Pages: [1] 2 3 ... 11   Go Down
Author Topic: boosted 4dr...OFFICIALY jdm since pg 6  (Read 245066 times)
speedjunky01
« on: April 20, 2009, 08:07:57 PM »
well my first two builds were FAIL 00 coupe caught on fire, 99 hatch got rear ended.
onto older and better things!!!
about to pick up a 93 EX 4 door
has 232k on her, going to boost it untill it blows up (should be pretty quick) and in the meantime I will be building the JDM d15b
wish me luck, 3rd time is the charm?
kit thats going on her
will have to hack it up a bit so the IC pipes fit the EG.
previous fails:
« Last Edit: November 20, 2009, 02:30:56 PM by speedjunky01 »
Re: boost atempt number 3. . . 4 doohs fo' mo' ho's!
« Reply #1 on: April 20, 2009, 08:19:29 PM »
Damn I like your old coupe. But I'm an OG 4 door civic gangster too.
speedjunky01
« Reply #2 on: April 21, 2009, 11:24:30 PM »
That black coupe looks nice.
yeah it was. . . had a ton of good things done to it. o well WTF can you do
the beaners tried to jip me( WTF else would you expect) so i got the price down to 1000
car is in great shape, very minor and easy to fix body work needed, new batery, new brakes, and axles are needed
not a big deal since i have two space civics sitting around.
this is the ABS model so it came with rear disks as far as i know :D
anyone know what I should be able to swap over from my old suspension/car setup? should be just about everything i assume tie/strut bars are all the same, shocks will work on the eg (tokicko blues) front rotors and pads are the same. dont think illl need anything else
the ABS light is on in the car and it stops poorly feels like the pedal is very soft, will bleed the system with fresh fluid and change the rotors tomorrow, any other ideas on what would cause the light to go on?
my goals are to get the car running very very well and get the suspension/brakes sorted before I delv into boost. The car needs to be prepared for the added stress of being turbo.
I've also decided that ill be redoing my charge pipes/down pipe to make it AC and PS compatible. This kind of car is really hard to find in this good of shape would be a shame to gut the fuck out of it IMO.
/rant . . . . . porn
speedjunky01
« Reply #3 on: April 23, 2009, 10:26:40 AM »
ok so a small update, got the alternator swapped out and it runs great now.
onto the suspension, what is compatible off my 99 hatch? I figure all of the mad typeR JDM braces are, but what about the subframe brace for the rear swaybay? turns out this car already has a rear sway, I plan on swapping over the 15mm one and the brace if it fits.
would the camber kit's (front and rear) swap over??
Im also fixing the brakes today, have new disks and hawk HPS pads going on the front. I looked at the back and it has disks from the factory :D will be putting the same on the back when i can. also the lines are very very rotted, would the SS lines off the hatch fit?? the pedal is super soft and the car stops like shit, hope its not as mushy once i bleed the sytem.
speedjunky01
« Reply #4 on: April 28, 2009, 08:51:51 PM »
picked up some more aluminized 2.5 bends today, going to face the turbo the other way in order to keep the AC and PS.
not sure about the WG placement right now but ill figure it out when I come to that.
I just finished lowering it with the eibach springs and tokicko shocks, and i put the flat black rota C8's on it pics coming soon.
Also looking for red/clear tails( like the 99-00 ex not ricer shit) black housing fronts, amber corners, fogs, and a front and rear lip, already have sideskirts from my old car. anyone know where i can get this shit from the same seller for a good price on ebay? shipping it all separate is rape
Colin
« Reply #5 on: April 30, 2009, 03:00:33 AM »
Looks awesome. Does the wastegate clear with that manifold? I was thinking about picking one up for my car.
speedjunky01
« Reply #6 on: April 30, 2009, 09:03:39 AM »
it clears on the EK chassy not sure about the EG should find out tonight or tomorrow for sure
speedjunky01
« Reply #7 on: May 01, 2009, 12:08:46 AM »
ordered a pre-loved LSD clutch 6 puck sprung 350ft/lbs
should be perfect once i finish the other motor. d15b with vitaras and FJ custom rods.
« Reply #8 on: May 01, 2009, 12:55:48 AM »
Your wastegate will rub one of the ribbs on the hood... It does on mine..
speedjunky01
« Reply #9 on: May 01, 2009, 01:11:13 AM »
no big deal then, ill just cut some of the ribs away around the gate.
i plan on filling the mounts so movement shouldnt be a big deal
thanks for the heads up though
should have the mani and turbo on it tomorrow afternoon, just waiting on mandrel pipe to ship in so i can start on the DP
speedjunky01
« Reply #10 on: May 03, 2009, 10:58:31 PM »
ok so need some advice from you folks.
I found some standard 137mm rods eagle rods and vitaras for a good price.
now im trying to figure out What CR a JDM d15b will have with this setup
using zeal auto calc i input d15 block and crank, as well as z6 head and standard y8 gasket i got 8.27:1 cr
does this account for the pistons sticking out the .022?
hope you guys can help me out on this so i can have a built motor sooner
« Reply #11 on: May 03, 2009, 11:18:52 PM »
Looks good to me unless the vitaras are oversize 0.5mm or 1.0mm.
As long as that d15b is jdm and not usd then yes the 137mm rods would work.
speedjunky01
« Reply #12 on: May 03, 2009, 11:26:41 PM »
yup jdm d15b
getting them for about 300 bones shipped :D
trying to lowball the shit out of the guy lol
vitaras have slight scratches on the skirt from poor notching, said they were never ran just mocked up. . . idk getting kinda fishy. . .
iyi0521
  • N00B *Read Intro Sticky*
« Reply #13 on: May 03, 2009, 11:45:42 PM »
pics please
speedjunky01
« Reply #14 on: May 03, 2009, 11:55:49 PM »
got a closer pic, will polish off them never got to rings was only at the very bottom
wither way decent buy for 300 bones even come with new NPR rings
« Reply #15 on: May 04, 2009, 12:00:38 AM »
I pd $60 for Y.C.P. vitaras
  pd $20 for rings
  pd $100 for used TT rods (same as eagles) w/o bolts
  pd $70 for bolts
Total $250 for vitara and rods for my setup
If I can get them that cheap maybe you could talk the guy down to $250 after shipping just maybe. ;D
speedjunky01
« Reply #16 on: May 04, 2009, 12:07:18 AM »
yeah after looking at them more closeley they are in new shae aside from super light scratches so a good deal. plus FJ vitaras are slightly better then other( according to himself :-P) but his rods wont require machining and will come with ARP 2000 bolts
what are your oppinions on just re-using the bearings that are in the engine already?
its a very very fresh d15b 30,000 or so on it. although some of it was a little harsh it was always on synthetic and changed ever 3000. IDK Ill end up just buying some from honda most likely, just the d15b is ghay d16 rod bearings and d15 mains
gonna have to pick up 2 sets
« Last Edit: May 04, 2009, 12:22:46 AM by speedjunky01 »
« Reply #17 on: May 04, 2009, 08:37:37 AM »
FJ vitara = Y.C.P. vitara > NPR vitaras  ;D
If the engines is that fresh just make sure that when using the eagle rods with the old bearing that you still plasti-gauge them first.
Make sure they are still within spec. beacuse you may not like the results later.
speedjunky01
« Reply #18 on: May 04, 2009, 08:40:53 AM »
yeah i planed on plsting them anyhow. I want to try and just leave the mains alone but i have to take the cap off to tq the rods :-P
you can see the scratches on the piston way tp the right on the bottom of the skirt, he gave me another close up pic but cant find it.
« Reply #19 on: May 04, 2009, 08:42:50 AM »
Not bad what does the tops look like?
speedjunky01
« Reply #20 on: May 04, 2009, 08:50:31 AM »
new nothing on them
« Reply #21 on: May 04, 2009, 09:10:12 AM »
I say go for it. ;D
speedjunky01
« Reply #22 on: May 04, 2009, 12:39:40 PM »
I say go for it. ;D
now i just need to find a "how to" on building the motor, gaping rings, TQing everything correctly,i found instructions on notching the block on "theoldone" ECT ECT ECT ECT lol
i have a helms manual for a civic but its for 96-00
also mandrel bends shipped out today :D hope to have the DP and IC pipes done by weeks end
speedjunky01
« Reply #23 on: May 07, 2009, 08:47:02 PM »
so reason i got the car for a good price was it needs four new calipers
FUCKING  :somb:!!!!
anyway. . . hope that makes the ABS light go off, front and rears now have brembo blanks and Hawk HP+. went to autozone and got new front calipers, bleed the system, the rears arent stoping at all
fronts get cooked when stopng hard but the backs are doing nothing. . .
bleed it many many times still the same results
any ideas on the ABS light? im downloading a pdf of all civic manuals, ill make a torrent and post it once the whole file is loaded
« Reply #24 on: May 08, 2009, 01:00:03 AM »
ABS pump ???
speedjunky01
« Reply #25 on: May 08, 2009, 01:51:42 PM »
ABS pump ???
pulled the ABS error code using a paper clip, its code 1 pump motor over run, looking into the helms right now to see wtf that means lol
MAJORAHOLE
  • fuckin C-unt
« Reply #26 on: May 08, 2009, 04:05:27 PM »
if you need some calipers on the front i got a pair of the the oversized front hype-r/prelude vtec calipers i could sell you
speedjunky01
« Reply #27 on: May 08, 2009, 08:31:37 PM »
na finally got the right ones from vato-zone :-P they gave me the DX non abs ones, got rear ones too for my troubles for free just cores trade in lol
4 new calipers about 100 bucks not bad :)
car stops like crazy, brakes the stock rubber loose way to easy, almost no fade either. I would highly recomend hawk HP+ pads!!
now just need to get the abs working, looking for a pump on ebay right now.
also GF's grandma has a lift, ill be using it monday for teh boost building :D lots of pics to come
« Reply #28 on: May 08, 2009, 10:15:10 PM »
So it was the pump?
« Reply #29 on: May 08, 2009, 11:33:56 PM »
Damn your making me wanna start on my shit, problem is I gotta wait till next week to wrap up all my parts... !!!!!! GL with build.
Pages: [1] 2 3 ... 11   Go Up
