How long before it blows up?
First start
- 12 (8.5%)
2 weeks
- 4 (2.8%)
1 month
- 7 (5%)
6 months
- 2 (1.4%)
1 year
- 4 (2.8%)
never
- 7 (5%)
motor already blew up, before being assembled
- 18 (12.8%)
CRX
- 28 (19.9%)
HHH
- 24 (17%)
JDSAP
- 16 (11.3%)
T2BSAP
- 13 (9.2%)
Fuck people who say "Fuck the French" but live with them?
- 6 (4.3%)
Total Members Voted: 49
Pages: 1 2 3 [4] 5 6 7   Go Down
Author Topic: Integra 92 b18A1 turbo build holy fucking huge pics  (Read 151414 times)
Re: Integra 92 b18A1 turbo build holy fucking huge pics
« Reply #90 on: July 19, 2010, 10:35:24 PM »
I forgot to add this info, it's the second ring.
« Reply #91 on: July 19, 2010, 10:41:06 PM »
If 0.006 doesn't matter, how much is too much?
« Reply #92 on: July 19, 2010, 11:10:18 PM »
Bought an aluminum half size rad on ebay. Like that, I'll have plenty of space for the wastegate.
« Reply #93 on: July 30, 2010, 05:06:52 PM »
Pistons are in, oil pump cleaned/installed. Interresting fact is that I installed 2 pistons by hand because le tabarnak de ring compressor broke...
 I'm now doing my cylinder head.
« Last Edit: July 30, 2010, 05:12:27 PM by Teg2boo »
« Reply #94 on: August 02, 2010, 12:34:40 AM »
sheetmetal + vicegrips = win
Someone else posted a different take on a rhmt ring compressor, I forgot what they used though. The version above I like the most (albeit the pro version, wrench-like handles), as it tends to not slip, and rarely breaks rings.
« Reply #95 on: August 02, 2010, 12:37:10 AM »
I used a 3" hose clamp before it works if th clamp is 3/4" wide or more. ;D
« Reply #96 on: August 02, 2010, 12:56:59 AM »
i like to make john west insert the piston/rod assembly into his colon bearing first, then install it by sitting squarely over the center of the bore... he recently installed a set of 89mm pistons like so, but fortunately the 5mm difference did not make him damage my ls install.
g_shok
  • SuperSport
« Reply #97 on: August 05, 2010, 06:24:46 PM »
don't forget to rotate the cam pulley counterclockwise 36 degrees before you put the belt on for good luck  :-*
« Reply #98 on: August 05, 2010, 06:35:29 PM »
I know this, it already been done! Don't think I'm dumb.
« Reply #99 on: August 05, 2010, 06:40:40 PM »
Why does my girl friend have a penis and yours dont  ???
« Reply #100 on: August 09, 2010, 11:34:02 AM »
The block is in the car. Had to put it by hand and alone the fucking car. The hoist was at dad's friend's house and anyway, it was raining and the engine hoist was too big to fit in the garage the way I positioned the car. I had to lift it at least 20 times to be able to put the bolts in the driver side motor mount. Very good exercise for my back.
Tonight I install the transmission and the more other things I can do. Hoping to start it up tonight or tomorrow.
How to remove engine redneck style. It finally felt on the ground pouring collant and oil everywhere...
Should have done it by hand like I installed it.
Heavy duty ratchet for big job. 3/4" drive
« Reply #101 on: August 09, 2010, 11:38:49 AM »
do work son!
« Reply #102 on: August 09, 2010, 11:25:00 PM »
So, it's not going very well... Had to remove the flywheel I installed yesterday cause I forgot to install the pilot bearing... Clutch installation was ok. Installation of the transmission goes wrong tho...
Tomorrow my gf needs her car, so I can't work on mine.
Todo list:
-Install the transmission  - 15 min to 2 hours
-Install starter - 15 min
-Install random brackets - 30 min
-Install alternator - 15 min
-Install cylinder head - 30 min
-Install intake manifold - 15 min
-Install turbo on exhaust manifold - 15 min
-Install exhaust manifold - 15 min
-Install/build downpipe (depends if I install ramhorn or miniram) 15min / 3 hours
-Install radiator + fan - 15 min
-Install injectors - 15 min
-Plug sensors, wires and hoses  - 30 min
-Replace outer and inner tie rods - 1.5h
-Weld my shift rod that I had to cut because bitch pin was too much of a fucking bitch - 15 min
-Install rods - 30 min
-Install axles - 30 min
-Install brakes - 15 min
-Install wheel - 5 min
-Do a basemap for new setup  - 30 min
-Break in - 1 hour
-Ripper 1000 hours
-Profit
Total: 12 hours before start up
Damn, I have job for at least a week at 3 hours/day. I need a beater...
