Pages: 1 ... 3 4 [5] 6 7 ... 11   Go Down
Author Topic: boosted 4dr...OFFICIALY jdm since pg 6  (Read 245074 times)
speedjunky01
Re: boost atempt number 3. . . 4 doohs fo' mo' ho's!
« Reply #120 on: October 06, 2009, 08:14:51 PM »
got the intake done today chopsaw plus pie cuts=SEX cant believe i didnt notice my pops had a chop saw stashed away earlier would have made life so much easier!!!
pics up soon
speedjunky01
« Reply #121 on: October 06, 2009, 09:55:51 PM »
brown only trmp. until i can get some heatwrap and flat black
got the idea now :D
pie cut sex
speedjunky01
« Reply #122 on: October 09, 2009, 02:01:10 PM »
shipped 3 cats and my IM to chris today
70mm TB,spacer and portmatched comming up :D
« Reply #123 on: October 09, 2009, 04:00:05 PM »
Well worth it. :yes:
jundoc
« Reply #124 on: October 09, 2009, 10:42:24 PM »
hey do you have a shot of how u ran the charge piping having the AC comp..there?? wanna see what that looks like... ??? ;D
VOUCHES; nbspnbsp jeffsciv23, TUNERTOYS,Ogubudiah,2G6,Y8crx,the 13th ,crx2211,soontobeDA,turboHF,40 psi 4g63
speedjunky01
« Reply #125 on: October 10, 2009, 12:34:38 AM »
ive heard good things as well
as for the pipes here is the best i have
infront of the DP right there is where the hot sire pipe goes, here is the hot pipe
so from engine to condenser fan it goes oilpan, oil return, DP, hot pipe, condenser fan
hope it makes sense
speedjunky01
« Reply #126 on: October 10, 2009, 07:23:40 PM »
the pipe maze is nearing completion
i think thats about as good as it gets when it comes to BOV placement close to throttle body lol
speedjunky01
« Reply #127 on: October 10, 2009, 09:26:41 PM »
im hoping the shrinking from 3" charge pipes to 2.5 and slightly shorter pipes help throttle response and spool out a tad
any ideas on how much of an effect i should look forward to?
before spool was full boost by 4700ish in 2-3-4 1st was really really late
speedjunky01
« Reply #128 on: October 15, 2009, 01:50:23 PM »
woho!! all done :D i had some rewards point from the zone so i got some reflective heat wrap for free and i did the intake pipe's and the hot pipe that is inside the engine bay right by the downpipe. hope it reduces some heat soak, car used to start breaking up on hot days.
enough talk onto a pic
waiting on the paint to try and putting it all together and testing it out.
speedjunky01
« Reply #129 on: October 15, 2009, 05:21:13 PM »
pipes fit like a glove this time around, hope the home depot couplers and clamps hold up over winter and spring. built d15b going in this summer and turning up the boost!!
« Reply #130 on: October 15, 2009, 06:09:04 PM »
Are you gonna be at the track on the 24th?   Mini rHMT meet?   :yes:
speedjunky01
« Reply #131 on: October 15, 2009, 07:52:35 PM »
sounds good as long as its in the afternoon/night time i work the AM, also brink some bkr7e plugs i cant find them anywhere up here, obviously you will be compensated in crack cocaine. also who else will be there? if its just two cars i dont think it will be worth the hour or so drive unless some tuning is done lol
car sounds nasty and IAT's are stupid low ambient or lower, car sounds cool approaching nice spooling sound.
not sure if i got the turbo XS mbc hooke up correct, bottom port on MBC to bottom of WG, side port of MBC to vac/boost source this sound right??
« Last Edit: October 15, 2009, 07:59:06 PM by speedjunky01 »
« Reply #132 on: October 15, 2009, 08:12:07 PM »
I wil be there
Rosario4124
And a few uninlisted fools
speedjunky01
« Reply #133 on: October 15, 2009, 08:13:13 PM »
I wil be there
Rosario4124
sounds like a plan, bring your laptops to help me get my turd tuned fully !! lol
« Reply #134 on: October 15, 2009, 08:15:13 PM »
sexy.  i can't believe how much stuff is crammed in there.
you using the stock air box for the air cleaner?
speedjunky01
« Reply #135 on: October 15, 2009, 08:22:30 PM »
yeah it looks ever crazyer in person lol im trying to get a catch can in there too lol
yup stock box with a stock filter fits right in :D i was gonna put a cone fiilter inside the box but the box is too small for the KN filter i have laying around.
speedjunky01
« Reply #136 on: October 23, 2009, 06:11:15 PM »
the new exhaust thanks to rcautoworks.com for a good deal
also broke down and bought a copy of ectune. program looks nasty so far but still havent started tuning the car just working on a basemap
if anyone could make me a decent basemap would be awesome!!!
