Pages: [1] 2 3   Go Down
Author Topic: Suggestions for donor car drivetrain, give your input!  (Read 35210 times)
TunerToys
« on: November 17, 2009, 11:14:57 PM »
Okay guys, so this is just a mental exercise of sorts, to get some creative thinking going for a project I may undertake...someday.  I want to build a daily driver custom vehicle out of an old truck, but put a modern day drive train in it.  Here are a few requirements.
 - It must be new enough to be managed by a modern ecu, OBD1 or OBD2.
 - It must not be so new that the donor car would be more than $10K
 - 300Hp minimum in it's stock form
 - Inline drivetrain, not any tranverse mount stuff.
 - Gasoline / E85 Only, no diesel.
 - Car donors only, with excellent ride quality, no truck donors.
 - Four wheel independent suspension.
 - Autotragic transmission
Tunability is a consideration for later, but not required for consideration.  Performance can come later, a comfortable cruiser is more important initially.
Some of the vehicles I thought of were...
 - Lexus GS430
 - Cadillac CTS
 - Lincoln (anything with a Modular Motor and independent suspension?)
I kind of like the Lexus idea, watching jaws drop when I pop the hood of a classic ford truck, to reveal an asian drivetrain.  And the reliability would be solid too.
So lets see what you guys come up with.
Craig
Re: Suggestions for donor car drivetrain, give your input!
« Reply #1 on: November 17, 2009, 11:20:14 PM »
Lincol Mark VIII has a 32V 4.6 V8, fords strongest auto, 93 had an aluminum driveshaft, 8.8 IRS, even has air ride you could incorporate if you wish.
« Reply #2 on: November 17, 2009, 11:20:44 PM »
I don't think 1940 internationals came OBD1. Just a guess.
« Reply #3 on: November 17, 2009, 11:21:02 PM »
do you want to do what everyone else does or something different?
« Reply #4 on: November 17, 2009, 11:22:08 PM »
You do understand what the OP asked right?
bryantaylor
« Reply #5 on: November 17, 2009, 11:22:16 PM »
well you mentioned lincoln, a mark viii would be cheap and work out great.  4v mod motor, 4r70w trans a 8.8 IRS rear end.  all pretty standard stuff that you can easily get parts for and have very few problems.
90 miata - t3 and megasquirt
95 mark VIII
06 GSX-R 600
 i changed my sig as per Robb
« Reply #6 on: November 17, 2009, 11:26:37 PM »
complex stfu you dumb nigger. can't you read
TunerToys
« Reply #7 on: November 17, 2009, 11:26:51 PM »
on the plus side i see your example is opposite of your requirement.
Yeah, I'm pretty tricky that way.
how about a 2uz or a 4.6 mod or a lsx/lqx in a 70's celica?
Although I love the early 70s Celica, I'd prob put an S2000 drivetrain in that one.
I want to stick with a reasonably full sized truck for the body of this project.
« Reply #8 on: November 17, 2009, 11:27:22 PM »
Bah, skimmed and didn't read right. Whoops
TunerToys
« Reply #9 on: November 17, 2009, 11:27:58 PM »
Different, that's why I threw the Lexus drive train in there.. you have ideas?
speedjunky01
« Reply #10 on: November 17, 2009, 11:30:20 PM »
rx7 and lsx
done a few times where the parts are readily avialable, will handle nice, wont fail like a rotary, pleanty of support to make more power if wanted
« Reply #11 on: November 17, 2009, 11:32:36 PM »
you fucking tards. A TRUCK. THIS IS GOING IN A GODDAMN OLD TRUCK.
speedjunky01
« Reply #12 on: November 17, 2009, 11:35:20 PM »
could be why we got confused
« Reply #13 on: November 17, 2009, 11:37:44 PM »
how much money do you have?
new camaro is irs
svt cobra is irs
any corvette that is obd1. prob started with the lt1s
« Reply #14 on: November 17, 2009, 11:38:05 PM »
my vote is for 03/04 SVT Cobra
« Reply #15 on: November 17, 2009, 11:41:28 PM »
new camaro is irs
svt cobra is irs
Apparently you can't read either.
 - Autotragic transmission...
« Reply #16 on: November 17, 2009, 11:45:09 PM »
Anything AMG.
« Reply #17 on: November 17, 2009, 11:45:43 PM »
yea you're right i owned myself.
i still vote for 03/04 svt cobra
or c4 corvette with lt1
« Reply #18 on: November 17, 2009, 11:49:48 PM »
do a Cummins diesel swap  :noel:
« Reply #19 on: November 17, 2009, 11:50:38 PM »
It's minister, how the fuck could he possibly understand.
TunerToys
« Reply #20 on: November 17, 2009, 11:59:48 PM »
Anything AMG.
Oh hell, now that's interesting.  A mercedes or bmw donor?  Hmm, that could be as much fun as an asian drivetrain. Parts would be expensive tho.
« Last Edit: November 18, 2009, 12:02:08 AM by TunerToys »
TunerToys
« Reply #21 on: November 18, 2009, 12:01:16 AM »
craig, do you have a truck already for this?
I don't own it yet, but I have one picked out.
« Reply #22 on: November 18, 2009, 12:04:07 AM »
U should change your mind and do a diesel  :yes:
« Last Edit: November 18, 2009, 12:10:05 AM by 88dx »
« Reply #23 on: November 18, 2009, 12:11:38 AM »
+1 CR cummins.
Hotrodlincoln
« Reply #24 on: November 18, 2009, 02:06:08 AM »
what have you picked? why not grab an old studebaker truck? antique dead mfg with efi motor would be neato
Studebaker has absolutly no room in the cab for anything, and very little room in under the hood for modern electroncs and so forth. I did a small block chevy swap added airconditioning and even with the gas tank removed and seat set back ( gas tank is inside the cab from factory) it was very uncomfortable. The guy i built it for ended up selling it because it was so uncomfortable.
kill yourself piss face
« Reply #25 on: November 18, 2009, 02:46:39 AM »
I'm going to toss in my vote for Lincoln Mk8, but one caveat: they may be a 4V, but they aren't the Cobra 4V.  Some corners were cut and if you want to breathe on it you'll have to replace a few things.
FYI, a lot of the emissions bullshit can be turned off very cheaply in the mid-late 90s Ford ECUs, super tuneable and stable.
« Reply #26 on: November 18, 2009, 03:44:55 AM »
+1 CR cummins.
4bd or 4bt on 75lbs should do it
« Reply #27 on: November 18, 2009, 08:45:42 AM »
rx7 and lsx
done many many times.
« Reply #29 on: November 18, 2009, 02:47:47 PM »
SC300 drivetrain are cheap as fuck + lots of aftermarket for 2JZ.
Pages: [1] 2 3   Go Up
