Author Topic: Jz swap into 92 toyota pickup (now NSFW)  (Read 28425 times)
« on: July 26, 2009, 09:55:34 AM »
Should I do this?
Truck needs engine and trans, body is decent.  Thinking of swapping in a 1jz-gte, or a 2jz-ge to turbo later.
Any experienced input would help, if I do this shit, its gotta run within a month and make a 600 mile trip
« Last Edit: August 26, 2009, 08:45:18 PM by Conceptz-X »
Re: Jz swap into 92 toyota pickup
« Reply #1 on: July 26, 2009, 12:52:47 PM »
Should I do this?
1jz swap are getting cheap. Wiring is not to bad either.
« Reply #2 on: July 26, 2009, 02:11:10 PM »
Having to ask is Fail. Post porn for to recover.
« Reply #3 on: July 26, 2009, 07:59:10 PM »
Your right, as soon as I get a good monitor for my laptop, porn will insue, untill then, I'm restricted to a shitty blackberry internetz.
I was just wanting some input, just something I thought would be cool to do seeing as how my 22re is fucked and so is the trans.  BTW, I may be moving to Indy in september, and need this shit done before then.
« Reply #4 on: July 26, 2009, 11:16:07 PM »
302 would be cool
The jz was a thought, the 22REs thrust washers were in the pan, block and crank are fucked, trans is fucked in 3 4and 5 pops out of gear, I'd say may be the thrust, if it were only like 4
E-b0la
« Reply #5 on: July 26, 2009, 11:29:56 PM »
fuck a 302
swap a 2uz. tundra 4.7
TheMadScientist
  • I'm like Batman and Shit
« Reply #6 on: July 26, 2009, 11:48:55 PM »
for the sake of getting it done quickly and simply a carb'd 302 is your best bet if your not going with a 22re. However a JZ swap either one would be sweet. but like was said before if your asking then you probably can't get it done in time.
« Reply #7 on: July 27, 2009, 09:01:49 AM »
just get a 2wd v6 drivetrain throw on some headers and swap the wiring over.
Im inclined to agree with this Jordan.  While the JZ is superior overall, the 5vz is a hell of alot cheaper and can hold up to a fair amount of boost bone stock.  Also, you should know that much like a 302, the headers are symetric on the VZ series and can be swapped from either side to face the front = easy turbo setup.  I have a friend who pioneered the mr2/5VZ swap and his budget was sub-$1000 turbo and all.  You can probably get away with a piggyback too.
Your biggest problem with this swap wont be making power, it will be traction.  Go ahead and buy some sandbags and toss em in the bed.  ;)
« Reply #8 on: July 27, 2009, 10:00:56 PM »
I think the 302 will be my best option, parts are dime a dozen and they are plentiful.
Thanks for the input guys, porn and boost to come still.
89shithatch
« Reply #9 on: July 28, 2009, 04:28:32 AM »
i vote 22re. or even 22r.
klyph
  • Proletariat for Life!
« Reply #10 on: July 28, 2009, 06:53:43 AM »
22rte
« Reply #11 on: July 28, 2009, 08:26:02 AM »
22rte
So he can replace rod bearings with every oil change?  I think not.
Stock 302 w/100 shot and slicks you'll have little problem running 11's Jordan.
« Reply #12 on: July 28, 2009, 03:29:57 PM »
22rte
RTE was an original consideration, but I decided against it.
The 302 however is plentiful everywhere, parts are cheap, and they take a lot of abuse.  I'm scouring the locals here in GA and AL to see what I can find before going to the bone yards.
caged
« Reply #13 on: August 01, 2009, 01:30:14 AM »
My mate had a 1j hilux, we built a big hp 2j but he sold the car before it went in. This car was fucken fun, it would out launch an evo on the street.
http://www.youtube.com/user/MrJoshTaylor#play/all/uploads-all/2/k3WbyVxlUuI
« Reply #14 on: August 01, 2009, 10:48:45 PM »
It aint hard to out-launch an awd car on the street. Slicks only suck in the rain ;)
Jordan, if you need any sbf info, all the hardcore fuckers at my shop are phord guys.
« Reply #15 on: August 01, 2009, 11:18:37 PM »
its been done, so you can find good write ups on it.  youll have a shit eating grin, and thats priceless.
