Author Topic: home depot B series valve spring compressor  (Read 48220 times)
dueyx99
« on: October 24, 2009, 07:58:46 AM »
somethin we rigged up today to yank the valve springs from a gsr head, only to find out why no matter how many valve adjustments it had, it would still tick, springs are from exhaust side. valves are also hammered to death on the stem tips. compressor was made with flat bar and bar stock from home depot
By duanefab2 at 2009-10-24
demonboy
Re: home depot B series valve spring compressor
« Reply #1 on: October 24, 2009, 11:12:21 AM »
Nice, I gotta make one.
« Reply #2 on: October 24, 2009, 11:42:42 AM »
Another image you stole from someone else?  :-X
« Reply #3 on: October 24, 2009, 04:04:28 PM »
how the hell did you break 3 springs? thats odd, ive never seen that happen to a b series before.
walter
« Reply #4 on: October 24, 2009, 07:29:57 PM »
nice!
i use this one..
hatchbox90
    • Dream Builders Homes
« Reply #5 on: October 25, 2009, 11:33:10 AM »
« Reply #6 on: October 25, 2009, 01:19:36 PM »
I use this
http://www.euroexportinc.com/product_info.php?cPath=28204&products_id=44427
Valve Spring Compressor Tool by EuroExports
Works fucking awesome and takes about 5 minutes to do all of them
yeah but it doesn't work on dohc zc motors or single cams. using a socket and extension works on all motors.
and you want to explain how you can put them back together with a socket?
hatchbox90
« Reply #7 on: October 25, 2009, 02:43:39 PM »
I use this
Try working on a bseries vtec motor.. There is no room for anything, getting them out is easy, i used a socket and a hammer to punch loose the keepers, but putting the retainers back in is the tricky part.  you cna buy the honda tool for xxxxxx amount of money, or use this bad ass tool which took me about shit for time to install ALL my retainer.
I used the sears spring compressor and i spent about an hour grinding off parts that were hitting the head or wouldnt let it fit. Then i spent 2 hours getting ONE fucking spring/retainer back on the head.  Ordered this thing and had it done in less than 10 minutes and didnt break any spring doing so  :?:
plus its anodized and looks pimp.
rudebwoy
  • tripple OG
« Reply #8 on: October 25, 2009, 05:28:24 PM »
or try and use that lever type on the head with it out of the car, I had to bolt the head to the work bench, but before that me and my friend stuggle to hold the head down, while installing crower dual springs and using the snap on one.
after seeing that video I am buying one, friend bought one on ebay for $25.
2000 civic SI daily driver
hatchbox90
« Reply #9 on: October 25, 2009, 08:00:25 PM »
Yea i knew i was going to need a valve spring compressor, I forgot how much of a pita b sereis vtec heads were, i got the craftsman compressor from sears(the small one) and it on fit in a few spots.  googled some stuff up and came across this.  Its damn near worth renting out to people.  saved hours of my time.  The kit even comes with the little flat head screwdriver with the magnetic end for the keepers
« Reply #10 on: October 25, 2009, 08:03:19 PM »
I use this
5 minutes?  you must have triple jointed spaghetti like fingers, but yes it does work well.  I bought the same one and it was well worth the ~60 I paid for it.  I think I have done about 5 sets of B VTAK sprin sets since then.
hatchbox90
« Reply #11 on: October 25, 2009, 08:10:57 PM »
I use this
felt like 5 minutes compared to my 2 hours for a single spring/retainer.
« Reply #12 on: October 25, 2009, 08:14:26 PM »
I use this
lol.
I did 1 set with a c clamp type compressor that I modified.  After that episode I wnet looking for a  better alternative.
« Reply #13 on: October 25, 2009, 09:05:25 PM »
i take one of the long nose vise-grips, clamp down on the edges of the retainer and then put a rag over the end and push down and get the collets out.
oh sometimes they fire off at the speed of sound so watch your eye(s), hotrex take notes.
« Reply #14 on: October 26, 2009, 11:41:40 AM »
I use this
damn that looks simple.
course i'll make one over spending the $65 though
« Reply #15 on: October 26, 2009, 02:31:27 PM »
I use this
zipties
doesnt't work so well for aftermarket springs. They do the job for weak sohc springs tho.
« Reply #16 on: October 26, 2009, 04:00:48 PM »
I use this
zipties
+1
The ziptie trick made me giggle when I first saw it.
« Reply #17 on: October 26, 2009, 04:25:16 PM »
Also when you remove springs I like to use white cardboard under the head so you dont lose any keepers those little bastards are impossible to find if you lose them. The white makes them stand out nicely. This is if your using socket/hammer method.
I use the snap on copy and it works fine takes some time to get use to it though. The one in the video looks too damn easy I may buy one.
« Reply #18 on: October 26, 2009, 05:17:48 PM »
They are fucking sweet, Chris.  Installation is tricky since the work area is so damn small, but that is the case with pretty much all methods methinks.
hatchbox90
« Reply #19 on: October 26, 2009, 06:37:02 PM »
agreed
Minor Threat
« Reply #20 on: October 26, 2009, 08:16:52 PM »
Mspaint?
« Reply #21 on: October 26, 2009, 08:23:50 PM »
Mspaint?
Keep the springs compressed with zipties while you install the keepers
Minor Threat
« Reply #22 on: October 26, 2009, 08:27:14 PM »
I can totally see that shooting retainer keepers into my eyeballs.
Minor Threat
« Reply #23 on: October 26, 2009, 08:52:21 PM »
I wish I had a head apart right now just to try it.
« Reply #24 on: October 26, 2009, 11:00:14 PM »
I would like to see someone try with dual valve springs with the zip trick
Its hella ghetto but if it does the job.
« Reply #25 on: October 27, 2009, 12:56:19 AM »
I'd just like to state for the record that, regardless of how well this thread has turned out, that the OP is a blazing faggot and unwanted on this site.
Thanks!
Random Hero
« Reply #26 on: October 27, 2009, 03:03:41 PM »
nice!
i use this one..
I use that one, while the heads on the car.
« Reply #27 on: October 28, 2009, 07:50:37 PM »
if i ever need one of those B series jobbers, im going to make one out of steel.
tap kit and drill for the win
« Reply #28 on: October 28, 2009, 09:10:26 PM »
There is no room for a steering wheel puller in the head  ???
« Reply #29 on: October 28, 2009, 09:40:47 PM »
Idon't think you have had your bear claws on a DOHC VTAK head before...
There really isn't much room to work let alone try to shove a tool in there.
