Author Topic: New problems.. Aight im only boosting 5psi max. Damn Diaphragm  (Read 160802 times)
Nigga Edit : I think the diaphragm is fucked in the wastegate.  Checking that shit out tomorrow.  Wont go past 5psi, even with the hose unhooked off of the cdm wastegate.  Last time i ran just off of the spring, it was a 14psi.  Opening up wastegate tomorrow!!!
as most of you know.  i put i new b20 in the teg....
im fired up to start it..
crank.... idle...die...code 7
i swapped throttle bodies with a good one that i had laying around.  same shit..
checked grounds and its all good....
i cant find the way to trace back tps wiring and im too lazy to spend time searching.
help a nigga out
« Last Edit: March 21, 2009, 02:43:43 AM by ApexSilver06MR »
Re: cock sucking code 7
« Reply #1 on: March 07, 2009, 06:12:41 PM »
shit...  checked voltage at tps and ecu.  its all good
« Reply #2 on: March 07, 2009, 06:17:27 PM »
Unplug the tps all together and start the car. See it the car reacts differently.
« Reply #3 on: March 07, 2009, 06:18:24 PM »
tps and map plugs switched?
« Reply #4 on: March 07, 2009, 06:37:05 PM »
probably a 90% chance of that being the case.
« Reply #5 on: March 07, 2009, 06:43:01 PM »
cant be.  map is on the driver side with the tps on the pass side
« Reply #6 on: March 07, 2009, 06:47:36 PM »
He has 1990 integra aka map sensor is a vacuum line and the sensor is on the fiewall no reason to unclip the map on the firewall during engine removal
Unplug the tps and see how the car runs
« Reply #7 on: March 07, 2009, 06:52:39 PM »
same shit
« Reply #8 on: March 07, 2009, 06:53:27 PM »
I didnt know what year, but dose he have a later model tb with the map on it maybe?
« Reply #9 on: March 07, 2009, 06:54:22 PM »
90 obd0
map on firewall
« Reply #10 on: March 07, 2009, 06:56:11 PM »
ok, well im pretty sure that that is probably not your problem then
« Reply #11 on: March 07, 2009, 06:59:14 PM »
ok
well i hooked up the battery charger to give it a jump.  The fuckin gauges went crazy and shit....   wtf is going on here.  ive fucked checked everything like 10x
« Reply #12 on: March 07, 2009, 06:59:45 PM »
Thermostat ground
« Reply #13 on: March 07, 2009, 07:00:41 PM »
Thermostat ground
already checked and tightened over and over and over again
« Reply #14 on: March 07, 2009, 07:05:48 PM »
alternator ground
« Reply #15 on: March 07, 2009, 07:07:27 PM »
^^^  what alternator ground?????
« Reply #16 on: March 07, 2009, 07:23:58 PM »
Im a dumby the power wire held by 10mm bolt.
« Reply #17 on: March 07, 2009, 07:30:07 PM »
thats a power wire nog....
i finally got to prove chris wrong..   on the phone at that..   damn im a fucking gangster
« Reply #18 on: March 07, 2009, 07:51:22 PM »
alright.  took off of map sensor hose.  let me remind you that this is a motorola 2.5bar map....
it idles...  what the fuck is this going on.  i put it back on and im back to square one......
« Reply #19 on: March 07, 2009, 07:52:37 PM »
Those have a history of having problems
« Reply #20 on: March 07, 2009, 08:38:20 PM »
going to see peter [turbo4life] getting a chip burned for a stock map sensor
« Reply #21 on: March 07, 2009, 10:13:39 PM »
pay him in vodka
« Reply #22 on: March 07, 2009, 10:15:28 PM »
describe "crazy and shit"
« Reply #23 on: March 08, 2009, 12:48:58 AM »
tightening a ground DOES NOT magically make a dirty ground get cleared up. you only run the risk of damaging your threads.
take it off, get some 320gr sandpaper, clean the shit up and give a LIGHT LIGHT LIGHT coating on dielectric (silicone grease basically)
i was saying that just to state that i checked everything 10x.
its a map sensor problem
« Reply #24 on: March 08, 2009, 08:12:59 PM »
new chip burned for stock map sensor....  here we go!
« Reply #25 on: March 08, 2009, 09:54:51 PM »
aight....  fuck....  same fuckin shit...
it seems like that something is cutting back the spark when i give it gas
turbo4life
« Reply #26 on: March 09, 2009, 03:31:05 AM »
pay him in vodka
i perfer cash as i can get vodka free thanks for the comment cris you nigga/
JAY shit not running dam i have to take a look at it!!
End the fake food.
turbo4life
« Reply #27 on: March 09, 2009, 03:35:32 AM »
jay take a vohm meter and  check to make sure the wires to the tps are all not broken and have a connection.. ya know. then maybe swap a tb or tps i have a extra da throttle if you need and a spare tps somwehere
End the fake food.
« Reply #28 on: March 09, 2009, 03:36:58 AM »
i already ruled that shit out.  replaced throttle body..  same shit...
checked tps voltage at tps and at the ecu.  everything checks out.  main relay????
« Reply #29 on: March 09, 2009, 06:38:11 PM »
dizzy???
Pages: [1] 2 3 ... 5   Go Up
