Pages: 1 ... 4 5 [6] 7 8   Go Down
Author Topic: Jacer's 63' Nova Twin build.. Update..Parts showed...  (Read 196141 times)
Re: Jacer's 63' Nova Twin build.. FUcking wiring...i hate.... pics inside..
« Reply #150 on: March 07, 2013, 01:59:15 PM »
DO WORK!
« Reply #151 on: March 25, 2013, 06:24:57 PM »
No update in a month, bump.
« Reply #152 on: March 25, 2013, 06:27:27 PM »
Talked to him the other day. Said he has it running, but has to do a cam swap. Only pulling 6" vac at idle is making a bitch to even idle he said.
« Reply #153 on: March 26, 2013, 09:39:34 AM »
Sounds like its time to go alpha-n
99gsrturbo
« Reply #154 on: March 29, 2013, 09:01:05 PM »
He's doing the cam swap now. I have seen the pics on facebook just waiting to see them here.
JACER63
  • well shit..
« Reply #155 on: April 19, 2013, 03:43:09 PM »
sorry guys been lazy posting pics and shit... quick update.. yes did cam swap and thats done then starter decided to shit bed and eat up flexplate. parts ordered and should recieve today.. reinstall and finally should be able to run it off the jacks this sun. then i will update with all new pics and shit... the car sounds fantastic and iam pumped..
alpha-n does not su[pport boost..need speed density, hence the cam swap... removed ionner valve springs and broke in the cam.. then reinstalled inner's and ran it once when the starter shit... it did pull 14in at idle 1000 rpm..should work.. went from 108 lsa to 113 lsa.. lil less intake dur and lift .507 284d and .525 306 d exh. idles way smoother... more to come
JACER63
  • well shit..
« Reply #156 on: April 19, 2013, 04:38:31 PM »
so previously stated needed a cam swap ... went with the comp cams  .507 284 in/.525 306 113 lsa.  needed to remove inner valve springs for break in steps.. use air to seat valves..
worked like fucking a slutty stripper in vegas...
all in order and proper holes..
then i just repeat process for reinstalling springs...
broke the bitch in 2500 rpm for 29 mins with occassional burps to splash oil; on cam yada yada
then starter took a shit .. and ate flywheel up.. as stated.. starter cracked the shoulder leaving it to move a tad and ate the fuck out of the flexplate.. and it would not disengage.. trouble
flexplate damage... it was old and been through 3 starters..
and new starter..
so now iam waiting here on a rainy friday waiting for my flexplate to arrive.. since the first one they sent wrong..gotta love summit shit is 2 days out on orders..
some random shit pics ...
this how to remove flexplatre with tranny still in car.. move the tranny back 2in and viola...
now here's the final engine setup..
now i will try and putt this bitch around the block this sun. sat is shot i have a family deal..errr
need to dial it in and hope shits good before i trailer it 90 miles to lynnhood.. may need help on the tune?...
« Reply #157 on: April 19, 2013, 10:52:12 PM »
If I'm not at the track Sunday I want a ride
Minor Threat
« Reply #158 on: April 20, 2013, 04:57:03 PM »
Do you have carpet on your garage floor?
JACER63
  • well shit..
« Reply #159 on: April 21, 2013, 01:02:02 AM »
yep how we roll... nah jk its a throw rug my wife had.. its nice to lay on when working on your back...
« Reply #160 on: April 21, 2013, 06:11:54 PM »
Did it make it around the block?
« Reply #161 on: April 22, 2013, 02:29:21 PM »
x2
JACER63
  • well shit..
« Reply #163 on: April 22, 2013, 06:37:54 PM »
not yet... just finished up the resoldering the battery lead to starter.. didnt work on it yesterday.. duidnt feel well.
JACER63
  • well shit..
« Reply #165 on: April 29, 2013, 07:34:22 PM »
well turns out the map sensor was a lil fuckered.. ordered a new 2 bar fast.. waiting on it... then iill report..
99gsrturbo
« Reply #166 on: April 30, 2013, 04:51:27 AM »
This Nova's being a little bitch. If its not one thing its another at the end.
JACER63
  • well shit..
well got it run pretty damn good so far with the working 2  bar... finally took her around the block last night.. seems to run good.. now just need to clean up the map and hope for the best...lol  burnout vids soon to come!!!!
and yes ryan, this lil whore has been acting up at the wrong times!.. ill wrestle her down though
« Reply #168 on: June 11, 2013, 12:25:26 AM »
Bump
carkrazed
« Reply #169 on: June 15, 2013, 01:13:04 PM »
Well?  >:(
« Reply #170 on: June 15, 2013, 07:18:51 PM »
Should have called the Grand Wizard, happy to have given some advice... I just did a speed density Procharged 454 that pulled 5" at idle, had an electric vacuum pump for the brake booster.  Drives and idles great at all temps.
« Reply #171 on: June 16, 2013, 11:35:20 AM »
5" at idle surprises me that you didn't go tps. Was it not an option or am I too inexperienced? I haven't dealt with a cam that big yet
« Reply #172 on: June 16, 2013, 12:03:41 PM »
As someone else stated, you can't do that to a boosted car.
I get the feeling there might be a parts combo conflict here that wasn't exactly the cam.  Trying to idle too low an rpm (which can be bad for a big mechanical lash cam, i so equipped), or the wrong converter loading the motor and causing issues when dropped into gear.
« Reply #173 on: June 16, 2013, 12:06:28 PM »
People hate to gear it, but converters are fucking critical to getting a RWD car out of the hole.  A serious build usually requires 3-6 converter changes, working with a good converter guy, before you find what the car wants.  You ready to bleed some money and pull some trannies, bro?
« Reply #174 on: June 17, 2013, 09:31:10 AM »
Why couldn't you switch to map at 0psi kinda like an itb car? Again, curious and wanting to learn since I have yet to com across this.
« Reply #175 on: July 14, 2013, 02:34:27 PM »
Updates?
« Reply #177 on: August 19, 2013, 01:13:05 AM »
I need a link to this intercooler bitch.
« Reply #178 on: August 19, 2013, 02:45:50 PM »
Still Failed!!
JACER63
  • well shit..
« Reply #179 on: August 27, 2013, 11:31:16 PM »
well guys sorry for the lack of updates.. been super busy at work and other things... to bring you fella s up to speed..
aug 9th went to pacific raceways for a tnt session.. had a hell of a time passing tech .. master switch was being a wierdo.. finally passed and first run of the night pushed the hgs out.. lol
the car pulled hard until the  hg shit.. ran a 10.188 @ 100.21 .. 6.19 116 @ the 1/8th.. soon as  i hit 3rd gear the rad hose popped off and lifted..
so ordered .060 cometics and arp 12 pt studs... more to come...
Pages: 1 ... 4 5 [6] 7 8   Go Up