Toysrme
« Reply #16 on: August 06, 2009, 09:40:10 PM »
7m-gte
5vz-fe1uz-fe
no point in swapping a 22rte. overpriced old torqueless blahs that only gets worse when you swap the turbo off it to a bigger one.
and dont get a 2jz-ge planning to turbo it later. youll get better mileage, less reciprocating weight, 33% more displacement and have the same rought unbuilt / built power limits a 2jz-ge will have with a 1uz-fe.
« Last Edit: August 06, 2009, 09:46:28 PM by Toysrme »
« Reply #17 on: August 07, 2009, 09:49:50 AM »
7m-gte
5vz-fe1uz-fe
1uz-fe aint all its cracked up to be.  1L more displacement with less room in the engine bay, old worn out oil leaking engine with a billion miles on it (most the -92 blocks are now).  Or settling for the thin rod motors is a waste since rods will run you upwards $1000. Then your limited in your transmission options.
2jzge with a 2mm headgasket and the P2W clearanced to the turbo specs and you will have an efficient turbo engine that will last longer than the truck.  Never mind that the 2jz is generally cheaper as its easier to find than a 1uz.
Not starting an arguement here, just offering a different perspective on the variables.  All things being equal, the 1uz has it on paper, but not in the real world or this site where cheap is god.
Toysrme
« Reply #18 on: August 07, 2009, 07:15:00 PM »
the rods are atleast 100hp weaker than the best sets toyota was making on the earlier v8/v6/i6's. despite improving the metallurgy while slimming down the rods (they did NOT improve the metallurgy until more rescently which is where the problem arose.)
but you're still distributing that load over 8 instead of 6.
for USDM i find the 1uz-fe's to be easier to find  & in better condition for less than a grand than the 2jz-ge's. you can get's the two stronger JDM v6's imported for even less.
and throwing a huge monkey wrench into it you can have complete (with turbo, managementless) JDM 2jz-gte's imported & at your door for $1500.
« Reply #19 on: August 08, 2009, 08:27:03 PM »
I think we can both agree that the 5vzfe is def the best cost/power for this swap of the toyota options.  Its really an awesome motor whose limitations are really just in the cams.  Bolt to many diff transmissions and millions of parts trucks laying around.
TTC
« Reply #20 on: August 08, 2009, 09:07:32 PM »
What rwd tranny would u put behind the 5v if you went 2wd?  Will the W or R series work?
« Reply #21 on: August 09, 2009, 12:46:03 PM »
Both work with the rwd pickup bellhousings. Also, vz motors bolt up to S-series trannies.
E-b0la
« Reply #22 on: August 10, 2009, 07:43:02 PM »
I vote 5vz-fe. They are a good motor. The one in my truck has 210,000 on it.
The cams produce good low end torque. I bet if you had a quick spooling turbo it would produce nasty low end torque.
I've heard 3vz cams make a nice combo on the 5vz-fe. More mid-range power.
I'm not entirely sure if the motor will bolt in or not.
« Last Edit: August 10, 2009, 07:44:34 PM by E-b0la »
Toysrme
« Reply #23 on: August 11, 2009, 04:20:19 AM »
erd on the cams. 5vz-fe falls on its fucking face instantly. 3vz-fe's rev out
can't swap 3vz-fe cams into a 5vz-fe. i forget why, but the truck guys were looking into it years and years back & noone could ever get it done.
5vz would be the easyest swap because its the most knonw
« Reply #24 on: August 11, 2009, 04:03:06 PM »
I have a hole 1uz swap with trans for $500, im in Nj take the trip up :noel:
DzMiniz
« Reply #25 on: August 13, 2009, 10:46:24 PM »
« Reply #26 on: August 14, 2009, 09:22:05 AM »
« Reply #27 on: August 26, 2009, 08:39:57 PM »
going 302, parts areeasy to get if I break anything.  Possibly later throw the VGT holsets on it.
Kickin the wife to the curb so the 408 isnt getting boosted.  she's keeping the stang, I get my sanity.
« Reply #28 on: August 26, 2009, 08:44:10 PM »
Almost Forgot...
deeznutts
Re: Jz swap into 92 toyota pickup (now NSFW)
« Reply #29 on: August 26, 2009, 11:16:39 PM »
the bitch on top is banging but raven is as played out as ohmt and the last bicth aint gonna cut it
fuck xeno
