How long before it blows up?
First start
- 12 (8.5%)
2 weeks
- 4 (2.8%)
1 month
- 7 (5%)
6 months
- 2 (1.4%)
1 year
- 4 (2.8%)
never
- 7 (5%)
motor already blew up, before being assembled
- 18 (12.8%)
CRX
- 28 (19.9%)
HHH
- 24 (17%)
JDSAP
- 16 (11.3%)
T2BSAP
- 13 (9.2%)
Fuck people who say "Fuck the French" but live with them?
- 6 (4.3%)
Total Members Voted: 49
Pages: 1 [2] 3 4 ... 7   Go Down
Author Topic: Integra 92 b18A1 turbo build holy fucking huge pics  (Read 151433 times)
Re: UPDATE: Carnage pics! Near future b18a1 build holy fucking huge pics
« Reply #30 on: June 30, 2010, 05:23:01 PM »
I'd loved to have read the carbon coat, but oh well.  There are no signs of detonation on the piston faces.  Unless there's appreciable scarring on the skirts I'm going to say the tune was fine if a bit rich, and it looks like she was a minor oil burner.  Well, if the tune was off the sleeve is about the last thing that would let go.  Sleeves just let go, sometimes, and a block guard doesn't help with anything.   :-\
I'd recommend a later B18B block, but IIRC you've already run that other B18A through the machine shop.  As long as it doesn't have the decayed/chipped upper liner sheathe like most B18A's I'm sure it's just as good.
Re: Near future b18a1 build holy fucking huge pics
« Reply #31 on: June 30, 2010, 05:34:21 PM »
It must be cause I'm a tuner extraordinaire. HA
I was at WOT near 150km/h when it happened.
 :P
« Reply #32 on: June 30, 2010, 06:00:49 PM »
 :P
I thought of this thread at the moment it happened LOL
« Reply #33 on: June 30, 2010, 06:02:12 PM »
Block as not been sent to the machine shop yet. I'm not sure to understand what you mean by "upper liner sheathe"
Here is a picture of the block surface (new block):
« Last Edit: June 30, 2010, 06:18:05 PM by Teg2boo »
« Reply #34 on: June 30, 2010, 06:19:27 PM »
Your parts should be to you shortly damn customs. Also make sure that manifold is opened up to 68mm to match the throttle body plate size. I always recommend running the spacer since you can use it to match the manifold perfectly plus it has the taper which helps out big time with throttle response.
« Reply #35 on: June 30, 2010, 06:52:48 PM »
I forgot about the spacer... I wanted one few month ago but waited until I buy more things from you.  How much shipped for the plate?
« Reply #36 on: June 30, 2010, 07:01:12 PM »
The aluminum that surrounds the sleeves.  Lots of B18A blocks are haggard as fuck in that area.  I would think that decay in that area would mean slightly less sleeve support, and less surface for the head gasket to seal.
The new block look pretty decent to me.
EDIT:  Fat fingered like a mofo.
« Last Edit: June 30, 2010, 10:32:24 PM by snm95ls »
« Reply #37 on: June 30, 2010, 07:56:52 PM »
buk can weld that.
Exactly, just get him all hopped up on some DXM and he'll work his sandcoon welding magic, it'll be 8x as strong with the blessing of allahu akbar on it.
« Reply #38 on: June 30, 2010, 09:55:16 PM »
The aluminum that surrounds the sleeves.  Lots of B18A blocks are haggard as fuck in that area.  I would think that decay in that area would mean slightly less sleeve support, and le4ss surface for the head gasket to seal.
Thge new block look pretty decent to me.
+1
boosted wagon
« Reply #39 on: July 01, 2010, 01:46:01 AM »
Nice work :noel: You should really just save some funds and sleeve it.It cost me $1235 CDN to have my B18B sleeved all done with machining to match pistons and return shipping to Canada.
