How long before it blows up?
First start
- 12 (8.5%)
2 weeks
- 4 (2.8%)
1 month
- 7 (5%)
6 months
- 2 (1.4%)
1 year
- 4 (2.8%)
never
- 7 (5%)
motor already blew up, before being assembled
- 18 (12.8%)
CRX
- 28 (19.9%)
HHH
- 24 (17%)
JDSAP
- 16 (11.3%)
T2BSAP
- 13 (9.2%)
Fuck people who say "Fuck the French" but live with them?
- 6 (4.3%)
Total Members Voted: 49
Pages: 1 ... 4 5 [6] 7   Go Down
Author Topic: Integra 92 b18A1 turbo build holy fucking huge pics  (Read 151390 times)
Re: Integra 92 b18A1 turbo build holy fucking huge pics
« Reply #150 on: September 13, 2010, 04:27:04 AM »
Fuck you bitchez it's running, but no boost for now because of the ECU. Anyway, I'm still in break in...  O0
The first video is the second startup. I  almost got asphyxiated so it's very short.
Built Integra second startup
This one is longer, but poor quality. I let off the gas cause I heard a bolt falling on the exhaust. I thought is was a downpipe bolt cause it happen to me few months ago, but finally it was a dizzy bolt. I knew it cause the engine shut off on the highway when I got my girlfriend for a ride. The distributor pop out of his hole and only 1 bolt was still there. I guess I forgot to tight those... At least I had vise grip with me. Let me tell you that when the engine shut off I was fucking scared and the first thing I did was look bellow the car to see if oil was falling lol That's a stupid error, but I did more stupid than that in that build...
Integra first pull built motor
« Reply #151 on: September 13, 2010, 01:13:06 PM »
Whats up with the CEL?
« Reply #152 on: September 13, 2010, 08:22:35 PM »
I'm not sure if the code is 4 or 14. I really doubt it's 4 (crank sensor) cause the car is running fine.
Code 14 is IACV and the idle jump sometime so I think it's that shit. I really need to fix the ECU, I need boost.
« Reply #153 on: September 13, 2010, 08:33:44 PM »
The clutch is hard to deal with in parallel parking. It hooks up hard!  ;D
« Reply #154 on: September 13, 2010, 09:48:04 PM »
Thats cause its the shit.....
« Reply #155 on: September 15, 2010, 10:55:18 AM »
Whats left to do?   ???
Whats the hold up?  Where are the ripper vids?
« Reply #156 on: September 15, 2010, 11:07:40 AM »
I couldn't wait to take a ride with it so the alignment is fucking offset. Wheels are straight, but the tie rod hit my wheel if I turn too much to the left. lol
So I need to fix this. And the computer problem, I'll retry maybe today. It was working 2 weeks ago, I don't understand why it won't now.
I need to put new bolts on the dizzy since 2 are missing.
I'm waiting for boost to make ripper vid. N/A is fucking slow! Can't wait to test this clutch at his full potential  :evil:
I drive it everyday to the subway station. As said before, no problem with it other than parallel parking being a bitch because of the clutch and worse alignment ever done to a car lol
« Reply #157 on: September 15, 2010, 11:48:53 AM »
Look at my ghetto fab abilities. Unhooked coupler are wanted, not forgotten.
BEST POWER STEERING BRACKET EVER! Yeah, it's a zip tie and a random bolt with no nut at the other end.
« Reply #158 on: September 15, 2010, 11:53:56 AM »
Btw, the power steering bracket is like that because the crank pulley I used is from 94+ integra and it is smaller than the 92 one. It's not even the good belt. Vbelt on flat (??) pulley... Works fine when moving but stopped it's a bit erratic.
« Reply #159 on: September 15, 2010, 12:53:58 PM »
Where the fuck have I been? I didn't even know you blew your shit up.. Damn... At least its coming together nicely.
« Reply #160 on: September 15, 2010, 03:58:35 PM »
hehe
There's not a lot of contribution from other members in my thread. I guess everything is perfect  :mexi:
The clutch feel way better now. Maybe it was just because the clutch was new.
