Author Topic: Cheap water/meth pumps?  (Read 10999 times)
Minor Threat
« on: September 30, 2009, 10:49:10 PM »
Do I really need to spend 120 dollars on a 150psi pump for my meth kit?
Re: Cheap water/meth pumps?
« Reply #1 on: September 30, 2009, 10:51:14 PM »
Best price ive found on Meth was down on Railroad Ave.  :mexi:
Minor Threat
« Reply #2 on: October 01, 2009, 12:11:40 AM »
« Reply #3 on: October 01, 2009, 06:01:31 AM »
/thread jack/
for that matter, where is a good price for an external electric oil pump??
« Reply #4 on: October 01, 2009, 09:03:24 AM »
They have 150psi pumps here in canaduh at Princess auto for $55 , plus that great PA warranty that lasts FOREVER!!!
Minor Threat
« Reply #5 on: October 01, 2009, 01:03:48 PM »
Show me! I'm gonna check their website right now.
Minor Threat
« Reply #6 on: October 01, 2009, 02:25:42 PM »
Can't find any 150psi pumps on PA website, only 100$ "pony" pumps.
« Reply #7 on: October 01, 2009, 03:15:13 PM »
for external oil pumps, I would either run a shurflo 8000 (they are like $90), or modify the oil pump from a SBC to run off an electric motor.  Did a good bit of research on these when I was planning out a remote turbo setup.
« Reply #8 on: October 01, 2009, 03:26:35 PM »
My friend is a manager of the one near T.O ..i will ask him he is running one on a 5.0L
« Reply #9 on: October 01, 2009, 03:50:46 PM »
That seems like it would be a fair bit of work.  Access to a machine shop would be vital I would think.
Minor Threat
« Reply #10 on: October 01, 2009, 05:19:47 PM »
Sweet, lemme know. I know they occasionally have shurflo stuff in the store, but nothing is listed on their site.
SgtB
« Reply #11 on: October 01, 2009, 06:11:36 PM »
Shurflo. do you really need 150psi? The 100psi pumps are $55, and the 150s go for $130+. get a sureflo accumulator too. it keeps everything nice and consistent as the pressure switch on those things makes it jerky as shit. GPM would be the best way to pick the right pump.
« Last Edit: October 01, 2009, 06:14:03 PM by SgtB »
Minor Threat
« Reply #12 on: October 01, 2009, 06:27:07 PM »
Where are the 55 dollar 100 psi pumps? Need low volume for meth, high pressure to get decent atomization.
« Reply #13 on: October 02, 2009, 01:47:22 AM »
You'd be surprised:  http://www.jalopyjournal.com/forum/showthread.php?t=297383
« Reply #14 on: October 02, 2009, 02:48:10 AM »
thats dope
« Reply #15 on: October 02, 2009, 07:04:24 PM »
Lol.  God ole J.B. Weld.  Good idea, although I probably would have gone about it a little differently.
« Reply #16 on: October 02, 2009, 07:23:55 PM »
that diy oil pump is awesome.
caged
« Reply #17 on: October 02, 2009, 09:59:36 PM »
Dry sump here i come O0
« Reply #18 on: October 02, 2009, 10:31:07 PM »
I''m going to be running a DIY oil pump on my rear mount turbo setup (when I get to fucking work on it) for oil scavenging/return.  The best part is that it cost me all of $30.  Shitload of JB weld, some pipe I found in the garage, and a brand new sbc oil pump from advance autoparts.  Spun by an 18V cordless drill with a crap battery that we were going to toss.
My oil lines are going to cost about as much as the pump.
« Reply #19 on: October 03, 2009, 08:03:52 AM »
usually electrical, atleast in short duration.   you can get a used NASCAR rear end pump cheap on egay, it should have more than enough volume for a 4cyl
« Reply #21 on: October 03, 2009, 04:16:09 PM »
Why not take off of the accessory pulley?  Is the electric motor really a better option?  Mechanical load vs electrical load which is more efficient?
Pump's gotta be in the back, or at least that's how it seems.  It also needs to be able to drain the oil lines after I shut off the engine.
« Reply #22 on: October 03, 2009, 09:46:48 PM »
Said oil pump:
Just needs a skim coat of rtv between the layers and its all good, pump gears are like new inside.
