Author Topic: another one of my little ideas  (Read 24639 times)
toyolla86
« on: October 12, 2009, 09:20:06 PM »
so i was thinking about making a little tubing maker.
for aluminum only.
twin50 son. get some
and stop acting like a muslim
toyolla86
Re: another one of my little ideas
« Reply #1 on: October 12, 2009, 09:20:45 PM »
oh yeah forgot to add that it (the tubing) would be made from sheet metal.
figured you guys could assume that much but just in case. the tool would be made from heavy iron
« Reply #2 on: October 12, 2009, 10:13:14 PM »
you'd need a mamajama hinge and probably some hydraulic pressure behind it unless you're using aluminum foil
« Reply #3 on: October 12, 2009, 10:39:28 PM »
what purpose would this serve? you can buy aluminum tubing reasonably cheap
toyolla86
« Reply #4 on: October 12, 2009, 11:17:31 PM »
damn.
yeah aluminum foil would work perfect in my little apparatus.
hahahah.
naw i dont know it was just an idea.
and also as soon as i bent it the sides would be perpendicular and hitting the handle. thus it would
have to be cut to the precise measurements before hand.
i was thinking of bending like 12 inch sections at a time. and welding the halves together.
toyolla86
« Reply #5 on: October 12, 2009, 11:18:23 PM »
or what about preheating the metal.
toyolla86
« Reply #6 on: October 13, 2009, 11:58:18 AM »
hahahah what?
that would defeat the purpose man.
then i wouldnt get to build anything.
« Reply #7 on: October 13, 2009, 12:04:24 PM »
it's fucking tubing, just buy the shit.  ::)
toyolla86
« Reply #8 on: October 13, 2009, 05:31:02 PM »
dude when youre a tightwad like me you spend more just to save.
the junkyard never fails.
they always have good aluminum tubing.
bigwig
« Reply #9 on: October 13, 2009, 06:42:59 PM »
You're a fucking idiot.
« Reply #10 on: October 13, 2009, 07:55:10 PM »
Way to be cheap.......    Gotta watch the line though......   There's cheap then there's stupid....
toyolla86
« Reply #11 on: October 13, 2009, 08:40:02 PM »
EASY!!! EASY!!!
not everybody can be a "bigwig" like you.
« Reply #12 on: October 13, 2009, 10:39:43 PM »
Unless you are tying to make some ungodly large diameter tubing, I really do not see the point.
Simpler idea:
Press
Ditch the hinges and let your device become a set of dies.
An even simpler idea would be to employ the use of a set of slip rolls.  Then you could make all kinds of different radius rolls and even be able to create tapers as well without using an unnecessary amount of materials just to create the machine.
« Last Edit: October 13, 2009, 10:41:47 PM by snm95ls »
toyolla86
« Reply #13 on: October 14, 2009, 12:53:15 AM »
Simpler idea:
Press
good idea. and with the latter wouldnt that eliminate one of the welds. making it a single seam tube.
bigwig
« Reply #14 on: October 14, 2009, 02:04:16 AM »
Ever use a set of slip rollers?  Yeah, have fun......
Again, you are a fucking idiot.
toyolla86
« Reply #15 on: October 15, 2009, 12:46:03 AM »
dude stop acting like a muslim.
« Reply #16 on: October 16, 2009, 10:09:20 AM »
what are you trying to accomplish with this that you cant easily and cheaply buy already made?
im not trying to bash cause i am a big fan of making things yourself, but i usually dont make my own raw materials. it just seems like more trouble than its worth unless you are making something that isnt redily available
« Reply #17 on: October 16, 2009, 10:29:23 AM »
lol you have too much ideas
toyolla86
« Reply #18 on: October 16, 2009, 02:07:12 PM »
true. hahah i am always coming out with some stupid idea
that takes more time and energy than its worth.
its just fun.
oinesra
« Reply #19 on: October 17, 2009, 12:20:11 AM »
If you can get aluminum stock leftovers, you can use a 3lb sledge and pound out your own sheets.
caged
« Reply #20 on: October 17, 2009, 01:10:42 AM »
lol  :mexi:
lsone_chevelle
« Reply #21 on: October 18, 2009, 03:08:04 PM »
This has to be by far the most retarded fucking post on this site to date.
Bravo on the epic retardation of a fail.
« Reply #22 on: October 31, 2009, 01:46:09 PM »
I think you might have missed this one
http://www.realhomemadeturbo.com/forum/index.php?topic=6461.0
« Reply #23 on: November 03, 2009, 03:45:29 PM »
dude live in salt lake city, ut.  he already has a rating of 'douche bag +5'
« Reply #24 on: November 08, 2009, 09:31:37 AM »
And there's a %95 chance he's a fucking mormon...
« Reply #25 on: November 08, 2009, 10:04:27 AM »
Jesus wept.
« Reply #26 on: November 08, 2009, 03:34:13 PM »
The only reason you may want to do this is for oval tubing. But even then you'd need a very long "press", and cutting/welding sheet+round tube would be far easier.
« Reply #27 on: November 08, 2009, 10:18:39 PM »
its like telling the retarded kid to stop banging his head while riding the bus...... let this mother fucker ride his little yellow bus...
