Pages: 1 ... 8 9 [10] 11   Go Down
Author Topic: boosted 4dr...OFFICIALY jdm since pg 6  (Read 244994 times)
Re: boosted 4dr...OFFICIALY jdm since pg 6
« Reply #270 on: May 05, 2010, 04:57:17 PM »
my 272/260 on the LS has a very light lope to it. But I heard that the 272/272 beats the ground!  :evil:
speedjunky01
« Reply #271 on: May 05, 2010, 05:00:41 PM »
I hope so!!! hahah
almost ashamed im running an exhaust on this think now
« Reply #272 on: May 05, 2010, 05:01:03 PM »
I have used delta regrinds in non vtec sohc's for 5+ years. For the price they cant be beat.
speedjunky01
« Reply #273 on: May 05, 2010, 05:01:59 PM »
I have a spare y7 cam/head that i plan on using in another motor just for fun
« Reply #274 on: May 05, 2010, 05:04:45 PM »
Wat aboot having them rip off some skank2 PRO1s for the boat anchor??????
« Reply #275 on: May 05, 2010, 05:06:06 PM »
I know they were doing some b series vtec copies but had some issues this was a couple years ago.
speedjunky01
« Reply #276 on: May 05, 2010, 06:07:21 PM »
Never hurts to call the issue with going big is running out of base circle on the cam, you can only cram so much lift/dur "inside" the stock lobe.
« Reply #277 on: May 05, 2010, 06:13:34 PM »
I saw with my own eyes a set of flat b series skunk copies delta did years ago. Those pro cams are fuckin huge.
speedjunky01
« Reply #278 on: May 05, 2010, 09:41:29 PM »
i love being done with school  :mexi:
gotta stay organized all the bearings will be recycled back into the motor they look minty fresh
should I keep going deeper with the notch? I used a pice of 3/4 tape to mark out the width then i went about 1/4 inch up into the sleve and 1/4 back into the block and connected
speedjunky01
« Reply #279 on: May 06, 2010, 12:32:55 AM »
Help a nig out notch deep enough? Really don't want to reassemble just to see if it is :P tell me if you think I should take more out
« Reply #280 on: May 06, 2010, 08:50:42 AM »
I took out a little less material then you with good results. :yes:
But you should be fine.
I follow this article for help. http://www.theoldone.com/articles/d_series_engine_building_tips/
speedjunky01
« Reply #281 on: May 06, 2010, 11:24:56 AM »
Yeah I went with endyne as well time to go finish it up I guess!! Hope I can start assembly tonight
speedjunky01
« Reply #282 on: May 06, 2010, 12:32:26 PM »
hmmm i dont have a stretch gauge. . . fuck Wonder if i could just TQ them down or if the stretch is absolutely  necessary
« Reply #283 on: May 06, 2010, 12:45:50 PM »
I have had success with just torquing them down.  :yes:
speedjunky01
« Reply #284 on: May 06, 2010, 04:50:13 PM »
well finally got a vale spring compressor got the intake side done
should be good until 8000rpm if power doesnt start falling off
ill finish it all up after some lunch
speedjunky01
« Reply #285 on: May 07, 2010, 11:02:46 AM »
 im having an issue with the rocker assembly such a pain in the ass and it wont set down flat over the cam  any tips on installing it? im fallowing the helms manual
cam at TDC, all the adjusters loose, make sure non of the rockers are binding(this is where vtec SUCKS lol) and it wont go down over the cam, some of the rockers are also suer tight over the valve spring. I emailed crower to see if there is a diff between in/ex springs
« Reply #286 on: May 07, 2010, 11:43:04 AM »
Had similar issues but I just got all the cam cap bolts in and slowly tighten down from center out.
One turn at a time. :?:
But it worked, I'm using the same springs w/ a stock y8 cam ATM. ;D
speedjunky01
« Reply #287 on: May 07, 2010, 11:57:10 AM »
yeah the helms says that i should do it one turn at a time, the thing that worries me is that once of the rockers is sooooooo tight on top of the spring even with the adjustment bolt turned all the way out
im gonna hop out and try it again
« Reply #288 on: May 07, 2010, 02:48:12 PM »
Yeah watch the valve end of the rockers so they do not get caught on the edge of the valve stem.
