Pages: 1 2 [3] 4 5   Go Down
Author Topic: F2D gay as aids na Ef  (Read 117683 times)
Re: F2D turbo Ef
« Reply #60 on: January 16, 2014, 08:14:33 AM »
cant use a K tranny. the J has the starter on the tranny side and the K has the starter on the engine side. the j block is too wide for the starter
Re: F2D turbo Ef
« Reply #61 on: January 16, 2014, 07:52:29 PM »
Push start it you pussy
Re: F2D turbo Ef
« Reply #62 on: January 17, 2014, 07:49:12 AM »
I'm thinking golf cart style. Have an electric motor roll the car, then dump the clutch. I'd rather fab that up than push it every time
Re: F2D turbo Ef
« Reply #63 on: January 17, 2014, 10:56:34 AM »
I got a free J35 because it broke the timing belt and killed the valves. Needless to say I need heads but been throwing the idea of adapting a vg30dett 5spd trans and going rwd or a th400 with trans brake :evil:
Re: F2D turbo Ef
« Reply #64 on: January 17, 2014, 04:32:16 PM »
I already talked to a guy about making a GM adaptor for rwd. I have a 5 speed in my truck that I want to swap with a 700r4 I have. Then stick it in an ef hatch I have with an s10 rear axle. One day if I ever have time and money to throw at something stupid.
Re: F2D turbo Ef
« Reply #65 on: January 20, 2014, 03:14:21 PM »
Done dirty cheap!
Crank some boost and see what she makes. I have a 8.8" laying around.
Rioreded6
  • Aintcare
Re: F2D turbo Ef
« Reply #66 on: February 24, 2014, 07:10:55 PM »
I has progress
Thought it would be nicer to my neighbors new born if I didn't use air tools to take the axles out so they stayed in whilst I struggled to take the motor and trans out together...never again   :(
New assembled bottom
I couldn't find my clutch alingment tool so I improvised
It's in!  :D
On start up I had a nasty sounding tick...cyl #3 exhaust valve is sticking  :'(
This will be the third time this head will be at the machine shop fml.
Re: F2D turbo Ef
« Reply #67 on: February 24, 2014, 11:39:24 PM »
Why not pick up another head?
Re: F2D turbo Ef
« Reply #68 on: February 25, 2014, 12:04:44 AM »
they should be cheap enough.
Rioreded6
  • Aintcare
Re: F2D turbo Ef
« Reply #69 on: February 25, 2014, 01:05:42 AM »
Because I'm an idiot, and if its just the valve im sure I can pick up a new for less money, and effort it would take to pull one from the junkyard that could be warped, cracked, or plain fucked. No good yards around my parts, and the closest legit one would be in Tallahassee which is two hours away. This Saturday I work too so I have absolutely no time :<
Rioreded6
  • Aintcare
Re: F2D turbo Ef
« Reply #70 on: February 27, 2014, 02:12:39 AM »
Ended up bending that one valve some how. I've ordered a new valve  ($15.52 from honda :>) shitty felpro gasket set and some honda coolant and got it back together not too long ago. Maybe I'll post some pics later.
Re: F2D turbo Ef
« Reply #71 on: February 27, 2014, 01:40:26 PM »
Time to up the boost!
Re: F2D turbo Ef
« Reply #72 on: February 27, 2014, 10:01:53 PM »
Big boost
Rioreded6
  • Aintcare
Re: F2D turbo Ef
« Reply #73 on: March 03, 2014, 12:19:52 AM »
Re: F2D turbo Ef
« Reply #74 on: March 04, 2014, 09:52:12 AM »
That mofo is moving!
Re: F2D turbo Ef
« Reply #75 on: March 09, 2014, 12:22:14 PM »
Re: F2D turbo Ef
« Reply #76 on: March 09, 2014, 04:26:52 PM »
gauge cluster looking good which led's or lights did you go with?  I like how even the light looks.  Last time I tried with led's it sorta had bright spots and dimmer spots, hated it went back to stock.
Rioreded6
  • Aintcare
Re: F2D turbo Ef
« Reply #77 on: March 10, 2014, 12:17:08 AM »
These.
Just rolled up around the outer diameter of the tach and speedo.
Maybe picking up an hx35 with a bent shaft for $100.
Rioreded6
  • Aintcare
Re: F2D turbo Ef
« Reply #78 on: March 10, 2014, 12:20:52 AM »
Thanks. All the ignorant motherfuckers here think It's a stock hatch with a serious exhaust problem,so I'm on the look out for some stock diesel exhaust on craigslist to quite it down.
Rioreded6
  • Aintcare
Re: F2D turbo Ef
« Reply #79 on: March 21, 2014, 05:29:59 PM »
Almost bought the turbo but I convinced the guy to disassembly it prior to purchase.
shits fucked.
Rioreded6
  • Aintcare
Re: F2D turbo Ef
« Reply #80 on: March 28, 2014, 11:14:39 AM »
So this just happened last night...
Re: F2D turbo Ef
« Reply #81 on: March 28, 2014, 01:40:18 PM »
Win. You know your making power when your car rips motor mounts off the frame.
Rioreded6
  • Aintcare
Re: F2D turbo Ef
« Reply #82 on: March 31, 2014, 01:36:03 PM »
Bought a welder this friday and a tank for co2. I didn't know that tanks came empty  ??? so prepare yourself for some fluxcore sexiness  :-*
Hopefully it doens't break again.
Re: F2D turbo Ef
« Reply #83 on: March 31, 2014, 02:38:30 PM »
This happen to a few friends with crx making over 350hp.
Re: F2D turbo Ef
« Reply #84 on: March 31, 2014, 07:45:15 PM »
Lol if thats the case i'll just cut the frame mount off now and put it where it needs to be for a hydro trans because thats what i have anyway.  Goodbye flux cored hackjob mount
Re: F2D turbo Ef
« Reply #85 on: March 31, 2014, 11:28:33 PM »
That is sexy
Rioreded6
  • Aintcare
Re: F2D turbo Ef
« Reply #86 on: April 01, 2014, 12:49:45 AM »
I would be ecstatic if my car made over 280whp lol.
If you do swap to the hydro frame mount please save yourself the pain I went through and brace the actual frame mount.
That is sexy
I'm trying lol
Re: F2D turbo Ef
« Reply #87 on: April 01, 2014, 11:45:50 PM »
I'm trying lol
Shit, I'd hate to see it when you DGAF...
Re: F2D turbo Ef
« Reply #88 on: April 03, 2014, 11:35:49 AM »
280whp and probably well over 300 torque, the exact opposite of most turbo civics.
Re: F2D turbo Ef
« Reply #89 on: April 04, 2014, 01:29:05 AM »
I keep debating on selling my sleeved block to do this awesome
Pages: 1 2 [3] 4 5   Go Up