« Reply #161 on: September 17, 2010, 11:34:26 AM »
I think my Ostrich doesn't work correctly. Tried with a new ECU and still doesn't work...
Maybe it's just the cable tho because I'm able to Get the map from the Ostrich from previous upload.
I think I'm blowing up the turbo seal by not connecting the turbo to the charge pipe, it started to smoke badly yesterday after a long drive. I knew it, but I'm impatient and wanted to drive it.
Maybe it's time for a Demon?
« Reply #162 on: September 17, 2010, 11:49:10 AM »
Word. Bluetooth for the fucking win
« Reply #163 on: September 17, 2010, 12:31:41 PM »
Man your a dumb ass! You should have just thrown your stock header on and rocked it na for a few untill you seated your rings. Or had it all done and then driven it!
« Reply #164 on: September 17, 2010, 12:49:25 PM »
You may have done far worse then that, as you most likely over-sped it...
« Reply #165 on: September 17, 2010, 12:53:29 PM »
Shakes head.    :P
« Reply #166 on: September 17, 2010, 01:19:05 PM »
I don't have any headers and don't plan to buy one. Anyway, I notice the ECU wasn't working after everything was installed, I wasn't going to remove everything. I ran without wastegate for about a year, this turbo have seen worse than that lol
Just tried something else with the Ostrich and still not working.  I really don't understand what happened 2 weeks ago causing it to not work now....
« Reply #167 on: September 17, 2010, 03:58:57 PM »
Are all your pins making contact on your socket? Or do you have a zif installed?
« Reply #168 on: September 17, 2010, 04:52:03 PM »
Yes, it's a zif and the new ECU it's a socket. I pressed firmly on it with both ECU, but without success  :-\
« Reply #169 on: September 17, 2010, 05:37:22 PM »
All the pins making contact? If you burn the same tune onto a chip does it still fuck up?
« Reply #170 on: September 17, 2010, 09:03:04 PM »
Sadly I don't have a burner... Anyway it's eCtune and can't burn it.
« Reply #171 on: September 18, 2010, 12:14:17 AM »
Crome free FTW!!
« Reply #172 on: September 18, 2010, 09:43:24 AM »
I'll take a look at local electronic store to see if they have a cheap burner
« Reply #173 on: September 18, 2010, 11:40:36 AM »
www.mcumall.com
I think they are located in Poutineland.
« Reply #174 on: September 19, 2010, 04:08:32 AM »
Thanks JD, but fuck that. I just ordered a Ostrich 2. Don't feel to pay 300$ because I don't make a lot of money right now.
I'm sure it's the cable anyway. I just need to wait a week before I get it  :-\
« Reply #175 on: September 19, 2010, 10:34:05 AM »
I have to be careful, I hooked up the charge pipe minus one coupler that has no clamp and the fucker started to build boost when I was at 2500rpm in 5th gear  :?: Only 1 psi, but still...
« Reply #176 on: September 19, 2010, 03:51:01 PM »
It's really pissing me off. I checked the continuity of each wire on the cable and they are fine. I downgraded the firmware to 10.14 and it's working fine with Crome.
It there something that controls the chip outside of the ECU? Since I have 2 ECU and both are doing the same thing. It might be external to them.
Or I could stop searching and wait for my Ostrich 2   >:(
Btw, it creates a electric noise when I jump the wire to enable the chip. Sounds like it's coming from under the dash. Maybe it's just the solid cel tho...
« Last Edit: September 19, 2010, 03:53:03 PM by Teg2boo »
« Reply #177 on: September 19, 2010, 05:06:38 PM »
The sound come from the IACV. Doesn't make the sound on stock ECU, but when I jump J1 it makes the sound.
I'm lost.
« Reply #178 on: September 20, 2010, 12:13:12 AM »
main relay humming? soild cel? drop the dash panel under the wheel and it will stare you in the face take it appart and see if its in good shape
« Reply #179 on: September 20, 2010, 03:47:23 AM »
If it's the main relay, why it is working fine with stock ECU, but not chipped?
Pages: 1 ... 4 5 [6] 7   Go Up
