Author Topic: Project 11 second SI E85 rippers vids added  (Read 197819 times)
boosted 00 black si
« on: December 01, 2009, 07:09:40 PM »
shooting for 10's in the si for 2010 the 60-1 turbo took a shit on me so i got a killer deal on a holset turbo. i had to shave the head n the compressor housing a lil bit to get it to fit  :noel: so now all i got left to do is injectors, get rid of the aebs intake manifold n replace it with the edelbrock intake manifold n get the 74mm tb and a battery relocation in the trunk so i could fit my new catch can set up n get the car tuned on race gas on 30psi
motor
stock rebuilt head 3 angle valve type r valve tran job blah blah
b16a 81.5mm decked
probe forged piston n probe h beam rods
micro polished and balanced crank
all arp main, rod and head bolts
clinic 850cc injectors
aeromotive fpr
255 walbro pump
-6 fuel return line
earls inline fuel filter
gsr cam
aem gears
revhard intake manifold
70mm throttle body
moroso catch can set up
aem wideband
autometer oil n boost n volt
msd blah blah
b16 trans with ls final drive obx lsd
competion stage 5 clutch
turbo set up
top mount turbo manifold
holset hx35/wh1c ported the fuck out
tial 44mm wastegate
tial 50mm bov
big ass egay intercooler 2.5 ic piping all round
3 inch vband open downpipe  :noel:
x mbc
suspension
kyb agx struts
skunk 2 coilovers
19mm rear sway bar
black blox lower control arms
car made 385hp and 250 torque on 16psi on pump tuned by xeno
on old set up
old set up
holset turbo
port work done by eric
compressor housing
exhaust housing almost done
done
headlight cut out
oil feed set up
« Last Edit: April 14, 2012, 12:58:26 AM by boosted 00 black si »
go fuck your self
BORN TO BOOST
LITTLE B16.400whp on 16psi
Re: Project 10 second SI
« Reply #1 on: December 01, 2009, 07:15:59 PM »
Oil feed is baller :noel:
boosted 00 black si
« Reply #2 on: December 01, 2009, 07:18:58 PM »
thats right had to make it work cost 20 bucks to make  :noel:
go fuck your self
BORN TO BOOST
WOT
  • The Canadian
« Reply #3 on: December 01, 2009, 07:32:45 PM »
Yellow zip ties just make it that much better lol, who the fuck buys yellow zipties
boosted 00 black si
« Reply #4 on: December 01, 2009, 07:36:23 PM »
haha stop hating on my zip ties nig. 6 bucks at home depot for a shit load  :noel:
go fuck your self
BORN TO BOOST
« Reply #5 on: December 01, 2009, 07:46:45 PM »
Looks good, Im interested in how fast the spool up is.
boosted 00 black si
« Reply #6 on: December 01, 2009, 07:58:25 PM »
i do to thats why i did alot of port work to the turbo to hope it will help with flow and spool time i'm also rocking a 3 inch open dp  :noel:
« Last Edit: December 01, 2009, 08:04:25 PM by boosted 00 black si »
go fuck your self
BORN TO BOOST
« Reply #7 on: December 01, 2009, 09:07:33 PM »
i bet that sounds hot...neighbors love the dirty3rds ;D my neighbors like me but they trully love BDVT
« Reply #8 on: December 01, 2009, 09:26:07 PM »
Hi there  :noel:
h2a
« Reply #9 on: December 01, 2009, 10:34:31 PM »
Probe pistons, good piston for the b series lover on the cheap side. I mis the tuner toy rod.... :?:
boosted 00 black si
« Reply #10 on: December 01, 2009, 11:03:25 PM »
my neighbors are cool as fuck  :noel:
go fuck your self
BORN TO BOOST
boosted 00 black si
« Reply #11 on: December 01, 2009, 11:32:59 PM »
i've been running these pistons for three years now pretty dam strong i use to beat the shit out the car everyday..now since the trans took a shit me again i just took it off the road so im  just using the car for the track n sum $ runs now
go fuck your self
BORN TO BOOST
« Reply #12 on: December 02, 2009, 09:18:22 PM »
your timing belt told me to tell you to get the fuck away and fuck off.
please continue
« Reply #13 on: December 02, 2009, 09:50:23 PM »
I had almost the same setup, and let me tell you; as a street car, it fucking sucks.
mainly because when you're daily driving, there is no boost, unless you're careless of law enforcement.
when you're racing, it's fucking great, because the boost comes on hard and fast once you're in it.
