Author Topic: POS DSM Project **DYNO SHEET ON PAGE 1**  (Read 26008 times)
« on: October 29, 2011, 05:58:46 PM »
Ill find the pic that I had before it looked like this, and I will update this fucker a little later
**DYNO SHEET**
« Last Edit: December 05, 2011, 01:32:41 AM by glustic »
Re: POS DSM Project
« Reply #1 on: October 29, 2011, 07:26:41 PM »
Wow a 4g63? So what, like 40 pounds of boost brah?
Re: POS DSM Project
« Reply #2 on: October 29, 2011, 10:32:52 PM »
A 2G?  Is that a 6 bolt swap, have you pinned the 7 bolt girdle to the block, or are you wasting our fucking time faggot?
Re: POS DSM Project
« Reply #3 on: October 29, 2011, 10:33:41 PM »
Hopefully 60...
Haha I just want a decent track car, and a car to drive during the winter. Im sick of spending $400 a month in gas
Re: POS DSM Project
« Reply #4 on: October 29, 2011, 10:34:28 PM »
More than anyone elses im wasting yours sweetheart  :-*
Re: POS DSM Project
« Reply #5 on: October 29, 2011, 10:43:52 PM »
I hope you haven't gone through the bottom end in the last couple years as that rerolls the crankwalk dice.  "Most" 7 bolts can handle 300whp, if it's been together for years without coming apart it can probably take 400.
Re: POS DSM Project
« Reply #6 on: October 29, 2011, 11:34:13 PM »
Wasn't the crankwalk narrowed down to a very large run of bad bearings?
Re: POS DSM Project
« Reply #7 on: October 29, 2011, 11:42:53 PM »
The 7 bolt problem is the main girdle isn't pinned to the block like every other girdle, ever.
Re: POS DSM Project
« Reply #8 on: October 30, 2011, 12:17:49 AM »
lol wat? how the hell could they have missed that?
Even my cheap desk has alignment dowels. and it doesn't spin at 7000 rpm.
Re: POS DSM Project
« Reply #9 on: October 30, 2011, 01:24:35 AM »
Thanks for the advice sir, and to tell you the truth I dont know if its a 7 or 6 bolt.
Flipnog said its a galant vr4 motor (well IM) so im ASSuming its a 7 bolt
While Im quoting you... Any other way to tune these fuckers other than dsmlink or standalone?
Re: POS DSM Project
« Reply #10 on: October 30, 2011, 05:47:27 AM »
GVR-4 are 6 bolt motors.  In that chassis it's like putting a heterosexual into skinny jeans and sending him undercover to the gaybar, but whatever.
98-99 plastic case ECU is reflashable via Tactrix cable.  Also Evo8 or Lancer ECU.
Re: POS DSM Project
« Reply #11 on: October 30, 2011, 11:16:01 PM »
Meh I cant fucking complain. I got the car for free.. Well..
I sold the civic for 4K + this car
Also, is the plastic housing black?
like this one?
http://www.ebay.com/itm/97-98-99-MITSUBISHI-ECLIPSE-TURBO-ENGINE-COMPUTER-ecm-ecu-MD359402-EXCELLENT-/320782883780?pt=Motors_Car_Truck_Parts_Accessories&vxp=mtr&hash=item4ab0265bc4#ht_500wt_1341
« Last Edit: October 30, 2011, 11:28:00 PM by glustic »
mrgreengenes
Re: POS DSM Project
« Reply #12 on: November 01, 2011, 01:56:51 AM »
yes
also, the 6 bolt engine is identifiable by the oil pan.  It will be flat across where the crank pulley is, whereas the 7 bolt ones will drop down in an arc.
and, the 7 bolts have 7 bolts.
Re: POS DSM Project
« Reply #13 on: November 05, 2011, 10:15:11 PM »
Been putting this front mount on... Had my buddys shop put the front bumper and headlights in... And this is what I discovered
Mother fuckers put bolts in under the headlights, so I had to pull the headlights (im a lazy fucker!)
Painted the pipes black
Trash can paint booth ftmfw!
As she shits now...
Funny thing is I bought these off a dude that took them off his 2g.. they dont fit worth a fuck without some fabbing..
