Author Topic: hatchbones ride  (Read 24253 times)
hatchbone
hatchbones ride
« on: December 08, 2011, 11:37:43 PM »
last one got the delete when site went down so i just copied some pics for this so fuck you
Hatchbone Dyno Session HD
Hatchbone finally runs 10s
« Last Edit: December 08, 2011, 11:46:20 PM by hatchbone »
robus
Re: hatchbones ride
« Reply #1 on: December 09, 2011, 04:25:38 AM »
Pretty hardcore  :noel:
NoPistons!
Re: hatchbones ride
« Reply #2 on: December 09, 2011, 07:16:08 AM »
Dont tell anyone but i'm saving that gas station pic as wallpaper.
You drive that thing on the street?!  Hell yeah.
Re: hatchbones ride
« Reply #3 on: December 09, 2011, 03:32:05 PM »
Boat anchor love my niggle
Re: hatchbones ride
« Reply #4 on: December 09, 2011, 08:32:07 PM »
hot damn.  Is that a civic with a turbo?
hatchbone
Re: hatchbones ride
« Reply #5 on: December 09, 2011, 09:38:09 PM »
its a turbo with a civic
hatchbone
Re: hatchbones ride
« Reply #6 on: December 09, 2011, 09:39:13 PM »
got some new goods for my vac setup
hatchbone
Re: hatchbones ride
« Reply #7 on: December 11, 2011, 04:11:57 AM »
what turbo you end up going with?
DSharp
Re: hatchbones ride
« Reply #8 on: December 24, 2011, 12:32:13 AM »
your diff looks like mine!  still works though...
hatchbone
Re: hatchbones ride
« Reply #9 on: December 24, 2011, 03:25:06 PM »
I got new washers and re assembled it as is and works like a champ
theidealone
Re: hatchbones ride
« Reply #10 on: December 24, 2011, 04:30:12 PM »
I didnt have the same ones, but I had quick release with that plastic shit, and it melted where it came out of the turbo. Worked great for my BOV, and stuff like that. Someone told me they make all metal quick release adapters.
DSharp
Re: hatchbones ride
« Reply #11 on: December 24, 2011, 09:43:06 PM »
yep.  same here.  obx washers are like potato chips.
jarebear667
Re: hatchbones ride
« Reply #12 on: December 25, 2011, 12:28:30 AM »
What'd you end up for power?
midwest HMT!
hatchbone
Re: hatchbones ride
« Reply #13 on: December 25, 2011, 03:08:00 AM »
Around 800-820 it kept spinning over 8k on the dyno but it made 702 on 24psi its now at 34psi the dyno I use has a new strap design I just haven't put it back on the rollers,first thing next year though
Re: hatchbones ride
« Reply #14 on: December 25, 2011, 12:27:33 PM »
Fucking baller, will the obx hold up? :?:
hatchbone
Re: hatchbones ride
« Reply #15 on: December 25, 2011, 03:31:31 PM »
Has for three seasons already lol
Re: hatchbones ride
« Reply #16 on: December 25, 2011, 08:59:00 PM »
Damn I seen a lot of trash obx around here under 600hp :?:
hatchbone
Re: hatchbones ride
« Reply #17 on: December 27, 2011, 03:22:38 AM »
get the washer kit and re torque and you good to go for half price
flat_black
Re: hatchbones ride
« Reply #18 on: December 31, 2011, 12:31:47 AM »
brian is still using an OBX in his trans, thats about the only thing that hasnt broke...
I used one for 3 years or so from 500-600whp without issue, i did break the washers but upgraded and seemed fine after that
hatchback
  • N00B *Read Intro Sticky*
Re: hatchbones ride
« Reply #19 on: January 03, 2012, 12:39:21 AM »
Wheres the porn? You fail.  :noel:
hatchbone
Re: hatchbones ride
« Reply #20 on: January 03, 2012, 01:26:00 AM »
Your first post was coming at me asking me where the porn be ,I think I should be asking you that  O0
Re: hatchbones ride
« Reply #21 on: January 04, 2012, 10:21:33 PM »
if people ar breaking obx diffs theyre nos tetting them up right. I beat mine harder than I beat weidebodys ex roast beef and never an iddue, Washers are a nust.
hatchbone
Re: hatchbones ride
« Reply #22 on: January 10, 2012, 09:02:01 PM »
should not be a issue if set up properly
hatchbone
Re: hatchbones ride
« Reply #23 on: February 19, 2012, 02:32:33 PM »
so got around to pulling my head off this is what it looks like when your springs try and pull the valves through backwards not a big deal, could of been a lot worse, could of snapped off here are some pics never will i run superstretch again. couldn't handle the anti lag
Re: hatchbones ride
« Reply #24 on: February 19, 2012, 02:57:56 PM »
I'm not understanding what happened, besides the valve beating the piston. Mind explaining, such as failed retainers, keepers, or valve stems?
hatchbone
Re: hatchbones ride
« Reply #25 on: February 19, 2012, 03:05:27 PM »
the valves got so hot from my anti lag they got soft and the force of the spring wanted to pull them out backwards, the pistons are fine but a couple of the retainers are a little beat from hitting the rockers when the valve stretched
Re: hatchbones ride
« Reply #26 on: February 19, 2012, 03:10:09 PM »
Time to add sodium...at least for the exhaust side. The only problem is honda valve stems are already so thin.
Re: hatchbones ride
« Reply #27 on: February 19, 2012, 05:09:10 PM »
No need for sodium valves. At all.
Jake I dont think it weas the antilag. Looks like it went lean (you did mention this happened after upping the boost?) It went lean and EGTs got very very hot by the looks of it, maybe more than once...  Fuck Superstretch/snap valves though. Go Ferrea. Ive NEVER had an issue. Valves do look like contact was made... Pics of valve reliefs?
NICE CATCH Jake....Glad those things didnt cost you a bottom end
hatchbone
Re: hatchbones ride
« Reply #28 on: February 19, 2012, 06:10:51 PM »
I'll get some more pics up soon could of leaned I do have my data logs from my last race ill peep and see what they say
hatchbone
Re: hatchbones ride
« Reply #29 on: March 28, 2012, 10:42:21 PM »
head is back new valves and seals should be rollin by end of weekend