I would put money on this setup making a lot less power before 5500 rpm, simply because you were running a T3 turbine side before. Less exhaust volume for less displacement is key, but since you're going race only this doesn't apply thanks to the anti-lag and the high revving aspect of the B16.
My next setup is going to be LS/VTEC at or under t3/t4 57 trim style  :noel:
boosted 00 black si
« Reply #14 on: December 03, 2009, 01:59:33 AM »
the car will be retuned on race gas. when i blow this slut up i'm going h2b  :noel: but right i'm trying to get this tranny shit out the way
go fuck your self
BORN TO BOOST
Pootie
« Reply #15 on: December 11, 2009, 09:35:26 PM »
looks goood!!
 lets get it done.. I don't see why this thing wont go 10's.!!
 see you in March!! :yes:
Tuned by you know who! ;-)
boosted 00 black si
« Reply #16 on: December 11, 2009, 11:02:35 PM »
thanx pootie i just fixed the trans n put it in on monday now i just got to get a set of injectors n get it retuned on 30psi  :noel:
whats up with the high compression set up?? i see alot of people doing this now
go fuck your self
BORN TO BOOST
boosted 00 black si
« Reply #17 on: December 16, 2009, 08:59:43 PM »
just picked up  a set of 880's injectors...evo 560's for sale check the for sale section
go fuck your self
BORN TO BOOST
« Reply #18 on: December 16, 2009, 09:01:10 PM »
I just ran another batch of 74mm throttle bodies on the lathe if your interested. Still have them on sale too
boosted 00 black si
« Reply #19 on: December 16, 2009, 09:04:29 PM »
i'll let u know how much to port a intake out????
« Last Edit: December 16, 2009, 09:06:10 PM by boosted 00 black si »
go fuck your self
BORN TO BOOST
« Reply #20 on: December 16, 2009, 09:17:33 PM »
which one?
boosted 00 black si
« Reply #21 on: December 16, 2009, 09:19:05 PM »
got a aebs type r style
go fuck your self
BORN TO BOOST
boosted 00 black si
Re: Project 10 second SI updated 1/10
« Reply #22 on: January 10, 2010, 02:19:40 AM »
iiiiiii
« Last Edit: June 09, 2010, 05:50:51 PM by boosted 00 black si »
go fuck your self
BORN TO BOOST
« Reply #23 on: January 10, 2010, 02:52:40 AM »
You Sir are a true baller :noel:
« Reply #24 on: January 10, 2010, 03:43:05 AM »
Also, nice parts.  What gauge wire are you gonna use for those dual walbrozzzzzz?
boosted 00 black si
« Reply #25 on: January 12, 2010, 09:40:30 AM »
hows the build coming along steve
go fuck your self
BORN TO BOOST
« Reply #26 on: January 12, 2010, 11:17:48 PM »
Need money lol. Might pick up a already built short block as a back up.
Re: Project 10 second SI updated 1/10 with full blown dual walbro set up
« Reply #27 on: January 12, 2010, 11:18:19 PM »
h series ftw
boosted 00 black si
« Reply #28 on: January 13, 2010, 01:32:01 AM »
when the b16 blows i'm going h2b for sure  :noel:
go fuck your self
BORN TO BOOST
boosted 00 black si
« Reply #29 on: January 23, 2010, 12:22:21 AM »
 ;D
« Last Edit: February 07, 2010, 07:04:16 PM by boosted 00 black si »
go fuck your self
BORN TO BOOST
Pages: [1] 2 3 ... 8   Go Up