« Last Edit: October 23, 2009, 06:13:08 PM by speedjunky01 »
Re: boosted 4dr...now with 3" no muffler goodness
« Reply #137 on: October 23, 2009, 07:40:36 PM »
you using a demon or ostrich?
speedjunky01
« Reply #138 on: October 23, 2009, 08:59:04 PM »
ostrich 1 and honda log
tunerview 1 is in the mail got it for fairly cheap
xsenceo89x
« Reply #139 on: October 24, 2009, 02:41:07 PM »
Sick build dood. Im loving that ram air. I think I might try it with some pvc pipe I have lying in my basement. Any different in spool time and IAT?
speedjunky01
« Reply #140 on: October 24, 2009, 03:33:55 PM »
thanks man, pvc should work fine, a 3" 90 deg bend fits PERFECT into the bottom of the air box, i trimed the rubber on the bottom to help it seal a bit
no full tests yet but just looking at the log while cruising its ambient or slightly below it
« Reply #141 on: October 25, 2009, 04:53:52 PM »
definitely a baller setup. my first config had A/C and the plumbing was a PITA!
I upgraded to a Holset turbo and lost that privilege.. but most great things in life come with a consequence  :evil:
speedjunky01
« Reply #142 on: October 25, 2009, 09:49:46 PM »
holset is def. more important then AC lol
im kinda thinking about moving the condenser forward to make more room for a holset once the motor is built, ill have to see where the jackie chan turbo takes me first
got the car up and running now just need to finish fabbing up the exhaust and bleed the clutch and she is don, and about damn time!!! vid is just showing the intake working, rev between idle and 2000ish rpm
z6 turbo front bumper intake
just waiting on a magnaflow muffler i picked up for 40 bucks
boosted 00 black si
« Reply #143 on: October 27, 2009, 03:18:46 PM »
sounds nice!! u almost sucked that bag in lol   :yes:
go fuck your self
BORN TO BOOST
LITTLE B16.400whp on 16psi
speedjunky01
« Reply #144 on: October 27, 2009, 06:34:14 PM »
almost took my hand it when i stuck my hand there and reved it to antilag lol
got the exhaust on and magnaflow straight through= PURE SEX!!!!
hope to have a sound clip later tonight
« Last Edit: October 27, 2009, 09:51:35 PM by speedjunky01 »
speedjunky01
« Reply #145 on: October 27, 2009, 09:59:59 PM »
got the car just about done, the exhaust is only tacked together since i ran out of fluxcore gonna have a shop finish it up.
RCautoworks.com has a GREAT exhaust kit to say the least!!! will have pics after its on the lift at the shop
overall i love the way it sounds super deep zero rasp and the car feels like it has a bit of TQ not its not just top end. cant wait to tune it on ectune!!! calvin if fixing my license issues right now
sorry if its still processing
rHMT turbo z6 maganaflow 3"
having a small issue though the BOV is sticking a open a bit when the car is in vac, under boost its fine, this is making it build boost flow and the part throttle area run like ass, i was thinking switch the small spring thats in there with the big one, should hold it shut since its stiffer.
hate on
« Last Edit: October 27, 2009, 10:18:51 PM by speedjunky01 »
« Reply #146 on: October 27, 2009, 10:05:56 PM »
d16z6 turbo 3" maganflow
hate on
Linky no worky
speedjunky01
« Reply #147 on: October 27, 2009, 10:09:01 PM »
Linky no worky
yeah youtube is being a pile of aids and processing slow as a mexican processes english
speedjunky01
« Reply #148 on: October 27, 2009, 10:16:00 PM »
fixed!!
« Last Edit: October 27, 2009, 10:19:05 PM by speedjunky01 »
« Reply #149 on: October 28, 2009, 12:01:03 AM »
sounds not nearly as obnoxious as the 3" open dump just past the firewall.  between the solid motor mounts and not having the shifter boot on, my car almost requires earplugs right now.
when do we get ripper vids?
Pages: 1 ... 3 4 [5] 6 7 ... 11   Go Up