« Reply #103 on: August 10, 2010, 08:11:46 PM »
Just bought this for 500$
http://www.lespac.com/d-vehicules-autos-laval-pont-viau-pontiac-sunfire-gtx-1998-LPCaZZ22286700
At least I'm free to go where I want until my car is done.
« Reply #104 on: August 10, 2010, 08:15:17 PM »
did it come with a boyfriend or do you have to bring your own
« Reply #105 on: August 10, 2010, 08:19:52 PM »
It was at my choice so I choose to bring my own since there are plenty of candidate on this forum.  :-*
« Reply #106 on: August 11, 2010, 12:17:26 PM »
I knew you were just here to pick up guys
« Reply #107 on: August 16, 2010, 10:29:56 PM »
Kind of update... Clutch doesn't fit, I didn't know there was a difference between 90-91 and 92+ transmission. The shaft is different so I can't use the clutch.
Ordered one from LSD motorsport and should receive it next week.
I forgot to install the dowel pins on the head/block so I need to take the head apart and reinstall everything. The timing belt was installed, valve adjusted, FUCK. Found today that I only had one in good shape and the other one is at the apartment and not in the garage. So far, it's going very bad lol
Good thing today:
Intake manifold ported for the oversized throttle body.
« Reply #108 on: August 16, 2010, 10:35:57 PM »
Pm'ed about that 90-91 clutch......   Jew
« Reply #109 on: August 16, 2010, 11:03:05 PM »
I bought it from Chris M on OHMT. ACT Xtreme and 6 pucks disc.
30 minutes later
http://www.homemadeturbo.com/f9/act-b-series-cable-extreme-pressure-plate-6puck-105-shipped-92220/
I'll ship it at same price 120$ since shipping cost fucking lot of money.
« Reply #110 on: August 16, 2010, 11:05:03 PM »
PM just don't work for me... Get db error all the time
« Reply #111 on: August 16, 2010, 11:06:11 PM »
Post pics....  Of the disc
« Reply #112 on: August 16, 2010, 11:28:50 PM »
In 2 days, I'm not going to the garage tomorrow.
Edit: best I can find for now
« Last Edit: August 16, 2010, 11:30:33 PM by Teg2boo »
« Reply #113 on: August 16, 2010, 11:39:31 PM »
Some pics of my dad's camaro and a friend's cavalier.
« Reply #114 on: August 17, 2010, 10:01:01 AM »
Those are some Frenchified rides.  Do you live near the Bay of Fundy?
« Reply #115 on: August 17, 2010, 04:12:20 PM »
If 1000km in considered near, yeah, I am.
« Reply #116 on: August 21, 2010, 11:05:12 PM »
Then I'll not be sleeping on your couch when I visit there.
« Reply #117 on: August 22, 2010, 12:12:12 AM »
You can sleep on my couch at anytime, just call me couple of hour before you arrive. You need to be near Montreal tho.
Pics of the clutch for 2dogs and some random pics
My new cellar and 200$ worth of red wine.
Really out of context, but I am a baller when I have money lol
Working on my car
Disc
Disc with some love of a ramhorn manifold
Widthedthed
Widthedthed again
Pressure plate side A
Pressure plate side B
« Reply #118 on: August 22, 2010, 12:15:17 AM »
Your dad is one redneck frenchie, johnny would be proud.
Also, good luck with that ACT clutch, hope you have better luck than i did.
« Reply #119 on: August 22, 2010, 12:51:36 AM »
I'm trying to selling it out to 2dogs. Shut up sir. ;)  I bought a LSD 412lbs torque clutch/pressure plate. I
Shut up Scott, I'm trying to sell this clutch :P
Seriously, it won't fit 92-93 Integra cause splines are not the same as 90-91's. I bought a LSD clutch kit that should hold 415lbs of torque so I should be ok.
My dad is a french canadian redneck, no doubt of this. Seriously.
If it's 12pm somewhere in the world, you should be allowed to drink a beer. It might not sound as funny at it is in French, but I know you dad is an alcoholic and says something similar. lol
Pages: 1 2 3 [4] 5 6 7   Go Up
