Author Topic: Your sleeves...fuck 'em  (Read 59232 times)
« on: March 27, 2009, 05:31:11 PM »
fucking around last night, had a nice 6psi spike and lost power before i could let off. huge plume of smoke, smelled coolant. i prayed it was just a hg, but it just wasnt my luck.
car was tuned for 19-20psi, last boost readout on the Greddy Profec B 2 said just over 26psi  :noel:
Re: Your sleeves...fuck 'em
« Reply #1 on: March 27, 2009, 05:32:54 PM »
SOmeone say Spike???   :noel:
Shitty deal man
« Reply #2 on: March 27, 2009, 05:34:28 PM »
What motor is that a d-series or b-series?
Ouch  ;D :yes:
Shitty deal man
Or some serious detenation
MantisX
« Reply #3 on: March 27, 2009, 05:35:20 PM »
Damn that sucks. Now you and the mad scientist got to rip apart the block and replace the piston rings you fried.
When sleeves crack like that, they are still a candidate for resleeving right?
MantisX
« Reply #4 on: March 27, 2009, 05:35:53 PM »
d16a6, SRP 75.5mm slugs, TT i-beams
it was definitely a spike, which would have also led to detonation since i wasnt tuned that high and only have a 2.5bar map sensor
« Reply #5 on: March 27, 2009, 05:37:21 PM »
MantisX
Not if they go too far down...
« Reply #6 on: March 27, 2009, 05:51:25 PM »
Damn that sucks. Think it was detonation that killed it, or 26 was just too much?
« Reply #7 on: March 27, 2009, 05:55:09 PM »
psi is arbitrary
detonation fucks your world up
« Reply #8 on: March 27, 2009, 05:57:20 PM »
Thats good shit!   :yes:
« Reply #9 on: March 27, 2009, 05:59:27 PM »
psi is arbitrary
I know, that's why I asked.
I love my cast iron BP.  :yes:
« Reply #10 on: March 27, 2009, 06:02:45 PM »
either gonna be another no-tec 75.5mm SRP setup and re-use pistons, no-tec 75mm setup with another set of used SRPs i have, Vitara setup, or just say fuck it and get a sleeved block
gonna have to check the funds after i get my taxes O0
« Reply #11 on: March 27, 2009, 06:03:47 PM »
MantisX
I've seen people grind and weld the crack in preperation for a resleeve. so they could do that, maybe!!!
« Reply #12 on: March 27, 2009, 06:04:40 PM »
Sleeve the D!
« Reply #13 on: March 27, 2009, 06:06:05 PM »
Does your EMS not have overboost protection? That shit's saved my ass a few times.
« Reply #14 on: March 27, 2009, 06:14:04 PM »
MantisX
DFIINATELY not worth it. For the price of fixing it (or rather nigger rigging it), you could have a complete shortblock.
« Last Edit: March 27, 2009, 06:23:04 PM by bigdaddyvtec »
« Reply #15 on: March 27, 2009, 06:14:53 PM »
Damn man that is shitty. Hopefully you can resleeve.
« Reply #16 on: March 27, 2009, 06:16:57 PM »
ya, it was set for 21.5psi. probably happened too fast for the ecu to catch it. hell, i dunno
« Reply #17 on: March 27, 2009, 06:29:13 PM »
Guess time to start a d series cracked sleeve thread. How does the piston look like on that cylinder?
« Reply #18 on: March 27, 2009, 06:32:12 PM »
havent got it out yet
it looked fine the last time i cracked a sleeve  :P
« Reply #19 on: March 27, 2009, 06:37:08 PM »
Damn, that's weird. Run a dual port EWG with a MBC then. Or figure out what's up with overboost not working. My MS has some predictive feature to catch it if it sees boost climbing too fast and approaching overboost.
« Reply #20 on: March 27, 2009, 07:25:36 PM »
your boost spikes are my wg settings =p
good to see a shredded d though
« Reply #21 on: March 27, 2009, 08:24:50 PM »
Nice carnage. Well played.
« Reply #22 on: March 28, 2009, 03:14:04 AM »
did the tranny hold?
« Reply #23 on: March 28, 2009, 03:16:44 AM »
BONE I NEEDS YOUR HELPS
« Reply #24 on: March 28, 2009, 03:18:38 AM »
what did you fuck up this time??????
I don't play with H Fagoot trannys, that is Rob and Chubs job.
« Reply #25 on: March 28, 2009, 03:35:45 AM »
Nothing, actually its a D series
And I'm good with H's    trans wise for the moment
B's   mastered
« Reply #26 on: March 28, 2009, 07:14:18 AM »
Nothing, actually its only crabs
And I'm good with men,   trans wise for the moment
Actually transvestites have mastered my cornhole
TTC
« Reply #27 on: March 28, 2009, 09:57:11 AM »
psi is arbitrary
Ilove my cast iron 4ag :D
« Reply #28 on: March 28, 2009, 10:07:16 AM »
lol, trans held just fine  8)
« Reply #29 on: March 28, 2009, 11:58:12 AM »
I say just do a vitara, cant be cheap and big power on pump. Friend of mine drives his at 450+ on pump 93 and its his DD.