Currently looking for a bigger turbo, injectors, black box ecu, tactrix 2.0, and fuel pump, and ill be getting tuned
Re: POS DSM Project
« Reply #14 on: November 08, 2011, 07:08:36 PM »
You can run one of the Evo8 ECUs, or some of the 4cyl Eclipse/Lancer ECUs of that era.  Search thoroughly before buying, and keep in mind you have to purchase the correct KS for the ECU ($58 at the dealer).
Just an idea as the right ECU for the '97 my boss owns has been a bit of a pain to find.
DasPoop
Re: POS DSM Project
« Reply #15 on: November 08, 2011, 09:08:01 PM »
Open bov. Interesting.
Re: POS DSM Project
« Reply #16 on: November 14, 2011, 01:07:55 AM »
So I do have a 6 bolt... score!
So I decided on getting the small 16g. Its actually in great condition.
Install process:
Got all the bolts off the o2 housing minus the one behind the o2 sensor, so off came the manifold.
And the bitch bolt
It was such a PITA that this is what bent....
Yes your reading that right... its a BENT MAC wrench!
So I bought some PB Blaster, and off it came. And what did I find? A broken wastegate tophat! What the fuck has my cousin done to this car????
All done:
Lower IC piping on.. ran into this little problem... already ordered a 180 silicon coupler and some t bolts
Decided to install this little gem
And I got the slim fan wired in and mounted
That is all the updates I have for now. I will keep you guys posted.
Re: POS DSM Project
« Reply #17 on: November 21, 2011, 01:52:24 PM »
I wired up the fan right... but it didnt kick on when I drove it... Coolant was boiling when I got the car back home... So I grounded out a few wires going to the ECU and now when the ignition is ON both the radiator and condenser fans turn on
Moar pics of outside
boosted 00 black si
Re: POS DSM Project
« Reply #18 on: November 21, 2011, 04:15:43 PM »
looks good but u need a mans turbo  :noel:
go fuck your self
BORN TO BOOST
LITTLE B16.400whp on 16psi
Re: POS DSM Project
« Reply #19 on: November 22, 2011, 12:53:49 PM »
i thought it was gonna be a track car
Re: POS DSM Project
« Reply #20 on: November 23, 2011, 02:22:27 PM »
Hopefully 60...
The turbo I want is a 20g its brand new for $500... I will be getting a bigger turbo + bigger injectors soon...
I got my tactrix cable, black box ecu, and fuel pump! I will update you fuckers as soon as I get that shit put in tonight
Re: POS DSM Project
« Reply #21 on: November 24, 2011, 02:55:01 AM »
you should go speed density and sell me your MAF/intake LOL...  :Jew:
Re: POS DSM Project
« Reply #22 on: November 24, 2011, 09:16:34 PM »
Sure. $500
Re: POS DSM Project
« Reply #23 on: November 24, 2011, 10:01:06 PM »
slightly cheaper one on ebay...seriously. like 300bucks...some DSM people are crazy with there prices...
Re: POS DSM Project
« Reply #24 on: December 02, 2011, 05:28:08 AM »
Updates havent updated this shit in a long time, but have done alot of work...
Decided to remove the 5 LBS of bullshit speaker wires...
Fuel pump install...
Good bye piece of shit fuel pump!
Flashable ECU installed with basemap + launch control flashed..
Ricer bumper finally removed (dumb fucks had it molded to the body with about 1/4 inch of fiberglass)
Yes you see a shower curtain rod holding up the hatch... fuck you!
And you can't forget the finishing touches... Gotta represent in Vegas (Heading down for a tune + drag strip tomorrow)
Re: POS DSM Project
« Reply #25 on: December 02, 2011, 07:57:40 AM »
WIN
Re: POS DSM Project
« Reply #26 on: December 02, 2011, 09:34:26 AM »
You can't say win about a DSM.  Gluestick has, however, earned a hearty GOOD LUCK!
Re: POS DSM Project
« Reply #27 on: December 02, 2011, 09:44:02 AM »
Is your cousin's name Bennett by any chance?
Re: POS DSM Project
« Reply #28 on: December 02, 2011, 11:32:25 AM »
Building someone else's garbage DSM makes me think his name is Bennett.
Re: POS DSM Project
« Reply #29 on: December 02, 2011, 08:27:36 PM »
I'm building my DSM..
Anyways made 227 whp on a mustang Dyno @ 14 lbs on a small
16g