If you do it one at turn a time you just look the valve stems and see when the rocker tips get stuck. ;D
speedjunky01
« Reply #289 on: May 10, 2010, 06:16:26 PM »
well i got the rocker assembly on no problem, just worked noce and slow and it went on but for some reason the cam will NOT turn over im trying to get it so i can adjust the valves.
I think the royal purple lube is just to freaking sticky and its just not letting it spin easy at all.
92cxyd good tip worked great
speedjunky01
« Reply #290 on: May 10, 2010, 09:54:20 PM »
so im gonna hope to have the rings gaped tonight
did some math from 1st ring:
.006 x 3.00 = .018
2nd Ring:
.0065 x 3.00 = .0195
oil rails between .010 - .050
all from Laskey racing
Laskey Racing Online Store
this is for boost only
« Reply #291 on: May 10, 2010, 10:02:39 PM »
.006 x 3.00 = .018
2nd Ring:
W/ my 75.5mm vitara I gapped mine @ 0.018" (1st) & 0.020" (2nd) and the oil rails had plenty gap  ;D :yes:
speedjunky01
« Reply #292 on: May 10, 2010, 10:06:53 PM »
im just doing them straight .019 a .001 isnt gonna b the end of the world
also you really helped me out last time with the tip and the rockers came down great but im still having trouble getting some of the rockers being stuck down i think the royal purple is to sticky! the cam wont rotate to save my life more then 5-10*
« Reply #293 on: May 10, 2010, 10:29:51 PM »
isnt that a delta cam?  i just installed a crower 2 and i didnt have anyh problems with it.
speedjunky01
« Reply #294 on: May 10, 2010, 11:19:42 PM »
yeah it is i bet its just something dumb Im doing
got all the rings gaped and placed them according to endyne, arrow facing the flywheel :)
they look a little thicker eehhh?
notched up for some room, went a little deeper then i needed but better safe then sorry LOL
just gonna wash it really well tomorrow if im not to tired (work in 4 hrs :() and put the block together
thants it for now :D
« Last Edit: May 10, 2010, 11:25:34 PM by speedjunky01 »
speedjunky01
« Reply #295 on: May 11, 2010, 02:29:48 PM »
about to go put the rods in just want to confirm how to install without a stretch gauge the FJT rods with ARP bolts
43ftlb, with ARP lube.
45ftlb with 10w30 engine oil.
tq then loosen 3 times then TQ one final time any confirmation on this?
speedjunky01
« Reply #296 on: May 12, 2010, 10:15:58 PM »
 O0 :yes: :noel: .011 p2w SON LMAO
also checked the "recycled" stock bearings all spec out between .001 and .0015 :D
just have to find a damn 10x1.25 tap none of the local stores have ANY pissed all of the ARP's went in smooth minus one :P
hope to have it in this weekend on a basemap for break in, then the boost wil go to NOG asap
speedjunky01
« Reply #297 on: May 19, 2010, 09:55:46 PM »
ok so did some more work today
got the head TQ down, threw the IM on, ported the oil pump, got the oil pan re-welded just in case haha, put the oil temp sender on, started working on making the snail fit
before porting:
a nice 90 turn should help flow :D
she looks so tight needs loosening
after
forgot to get a before sorry but was all just sharp 90* shit
looks rougher then it is but will be better then the sharp corner
opened up!
oil temp location fluxcore OWNS ALL
the turbo would hit the oil dip stick so what to do besides fuckiing use a cut off wheel and a flapper wheeel to clearance that BITCH
shocker your ass china snail!
got the oil warmer on now to figure out how the hell i should plumb it, any tips?
« Reply #298 on: May 19, 2010, 10:33:41 PM »
I ran one hose that goes to the heater first to the oil cooler/heater then to the heater core.
Worked for me. ;D
Or look at the hose routing for the VX model and use their routing.
speedjunky01
« Reply #299 on: May 19, 2010, 10:36:38 PM »
Worked for me. ;D
wouldnt that mean it would only be warming/cooling if the heat was on?
ill have to flip through the helms on redpepperracing.com but the pics are fucking HUGE so its a pain to look at
also got this off a b18 or some shit not a VX
« Last Edit: May 19, 2010, 10:38:59 PM by speedjunky01 »
Pages: 1 ... 8 9 [10] 11   Go Up