« Reply #40 on: July 01, 2010, 06:43:43 AM »
I don't make enough cash for now to sleeve it and I can't wait 1 year with the car in the street with no motor :P
I'll build it with stock sleeve this year and sleeve it next year when I'll finish school and start making enough cash to buy a sleeved block every week ;)
I want this to be done in 2 weeks max.
« Reply #41 on: July 01, 2010, 07:29:04 AM »
Step 1) Go to French school.
Step 2) ???
Step 3) Profit!
« Reply #42 on: July 07, 2010, 08:14:57 AM »
bump for updates
« Reply #43 on: July 07, 2010, 08:17:55 AM »
GM 3bar map sensor is there and a spacer from Chris is on the way  :noel:
Haven't work on the head yet, it's too fucking hot outside (106F with humidity).
« Reply #45 on: July 07, 2010, 08:20:42 AM »
You should move a thousand or so miles South, and develop a Southern accent.   It's been nice the past few days,
« Reply #46 on: July 07, 2010, 09:27:28 AM »
I'm not sure I want to develop a southern accent.
« Reply #47 on: July 07, 2010, 09:35:04 AM »
Yeah combination of a French Canadian and a Southern accent would really be confusing for anybody Teg2boo tries to talk too.
Imagine his future job interviews with both of these accents competing to be used.
The only Southern area I can think of where he maybe ok would be in the Central to Southern Louisiana area. Since Cajuns have trouble speaking English, French, or speaking for that matter.  ;D
« Reply #48 on: July 07, 2010, 09:41:31 AM »
Yeah, but Cajuns eat gator so it's OK.
« Reply #49 on: July 07, 2010, 12:54:23 PM »
Does 94-01 B18B1 oil pump fit on my block? I forgot to buy an oil pump...
boosted wagon
« Reply #50 on: July 07, 2010, 01:19:03 PM »
Yes.OBD2 oil pump is the one you want its the same for all B series.The lower timing cover is different though so you will need a 96+ cover to match.
« Reply #51 on: July 07, 2010, 01:24:07 PM »
Spring/shim is not.  You want a VTEC unit, either from a used pump or purchased as such for the extra markup, or you can shim it yourself if you spend five dollars on an oil pressure gauge.
boosted wagon
« Reply #53 on: July 07, 2010, 06:39:02 PM »
So if I buy this one I should be ok right?
http://cgi.ebay.ca/OEM-96-01-Integra-GSR-B18C1-Type-R-B18C5-VTEC-Oil-Pump-/350364685664?cmd=ViewItem&pt=Motors_Car_Truck_Parts_Accessories&hash=item51935cd560#ht_503wt_911
Yes all newer B series run the exact same pump no difference between any of them.The cover you can cut to fit or buy a new 96+ B series for like 30-40 bucks.
« Reply #54 on: July 08, 2010, 01:30:52 AM »
If you want a low mileage obd2 Jdm type r unit I have a box full of them on the cheap of course!
« Reply #55 on: July 08, 2010, 08:26:25 AM »
Thanks Chris, I'm interested!  But before I buy something else from you, I'll take a look if I need other things and ask you everything at the same time lol
I'll let you know tonight!
« Reply #56 on: July 08, 2010, 05:46:42 PM »
I agree shipping flat rate to canada isnt that cheap I think it was 26 bucks to ship the last stuff.
« Reply #57 on: July 10, 2010, 04:58:30 PM »
Kind of update. Still fucking hot here, so working outside is painful.
Removing my valve spring:
Cleaning my head:
Porting the head:
I'm not even half way to be done...
« Reply #58 on: July 10, 2010, 05:02:45 PM »
I forgot, should I remove the sharp edges on the pistons?
My dad has a sandblasting cabinet, yah or nah?
« Reply #59 on: July 10, 2010, 08:37:37 PM »
I wouldn't use a blast cabinet to debur pistons, personally.
Why the hell are the valve pockets always so goddamn huge on aftermarket pistons?
Pages: 1 [2] 3 4 ... 7   Go Up
