Author Topic: rhmt trolling motor  (Read 11805 times)
DSharp
rhmt trolling motor
« on: August 06, 2013, 11:30:12 PM »
rowing sucks dixs
Re: rhmt trolling motor
« Reply #1 on: August 06, 2013, 11:38:39 PM »
Well does it work, have ya tried it?
« Reply #2 on: August 07, 2013, 12:44:56 AM »
It will cavitate. It will spin at to high of a rpm. Any you dropped your oatmeal on the ground.
« Reply #3 on: August 07, 2013, 12:42:35 PM »
I'd think a 4cyl trimmer would be best, lower RPM & higher torque. My guess is he's not going for speed records, so it wouldn't be run a full RPM. Those things idle around 1200rpm, the speed the prop was designed for, so I don't think 3-4k will cavitate too bad. I think the biggest issue will be burning the clutch if no weights are added.
« Reply #4 on: August 07, 2013, 12:46:23 PM »
Technically this would be called a reed wacker...
« Reply #5 on: August 07, 2013, 03:13:30 PM »
I'm interested to see how it goes, but yea, the rom is way too high to be properly efficient. It will still move though.
« Reply #6 on: August 07, 2013, 04:02:05 PM »
I think the load will keep the rpms down
DSharp
« Reply #7 on: August 07, 2013, 06:17:56 PM »
well see tomorrow, I have been thinking about putting a cone behind and possibly in front of the prop and smoothing things out.  if it works at all its a hell of a lot cheaper than an outboard
« Reply #8 on: August 07, 2013, 06:28:29 PM »
So at what point is noise a factor in fishing? Is that 2 stroke wound out gonna be loude enough to scrae the fish away? At any rate its way less than a electric outboard.
« Reply #9 on: August 08, 2013, 10:20:29 AM »
Good point.  I know the load is what makes your mom go down.
« Reply #10 on: August 08, 2013, 12:55:43 PM »
ZING!
n/a mike
  • Mr. Hotpocket
« Reply #11 on: August 08, 2013, 09:56:08 PM »
So did we get trolled or is it a trolling motor?
it's not supposed to be fast, it's for trolling.
you can pick up a trolling motor on CL for about the same it would cost to make what you did.
except you probably had the shitty wacker laying in your back yard.
« Reply #12 on: August 08, 2013, 11:47:32 PM »
Ripper vids?
Zombie killing vids?
« Last Edit: August 08, 2013, 11:49:36 PM by Phate »
DSharp
« Reply #13 on: August 09, 2013, 12:39:11 AM »
this thing needs a reduction gear box, the motor doesnt have the torque to spin it direct drive. im just gonna buy a dam outboard.
« Reply #14 on: August 09, 2013, 12:54:50 AM »
Smaller prop?
DSharp
« Reply #15 on: August 09, 2013, 07:13:56 PM »
maybe a big rc boat prop.
« Reply #16 on: August 21, 2013, 03:00:23 PM »
Nitromethane?
Travis
« Reply #17 on: August 22, 2013, 11:25:54 PM »
minnkota prop?
« Reply #18 on: August 23, 2013, 09:58:44 AM »
Just keep chopping a 1/2" off the blade tips til it works. If it spins at 3x the speed, it only needs 1/3 the prop.
« Reply #19 on: August 23, 2013, 10:02:03 AM »
That idea would work better if you could put 2 blades in there clocked 90° apart. Smaller diameter and high rpm needs more blades.
« Reply #20 on: August 26, 2013, 09:24:01 AM »
More blades in the water requires more torque to move them. They "bite" more, and also create more drag.
« Reply #21 on: August 26, 2013, 09:29:34 AM »
If all you did was make those 2 tiny blades smaller it would cavitate and do nothing. 4 smaller blades would be easier to spin than the 2 bigger ones and he might have a chance of forward motion.
« Reply #22 on: August 26, 2013, 07:20:42 PM »
180 degrees apart I hope?
« Reply #23 on: August 26, 2013, 08:52:59 PM »
90° would be better. 180° would put them in the same place as the others
DSharp
« Reply #24 on: August 31, 2013, 04:29:49 PM »
I did shave down the prop, turned the weed eater wide open and shoved the prop down on the concrete lol, I even went through the trouble of sanding the edges smooth.  still too much drag from the high rpms.  My 2 hp sizuki outboard works much better.  anyone ever put a tuned pipe on a 2 stroke outboard?   :evil:
re: rhmt trolling thread
« Reply #25 on: August 31, 2013, 10:14:55 PM »
