumps  (Read 26120 times)
TTC
« on: September 11, 2009, 10:06:07 AM »
I put one in ages ago thinking no way i would need bigger. But im wondering if i need a 255 to hit 300whp.
16v 4age, 550cc, small 16g
Re: Anyone have actual experience with walbro 190lph pumps
« Reply #1 on: September 11, 2009, 10:22:25 AM »
I would use the 255 just for the insurance.
But I also look at cheapest route first. ;D
jarebear667
« Reply #2 on: September 11, 2009, 11:00:59 AM »
use an evo 8 pump.
midwest HMT!
« Reply #3 on: September 11, 2009, 02:02:08 PM »
use an evo 8 pump.
Those are only rated at 160, despite what the internet would have you believe.  That being said, evo's make 300+ on stock pumps all the time.
190 is plenty for your application. Change your fuel filter, and watch your afr's.  If you are running out of fuel, you will know.
« Reply #4 on: September 11, 2009, 02:50:19 PM »
In the same subject, what is the rate of honda gas pump?
TTC
« Reply #5 on: September 11, 2009, 04:12:19 PM »
use an evo 8 pump.
That is pretty much what i figured, thx Rob.  If i add fuel and it doesnt richen then i need a bigger pump.
« Reply #6 on: September 11, 2009, 04:14:33 PM »
miata people use 190HP walbro pumps all the time for 300whp. 255 is kinda overkill, and supposedly at higher pressures and lower volume rates, the 190hp is actually the better pump.
« Reply #7 on: September 11, 2009, 10:07:57 PM »
255 is a 650+ whp pump.  What's 74.5% of 650+?
If you run 12 gauge power and ground to the factory pump, 325 whp Mustang/375 whp Dynojet.  Honda-Tech will tell you "300 whp" or "impossible"
« Reply #8 on: September 11, 2009, 11:18:50 PM »
484.2500000000000
« Reply #9 on: September 12, 2009, 01:14:44 AM »
Good to know. I don't think I make more than 250whp
caged
« Reply #10 on: September 12, 2009, 04:39:48 AM »
There are lots of CDM 190lph pumps out there which iv seen a few problems, I run a genuine 190lph walbro and im around 300rwhp.
« Reply #11 on: September 12, 2009, 10:09:19 AM »
Seems like the CDM pumps are hit and miss.  Ive ran them in my last 3 builds with no problems.
caged
« Reply #12 on: September 12, 2009, 04:47:17 PM »
That pretty much sums up CDM parts, hit and miss lol
« Reply #13 on: September 12, 2009, 05:05:30 PM »
I was gonna say the same thing, blanket statement right there.
« Reply #14 on: September 12, 2009, 05:49:17 PM »
I've never seen or heard of a problem with the CDM 255's.  Which are what most people who think they have Walbros actually have.
caged
« Reply #15 on: September 13, 2009, 05:58:25 AM »
1st one stripped the plastic gears and the second one just went dead. mabey its cause im on the other side of the equator, water swirls in the opposite direction apparantly :yes:
