Author Topic: anti-theft ideas.  (Read 17219 times)
anti-theft ideas.
« on: April 22, 2009, 07:54:19 PM »
I made a thread on the old site about this..
I've got some new ideas though and I'd like to share.. maybe a fab guy on here could make a few.
Basically, a steel box that covers your steering wheel column, so the thief cannot break the steering wheel locking mechanism to unlock it.
ideas? suggestions?
Re: anti-theft ideas.
« Reply #1 on: April 22, 2009, 07:57:57 PM »
this reminds me I gotta post some pics of some "anit-theft" shit I've done recently.  :noel:
« Reply #2 on: April 22, 2009, 08:06:19 PM »
i will stick to my cigarette lighter for a push button starter.  no lighter, no starter.  also i use my cruise control button for ign
« Reply #3 on: April 22, 2009, 08:09:50 PM »
locked garage and a shotty.
« Reply #4 on: April 22, 2009, 09:01:03 PM »
Alarm system disables all relays by removing the relay ground circuit.
except lights.
IGN, Fuel, Starter, etc. are disabled.  Or you could make it blow a main fuse by using a relay to short it out if someone tampers with your car
« Reply #5 on: April 22, 2009, 09:10:50 PM »
couldnt you put some sort of momentaly push button inline with the starter signal wire and route it into the cab?
« Reply #6 on: April 22, 2009, 09:25:32 PM »
Could, but the object here is to do something kinda different to thwart thieves
« Reply #7 on: April 22, 2009, 09:27:00 PM »
Garage/large dog/gated yard
« Reply #8 on: April 22, 2009, 09:30:05 PM »
I unfortunately do not have that convience, so its a 12ga and my custom installed alarm system.
« Reply #9 on: April 22, 2009, 10:00:27 PM »
come with a tow truck.
« Last Edit: April 22, 2009, 10:14:27 PM by junkyard racer »
hotrex
« Reply #10 on: April 22, 2009, 10:02:54 PM »
thats what im talking about...  MY HONDA IS PROTECTED BY BENELLI
« Reply #11 on: April 22, 2009, 10:16:21 PM »
Take your ecu inside with you at night...Or everytime Its a pain in the ass but your car is there in the morning...
You can also make a small custom harness that takes out sections of your engine harness... and other main wires that are needed to run the car...
Kill switches
Take the main relay in the house
Spot lights that are motion actived
stealthiskey
« Reply #12 on: April 22, 2009, 10:27:39 PM »
ideas? suggestions?
like thiiiiiis?
g_shok
  • SuperSport
« Reply #13 on: April 22, 2009, 10:42:20 PM »
theft deterent indeed, if anyone sees that theyd walk away
« Reply #14 on: April 22, 2009, 11:00:07 PM »
Here's my take on anti-theft devices.  :P
« Reply #15 on: April 22, 2009, 11:57:57 PM »
ok
caged
« Reply #16 on: April 23, 2009, 02:10:25 AM »
My A/C button is a fuel pump ground cut.
Tre West
  • Solid Gold Studio Assassin
« Reply #17 on: April 23, 2009, 02:24:25 AM »
No one will steal your car if you drive this.......
Or this.............
And If you drive a car like this.....Pray that someone steals it... And I'll pray for your brain to evolve from monkey to man.
« Last Edit: April 23, 2009, 02:31:18 AM by Tre West »
caged
« Reply #18 on: April 23, 2009, 02:48:36 AM »
Unfortunatly all of these would not be safe in my suburb. O0
« Reply #19 on: April 23, 2009, 03:02:51 AM »
niggers will steal anything just as long as they can sell it to get their fix on
BoostForLife
« Reply #20 on: April 23, 2009, 03:25:46 AM »
Usually I just put my ecu into my trunk and arm the alarm, also have a couple of switches for ignitions and fuel in the cabin.
BTW: On my del sol, trunk is only accessible by key, so storing ecu and possibly the main power switch in there would be a good idea as well.
« Reply #21 on: April 23, 2009, 04:12:52 AM »
The best way to avoid theft is to sell everything you own and live in a cardboard box.
Ghetto_D
« Reply #22 on: April 23, 2009, 04:30:13 AM »
So when your out collecting cans someone is just going to steal your box anyways
« Reply #23 on: April 23, 2009, 04:45:09 AM »
kinda of over the top, but i used to live at the end of a road, and would pad lock and chain my car to the street light.  i used locking lugs on my already curbed ass rims, 2 heavy duty locks and 'towing grade 3' chain.  not impossible to steal, but deffinately not easy.
« Reply #24 on: April 23, 2009, 04:47:42 AM »
post up the ideas
I think I want to put a fuel cut off switch in.
using the ground. need to find a good switch and a place to hide it
« Reply #25 on: April 23, 2009, 09:56:08 AM »
ideas? suggestions?
Fuck you I got the idea of steel box before you ;) lol
It's a serious option since it is how they have stolen my car.
I had an idea: put 2 wires in the gas tank over the fuel level pluged to a 20000Volt coil and if you forget to press on a button, the gas tank explode with the spark of the coil.
Other then that, a switch for ignition, a switch for ECU a switch for gas pump and an eject button ;)
ShoofIsLudin
« Reply #26 on: April 23, 2009, 10:05:34 AM »
you can use the clutch switch.  Re-route the wires to a momentary switch.  They can still push start it, but i could throw them off.  On top of other things... fuel pump ground cut switch under the carpet, into the back of the seat.
BoostForLife
« Reply #27 on: April 23, 2009, 01:19:08 PM »
That's either suicide or a murder charge.
What if your button breaks?
I would not blow up my own fucking car because some dipshit tried to steal it.
Ghetto_D
« Reply #28 on: April 23, 2009, 01:44:49 PM »
Bury this somewhere deep in the dash, or a vent where it can be herd but not found. It will deliver 139db's of ear peircing lovingness. Hook it up to a pressureswitch on the seat, so when they sit in the seat it goes off or to the main relay, or another power source that will constantly stay on to piss off the theives and make them go away, and wake up half the neighborhood in the process.
« Reply #29 on: April 23, 2009, 02:07:02 PM »
I guess you won't agree with my shotgun idea then... ;)
