Pages: 1 2 [3] 4 5 ... 47   Go Down
Author Topic: UI's 703hp Purple beast - She is injured  (Read 832416 times)
Re: Urban Indians Re-Rebuild on the HX-52/2.0L GSR
« Reply #60 on: April 30, 2009, 10:37:14 AM »
...Fixed some sketchy wiring...
Get a grommet or some silicone on that group of wires (far left top 1/3rd of the screen) going through the firewall, that is just asking for issues.
« Reply #61 on: April 30, 2009, 11:49:41 PM »
MRP fo lyyyfe.
i heard its actually going to be open tomorrow.  fresh pavement.
where the fuck are my isky springs.
looks good indian hope this one turns out good for ya.
yeah I was going to go and watch a buddy race but instead ill be camping and drinking to much
did your buddy happen to crack a sleeve?  i know something didnt go right.  heh
Is this Dan from Roto?
Levi, I like the black tanks.
Dan from Altrom.  i gotta check out your shop one day.  u should buy shit from us.  fuck woldpac.
Well set us up with an account than ;)
Loki
« Reply #62 on: May 01, 2009, 01:00:26 AM »
You work for Altrom? I buy stuff from them all the time.
Car is looking good Levi.
« Reply #63 on: May 03, 2009, 11:53:02 AM »
All the gauges are wired. The MSD is hooked up and the box light turns on( just need to add clips to plug into the dizzy ignitor. Dash is back in, just needs a little bit of wiring.
Rocking this bumper until I get a different one. I'll still keep this for the track.
Charge wiring problem thread
http://www.realhomemadeturbo.com/forum/index.php?topic=2149.0
PICS
« Last Edit: May 03, 2009, 11:54:55 AM by Urban Indian »
« Reply #64 on: May 03, 2009, 12:33:34 PM »
This is the way I did my kill switch setup. Works great.
« Reply #65 on: May 05, 2009, 08:57:31 PM »
is tack welding the studs to the hub really needed or is it a just for good measure thing?
90dx
« Reply #66 on: May 05, 2009, 11:34:43 PM »
The studs love to back off and fuck you over.I always tack weld them on.Keep up the good work nog :noel:
« Reply #67 on: May 06, 2009, 02:46:20 AM »
i've never had one back off, but i did have one strip more or less.  had to break the lug nut off
all the more reason to do what you did
« Reply #68 on: May 06, 2009, 03:06:50 AM »
« Reply #69 on: May 06, 2009, 04:44:20 AM »
The studs did back off and fucked my wheels up.
Weld them. Its for safety.
And fuck off JH, thats andy P there doing some fucking wiring up in that bitch.
I hate how AEM has like a MILLION fucking wires for their gauges. Hard to stuff it in that little hole
« Reply #70 on: May 06, 2009, 10:50:38 AM »
LOL
But seriously Black Angus (Andy P) is the shit, he has a Chevelle that runs low 9's.
boosted 00 black si
« Reply #71 on: May 06, 2009, 11:32:31 AM »
nice rebuild  :somb:
go fuck your self
BORN TO BOOST
LITTLE B16.400whp on 16psi
« Reply #72 on: May 06, 2009, 01:22:00 PM »
nice rebuild  :somb:
GET THAT FUCKING SHIT OUT OF YOUR SIGNATURE YOU FAGGOT, YOURE A BIGGER FAGGOT THAN LEVI FOR HIS QUEER ASS BUMPER
CAN I GET A BANTHISNIGGER???
« Reply #73 on: May 06, 2009, 01:48:25 PM »
nice rebuild  :somb:
BANTHISNIGGER!!!
« Reply #74 on: May 06, 2009, 03:40:41 PM »
BANTHISNIGGER!!!
[/quote]
Amen
Xenofraud
« Reply #75 on: May 19, 2009, 02:53:18 AM »
Well since super dipper failed to bring me a bumper I am going to rock this one. Pics of the new block, and the fancy dancy coated pistons. Just waiting the head and then its go time for assembly.
d-rail
« Reply #76 on: May 19, 2009, 03:08:56 AM »
Very nice. Looks expensive
« Reply #77 on: May 19, 2009, 04:15:33 AM »
he's indian, old ladies betting their social security checks paid for that shit
« Reply #78 on: May 19, 2009, 06:21:26 AM »
Your tires will be here this weeek nig, Im taking youre trans shit to Rosss this week, probably tomorrow.
« Reply #79 on: May 19, 2009, 10:32:44 AM »
Laskey gave me a bunch of free shit. Like i was going to buy teflon coated pistons anyway. Shit looks baller though.
Re: Urban Indians Re-Rebuild on the HX-52/2.0L GSR - block & head done
« Reply #80 on: May 20, 2009, 04:37:30 AM »
Lion Cat, new avid mounts. and the 2 HG i got from Tuner toys?(accidental shipment?)
« Reply #81 on: May 24, 2009, 10:13:50 AM »
RUN YET?
« Reply #83 on: May 25, 2009, 01:16:57 AM »
put the rockers in today. Putting the head on the block as we speak. Had a small problem with the timing belt gear on the crank snout, then fucked up my oil pump seal. So just fixed those and finished copper coating the HG
block together tonight
« Reply #84 on: May 25, 2009, 07:17:10 AM »
Finished tonight
- Head is on the block torqued down. copper coated GE HG @ 72ftlbs
- cams are in/lubed & degreed.  .5 degree out both intake/exhaust retarded
- timing belt is on/ tightened
- harmonic balancer is on
- oil pump is installed and good to go
- coolant tube/lines/fittings on
-vTAK is on
- block fittings are installed ( oil filter thread stud is pulled off, i dont want an oil warmer anymore)
- drivers side mount installed
-1 of 3 timing belt covers installed ( cant find 1 of them so fuck it, not an issue as of right now)
- intake manifold parts put on the IM
Left to do
- find studs for the intake & exhaust( i cant seem to pull them off my LS motor without fucking them up and they are missing off this head
- front main seal needs to be installed.
- get a couple plugs for my coolant passages/turbine housing
- new oil filter stud
- clutch installed
then throw the thing in the car. Been a long night
« Last Edit: May 25, 2009, 07:21:52 AM by Urban Indian »
Dr. D-Series
« Reply #85 on: May 25, 2009, 10:52:08 AM »
A friend of mine has a hx52 sitting on his bench at work. It looks ridiculous.
Thanks for using one.
D16Y8-Z6.
sloTeg
« Reply #86 on: May 25, 2009, 01:51:26 PM »
easiest way i found to get those out is to thread 2 nuts on the stud and then tighten them together, then just loosen the nut closest to the head and should come right out.
« Reply #87 on: May 25, 2009, 01:54:51 PM »
tried that. I might try adding some heat to the equation. If not I think you can buy them at lordco
« Reply #88 on: May 25, 2009, 08:58:54 PM »
Left to do
finish installing turbo onto manifold with wastegates. tranny is on, might go in the car tonight
« Reply #89 on: May 25, 2009, 09:06:47 PM »
Left to do
Probably should keep on that.
If my math is right you have 3 days and counting.
Pages: 1 2 [3] 4 5 ... 47   Go Up
