Pages: 1 ... 4 5 [6] 7 8 ... 11   Go Down
Author Topic: boosted 4dr...OFFICIALY jdm since pg 6  (Read 245069 times)
speedjunky01
Re: boosted 4dr...now with 3" no muffler goodness
« Reply #150 on: October 28, 2009, 12:16:37 AM »
sounds not nearly as obnoxious as the 3" open dump just past the firewall.  between the solid motor mounts and not having the shifter boot on, my car almost requires earplugs right now.
when do we get ripper vids?
right now its breaking up once it hits boost
drove 1 fucking hour to get some bkr7e's :(
calvin is fixing my ectune license should be tuned this weekend if homework isnt over loaded, but im statring IV meds so IDK
« Reply #151 on: October 28, 2009, 01:14:22 AM »
damn, those meds sound serious.  hope all is well
is the car leaning out in boost?  that would definatley permote breakup.  is it drivable or does it break up sitting still?
speedjunky01
« Reply #152 on: October 28, 2009, 11:00:45 AM »
lol im not on the meds im learning how to give them :)
its fine part throttle and cruise but just in boost its breaking up bad
« Reply #153 on: October 28, 2009, 11:09:12 AM »
lol about the meds
what are the afrs when you are in boost?
speedjunky01
« Reply #154 on: October 28, 2009, 11:36:39 AM »
lol about the meds
no clue crome is being a whore and isnt logging quick enough 3rd or 4th pull :(
just waiting on ectune now
« Reply #155 on: October 28, 2009, 05:38:29 PM »
try freelog, its', well free and does a semi decent job on the afr logging.  can't figure out to get the map sensor to read where i can understand whats going on tho
speedjunky01
« Reply #156 on: October 28, 2009, 08:11:00 PM »
i have that, ecucontrol, its ok but i dont like switching the windows looking at each one and seting up the scalars is annoying, im just gonna wait for my license to come in
im gonna re-do the downpipe but im letting this one get trashed through the winter
speedjunky01
« Reply #157 on: November 19, 2009, 11:00:10 PM »
working on the new DP about 25% there
i know it looks weird but there was no way for me to get it to bend straight down, clear the compressor, and still be able to keep that stupid ass 5th bolt on the bottom of the flange. I rotated the pie cuts so that the bottom of the DP would point forward a bit towards the condenser then turns back down and to the ground.
gonna have a shitload of welding to do with these 15* whitey bends! lol
also if anyone has or can get a decently priced 2.5" mild v band would be AWESOME please PM me
« Reply #158 on: November 20, 2009, 01:21:37 AM »
Thats a tight bend lol
So it's a 2.5" merging into 3" ?
speedjunky01
« Reply #159 on: November 20, 2009, 01:27:52 AM »
2.5 i think im gonna go 2.5 all the way
speedjunky01
« Reply #160 on: November 20, 2009, 02:29:26 PM »
got the ksports, some pics, and they are packed away until spring lol
went with the balla coilovers instead of the tried and true GC/koni setup
speedjunky01
Re: boosted 4dr OFFICIALY jdm as of page 6
« Reply #161 on: November 20, 2009, 02:30:15 PM »
well my first two builds were FAIL 00 coupe caught on fire, 99 hatch got rear ended.
onto older and better things!!!
about to pick up a 93 EX 4 door
has 232k on her, going to boost it untill it blows up (should be pretty quick) and in the meantime I will be building the JDM d15b
wish me luck, 3rd time is the charm?
kit thats going on her
will have to hack it up a bit so the IC pipes fit the EG.
previous fails:
theidealone
« Reply #162 on: November 20, 2009, 11:09:16 PM »
Did you spend money on those leaky piles of fail?  :-X
Re: boosted 4dr...OFFICIALY jdm since pg 6
« Reply #163 on: November 21, 2009, 02:02:30 AM »
I have 1 vband flange. I used the other one as well as the clamp for the holset.
speedjunky01
« Reply #164 on: November 21, 2009, 02:49:52 AM »
i need a whole kit but thats a start lol
speedjunky01
« Reply #165 on: December 17, 2009, 11:15:13 PM »
some new sex from chris M
good work as always
www.polarbeartuning.com is good shit
pure pron
chris did a hell of a job for sure, also blended and smoothed the runners on the intake manifold, nothing crazy but looks great
« Reply #166 on: December 18, 2009, 01:16:24 AM »
I didn't know that I need the spacer to fit the 74mm bore. I'll have to order it this spring I guess.
« Reply #167 on: December 18, 2009, 04:17:13 AM »
If your running a 94+ b series intake manifold you dont need the spacer there is enough material to port match but the spacer is still recommend.
« Reply #168 on: December 18, 2009, 06:39:41 AM »
Thanks I love working on those d16z6 manifolds. 2010 has flow benched ported d16z6/d16y8/d16a6 heads in stock in the works.
Im going to have a couple budget options but I think 2010 will be another step forward for big power D's.
speedjunky01
« Reply #169 on: December 18, 2009, 12:59:32 PM »
ill prob be test mule #1 lol
« Reply #170 on: December 18, 2009, 01:05:01 PM »
not if i beat you to it
speedjunky01
« Reply #171 on: December 18, 2009, 01:06:12 PM »
i sell a lot of crack rock, the flow is not an issue lol
« Reply #172 on: December 18, 2009, 07:07:34 PM »
I have done plenty of sohc heads but to keep cost down Im going to see how much flow I can get out of them on a stock valve job. I have yet to do that with stock valve job but have 2 heads Im already working on.
1slow91hf
« Reply #173 on: December 19, 2009, 02:20:33 AM »
what kinda of  O0 money we looking at on the head work
i might have to ship you a head and IM to let you play with
« Reply #174 on: December 19, 2009, 07:43:39 PM »
Chris pm me a price, income tax is almost here ;)
« Reply #175 on: December 20, 2009, 04:56:00 AM »
+1 and what cam options if any?
El Beefo
  • tongue punch my fart box
« Reply #176 on: December 21, 2009, 10:37:08 PM »
That port work is pure SEX! Going for the same setup... 74mm tb, spacer, and ported z6. How much did it run ya?
speedjunky01
« Reply #177 on: December 21, 2009, 10:43:01 PM »
it is very very sexy, cant remember exactly how much but i sent Chris 3 cat converters which he buys then like 140ish on top of that I think
speedjunky01
« Reply #178 on: February 07, 2010, 05:28:26 PM »
sorry for the lack of updates but been crazy busy with school, work, hoe's you know how it is.
got the dp fitted after a million pic cuts, its tacked together but need to buy 3 spools of fluxcore to get it welded up LMAO no pics didnt have time to take it off and take a few.
picked up some GSR leathers like them a lot comfy as fuck and give the cheap ass interior a welcome upgrade. the foam in the drivers seat was worn down and I had metal stabbing me in the kidney when driving it.
i got a set of rears too but fitments is deff an issue haha.
the brackets are different :( also the portion of the seat that used to go around the seats doesnt fit.
anyone know of a way to make integra coupe rear seats fit a 4dr civic?
« Reply #179 on: February 07, 2010, 06:22:09 PM »
Ya!
Get the integra 4 door rear seats.....    ;)
Pages: 1 ... 4 5 [6] 7 8 ... 11   Go Up
