Author Topic: s2k equal length manifold setup  (Read 37894 times)
speedjunky01
Re: s2k equal length manifold setup
« Reply #30 on: October 02, 2009, 04:31:22 PM »
does the wrap really do that much harm to a manifold??
either way awesome work!
yes it does.  it holds the heat in and overheats the material to the point of structural failure.  ceramic coating will do the same thing if it is not coated inside and out.  corky bell talks about it in maximum boost.
yeah on a long hard drive i could see it doing that, makes sence metal over heats becomes brittle and cracks.
« Reply #31 on: October 03, 2009, 02:35:37 AM »
If you look up the phase chart for steels at various temps, even 1400F isn't nearly as bad as one might think. And that assumes that the r-value of the wrap is ideal, loosing zero heat to the outside. Stainless doesn't absorb heat as quickly as regular steel (~1/2), and you can't heat a container beyond the internal medium, at least not with the minimal friction air creates. The main problem is the heat causing it to loose it's ability to resist corrosion, but with turbo engines, you have practically zero reactive gas (mainly oxygen) left in the exhaust.
I've ran 2 manifolds using mild steel, cast steel, and cast iron with lots of heat wrap, and haven't had any cracking issues. And this is from me doing "sloppy" mig welds by not pre-heating the cast metals. The fact is that most people with such expensive manifolds won't drive their cars often enough to worry about heat. I'd guess that Corkey Bell was refering to all-out racing applications. Honestly though, Honda guys don't daily drive their 400whp vehicles as often as Evo owners.
Back on topic, manifold looks tits. You are definately the Tony1 of RHMT. :P
« Reply #32 on: October 03, 2009, 01:18:14 PM »
exact same scenario with mine, lol
D.Alomb
  • [url=http://tierussianwoman.w-ru.com/]largest dating sites[/url]
    • iwantu
« Reply #33 on: October 08, 2009, 03:18:31 AM »
Awesome pics.
One question about the intake manifold, are you worried about diff intake velocities between the two velocity stacks being the way the air enters the plenum?
latest dating site
« Reply #34 on: October 08, 2009, 04:01:03 AM »
did i miss something or did someone post an intake manifold?
« Reply #35 on: October 08, 2009, 05:59:35 AM »
That was on his post on Honduh Tek.
weirtech
    • Weir Technologies Inc.
« Reply #36 on: October 08, 2009, 08:51:26 AM »
actually, said manifold can be seen in my crx thread.
