Pages: 1 2 3 [4] 5 6 ... 9   Go Down
Author Topic: Ohisofly's 91 Crx  (Read 356556 times)
Re: Ohisofly's 91 Crx
« Reply #90 on: January 28, 2014, 12:51:49 AM »
In front of the rad. There's room. And you won't have to cut your gill out.
« Reply #91 on: January 29, 2014, 02:05:03 AM »
Dude Makes me want a sink trap but my welding skills lack your luster lol. What turbo you running I haven't gone back to earlier posts?
ohisofly
« Reply #92 on: January 29, 2014, 05:18:42 PM »
Yea I probably should have done a little more research before I decided to go the route I did but oh well, I'll definitely keep your idea in mind for when my brother goes turbo with his ef hatch
Hah thanks man and the turbo is a Garrett TA34, compressor .60 a/r and turbine .63 a/r
91 Crx Si - turbo ls vtec
ohisofly
« Reply #93 on: January 29, 2014, 05:30:37 PM »
Pics from rebuilding the turbo
Now hardly any shaft play
ohisofly
« Reply #94 on: January 29, 2014, 05:35:50 PM »
Picked up this thing
Here's roughly where the intercooler will need to sit to give the manifold enough clearance, I'm going to wrap the bottom half on the manifold to help a little bit
Middle
Side
Manifold mostly done, still needs wastegate flange welded on and I need to clean up the inside
ohisofly
« Reply #95 on: January 29, 2014, 05:42:04 PM »
Went over the welds to make it look pretty
Tried getting the snapped off bolts out but the screw extractor snapped off in the process, so tried welding a v band on there. The weld split down the middle as we thought it would so I need to get a propane torch to heat it up and then we'll try that again
Parts coming in the mail:
-innovative traction bar
-v band conversion for the wastegate
-heat wrap and metal cable ties
-2 stainless 2.5" 90 degree pipes for the downpipe
That's all for now
« Reply #96 on: January 29, 2014, 05:57:27 PM »
Metal cable ties are to baller. I use hose clamps.
« Reply #97 on: January 30, 2014, 08:20:10 PM »
I used zip ties lol they never melted
« Reply #98 on: January 30, 2014, 11:54:21 PM »
truth.... but i obviously only use one per pipe. just wrap it tight at the start, then at the end toss a clamp on.  :Jew:
« Reply #99 on: January 31, 2014, 07:25:23 AM »
I found metal cable ties at Walmart dirt cheap
ohisofly
« Reply #100 on: February 02, 2014, 01:49:13 PM »
Guess I need to start thinking more rhmt hah anyways looks like I'm going with ratcityrex's idea of the vw radiator because too much modification would be needed for my half rad. I'm pretty much going to make a little cage/skid plate to support and protect the intercooler because it's going to be out in front and sitting just as low as the traction bar. Here's the goods
Downpipe
Collector before
Collector after, might clean it up a little more
Traction bar
ohisofly
« Reply #101 on: February 02, 2014, 01:53:10 PM »
Getting a rough idea of what I need to cut for the intercooler. The crossmember will have the middle section cut out and the styrofoam will need some trimming
Guy on ebay sent me the wrong size flange so hopefully I get the right one for free
ohisofly
« Reply #102 on: February 09, 2014, 02:34:18 PM »
Got this inline filler neck but didn't realize it was for a larger size rad cap, most likely I'll still use it though
Downpipe mocked up
Might make a second one like this  O0
I was cleaning out the tech library at work, thought you guys would find this cool
ohisofly
« Reply #103 on: February 09, 2014, 02:41:59 PM »
Would it be better to use an intercooler like ratcityrex did or use the stock evo9 intercooler? I'm aiming for around 300hp, guess I could always make adjustments if I need a bigger intercooler down the road. I already have the evo intercooler but just looking for input since a ton of stuff will need cut for the evo intercooler to fit
« Reply #104 on: February 09, 2014, 03:27:33 PM »
Rock the evo ic. It will have better airflow and not try and get as warm as mine did. Mine would like to push 200° while driving down the hwy. Mine blocked more air than let through.
« Reply #105 on: February 10, 2014, 01:42:42 AM »
you could go with a str4 intercooler it would fit nice. Just don't get a 6" deep one lol
« Reply #106 on: February 10, 2014, 12:05:02 PM »
DO WORK!
« Reply #107 on: February 10, 2014, 01:22:19 PM »
Lol like the one I sold you? That thing is a fucking beast.
« Reply #108 on: February 10, 2014, 09:55:23 PM »
fits perfect n the da don't think the ef bumper sticks out far enough.
ohisofly
« Reply #109 on: February 11, 2014, 11:10:23 AM »
Thanks for the heads up, looks like I'll be going with the evo intercooler
DO WORK!
I'll put up the pictures when I have time but I started working on the wastegate placement. I also got a piece of bar that should work well for mounting the intercooler; it'll be welded to the traction bar and then stick out towards the front.
« Reply #110 on: February 11, 2014, 12:16:04 PM »
Should be fun once it is done!
« Reply #111 on: February 11, 2014, 01:05:56 PM »
I really like this:
I may be coping this for my Twincharge civic update.  :noel:
ohisofly
« Reply #112 on: February 11, 2014, 08:24:10 PM »
I really like this:
Do it  O0
Here's the mock-up of the wastegate placement
« Reply #113 on: February 13, 2014, 10:06:18 AM »
You'd want the "teardrop" or radius of that WG tube to bend the other way, but ideally you'd have the WG on the front or back side of that collector to intersect both tubes. If it stays fully divided and you only intersect one of the up-pipes for the WG, you will end up with high backpressure on 2 of the cylinders and low backpressure on the other 2. On diesels it doesn't matter nearly as much.
You could also use 2 small tubes going straight up from the bottom horizontal tubes into a mini collector that is topped off with the WG. That would keep it fully divided.
ohisofly
« Reply #114 on: February 14, 2014, 06:39:55 PM »
Thanks for the heads up. I had a feeling that would be an issue so I posted in the fabrication sub forum a little while back and someone told me it'd be fine  ??? Oh well. I'll look at it tomorrow and see which option would be better and report back with the results
ohisofly
« Reply #115 on: July 21, 2014, 07:15:12 PM »
Due to life this project went on the back burner but now I don't work weekends so I actually have some free time to work on this  ;DDD I think it looks good considering it's made out of two eBay headers
The vw rad isn't going to fit (I'm not mutilating my bumper, already cut the support in half as you can see) so I guess I'm going to rock the ebay rad, make a shroud and hope for the best
« Reply #116 on: July 22, 2014, 12:00:33 AM »
My vw rad fit perfect without touching the rad.
ohisofly
« Reply #117 on: July 23, 2014, 07:09:22 PM »
It'll fit if my intercooler (stock evo9) was an inch thinner but other than that I would have to cut the 'grille' which isn't an option
« Reply #118 on: July 23, 2014, 10:41:28 PM »
It must be because your turbo manifold sticks out further than mine did. My vw rad tucked up perfect to the back of the hood latch support. How thick is a evo 9 ic? My ic was 2.75" thick.
ohisofly
« Reply #119 on: July 24, 2014, 09:29:51 PM »
Not sure, I'll get some measurements this weekend if I remember. Yea this manifold setup is less than ideal, I kinda regret going down this route with the sinktrap style but I guess that's the whole point of rhmt so we'll see how it does. I'm interested to see if I have any issues with the recirculated wastegate since I've heard mixed things on that
Pages: 1 2 3 [4] 5 6 ... 9   Go Up
