Pages: 1 2 3 [4] 5   Go Down
Author Topic: Ebay T3/T4 turbo takes the family wagon to 12.994 @ 107.38 mph  (Read 106852 times)
Re: Ebay T3/T4 turbo takes the family wagon to 12.994 @ 107.38 mph
« Reply #90 on: May 13, 2010, 12:21:48 AM »
Sleeving a fucking subaru is fucking $1500plus?
Saving that for the real wagon.....
Fuck $1500 :?:
How much is a stock block?
reddevil
« Reply #91 on: May 13, 2010, 01:13:23 AM »
See, the subaru blocks, ALL, except the LEGENDAERY 2.2 closed deck and custom whatever sleved, are all weak.
I could do the 2.2 closed deck block, but I just don't want to.
eh, got to go....
Story later.
« Reply #92 on: May 13, 2010, 04:43:52 PM »
eh, got to go....
Story later.
Is there a reason you wont? Or do you just like blowing shit up :noel:
reddevil
« Reply #93 on: June 12, 2010, 01:44:34 AM »
This was the problem.
So now I have.....
2001 Forester main transmission case. TY755VC1BA
1997 JDM STI 4.44 gear set, center diff and transfer case. TY72VBCAA
199? Legacy front diff and 4.11 pinion shaft/gear.
????? misc pieces from another year?
« Reply #94 on: June 12, 2010, 02:18:45 AM »
I would love to see what you can do with another car.
« Reply #95 on: July 01, 2010, 12:59:52 PM »
Just saw this : http://www.dragsport.com/issue/2010/0810_cover_story.shtml
Thought you might want to call the guys who built this if they are experiencing the same issue with their. And what they are doing to avoid breaking theirs.  ;D
reddevil
« Reply #96 on: July 01, 2010, 11:52:49 PM »
yeah, they built a twin charged setup years ago.
MONEY was invested.
MONEY MONEY MONEY was invested in the dragsport writeup....
If I had MONEY, I would be shitting weasels.   But since I am poor, I shit replacement parts.
DYNO TUNING TOMORROW!!!!!
I think I could hit 500 whp if I am stupid.....
Safety is 450....
Love that EBAY turbo.....
caged
« Reply #97 on: July 02, 2010, 05:53:32 PM »
Your epic failure of open deck 2.5 blocks and gearsets has convinced me to do another cheap subaru build haha ;) Subaru shits so cheap down here, picked up a jdm 4.4 Gearbox, plate LSD rear 4.4 diff and shafts to suit all for 350NZ (about 175$ US)  :P
Hey just wondering if the decapping on the early red sidefeed legacy injectors is the same as the top feed WRX's? I was worried that because they are micro welded ontop instead of on the side, that the cap holds the pintle and injector togeather? Also what cc' did you find the flow at after the decap?
reddevil
« Reply #98 on: July 02, 2010, 10:07:43 PM »
Reds go about 500-550cc flow.
reddevil
« Reply #99 on: July 02, 2010, 10:08:01 PM »
Ambient Temp: 65
Elevation: 250?
Weather: Clear
Tires: Toyo Proxes 4 205/55/16
Car: 1990 Legacy Wagon
Tuner: Doug Vincent and Bobby W @ PRE
Dyno Info: Dyno Dynamics PRE Racing
Peak HP at RPM: 392 at 6500 rpm 17 psi  423 @6000 rpm 23 psi
Peak Torque at RPM: 375 at 5000 rpm 17psi 429 @ 5250 rpm 23 psi
Target Boost: 17 and 23
Fuel: e85
Engine/Power Modifications: 2.5 2002 RS block, 99.5 mm CP pistons, STI rods, 1997 EJ20 twin turbo heads, 800 CC injectors, 5th injector 800 cc (barely needed), Vortech FMU 3-1, Ebay T3/T4 turbo. Borla NA header, custom up and downpipe, 3" exhaust
Drivetrain Mods - dual diaphram pressure plate, 6 puck, 1997 STI gearset in NA case.
Tuned for daily driving 17psi and "race" 23 psi.  GRAPH RPM IS OFF BY ABOUT 400rpm (low)!
The 17psi map has been tweaked a little more so probably close to 400 torque, but not on the graph.  Dip in the boost probably due to fluke, wasnt doing that other runs.
Then I turned up the boost to 23 but it obviously would not hold and tapered to 20.  Had been on dyno for about two hours so I called it good for now.
« Last Edit: July 03, 2010, 11:07:32 AM by reddevil »
« Reply #100 on: July 03, 2010, 12:26:19 AM »
Nice!!!!!!! ;D
boosted 00 black si
« Reply #101 on: July 03, 2010, 02:30:04 AM »
good numbers
go fuck your self
BORN TO BOOST
LITTLE B16.400whp on 16psi
« Reply #102 on: July 03, 2010, 10:43:46 AM »
Dynojet?
reddevil
« Reply #103 on: July 03, 2010, 11:07:53 AM »
Whoops,
Dyno Dynamics
« Reply #104 on: July 03, 2010, 01:11:32 PM »
Shit must be fun on the street :noel:
reddevil
« Reply #105 on: July 06, 2010, 06:15:29 PM »
Wastegate has been blowing open, explains the funky boost curves....
That said, I ran 12.44 and 12.45 Saturday night, and shoulda coulda woulda a 12.2-12.3 on Sunday at Woodburn but had to stomp of the brakes to keep from breaking out (bracket racing) and still did a 12.51 @ 101mph....
"Fixed" the wastegate with a helper spring, but won't know if that is going to work till this weekend at the track again....
IF the wastegate holds now, 500whp is not out of the question, 25plus psi in 3rd has happened already.....  Tranny would be in question at that point....
« Reply #106 on: July 06, 2010, 06:41:59 PM »
I love a sleeper!
Gold DA9
  • OG LURKER
« Reply #107 on: July 12, 2010, 09:04:27 AM »
true sleeper. How long have you had your ebay turbo? Your running a restrictor to it also correct?
reddevil
« Reply #108 on: July 15, 2010, 12:16:42 AM »
Turbo is 15 months plus old....  TINY restrictor....
Finally had to run some bigger wire directly to the twin walbros....  Plug was getting HOOOOOOOOTTTTTTT.
reddevil
« Reply #109 on: July 17, 2010, 02:48:25 AM »
Split another cylinder wall! (unless I had epic head gasket failure......)
150' before the finish line......
12.387 @ 116.5 with a 2.004 60' time......
well, tranny needed to be rebuilt anyway....
« Reply #110 on: July 17, 2010, 11:34:07 AM »
I'm not familiar with subies, but do they have sleeves?
I'm wondering if you could devcon one or something to maybe help prevent splitting the walls.
« Reply #111 on: July 17, 2010, 04:50:21 PM »
Fuck how many times is that now? Needing to rebuild the motor and trans?
« Reply #112 on: July 17, 2010, 05:14:03 PM »
Have you clocked 1000 miles on it yet?
reddevil
« Reply #113 on: July 17, 2010, 06:14:43 PM »
[/quote]
[/quote]
Probably close to 15,000 miles?
reddevil
« Reply #114 on: April 03, 2012, 12:28:51 AM »
Finally pulled the motor 1 year 9 months later....
« Reply #115 on: April 03, 2012, 07:02:08 AM »
Ouch.
That thing is screaming for some devcon.
BTW, Welcome back.
« Reply #116 on: April 03, 2012, 08:11:04 AM »
Ouch.
BTW, Welcome back.
+1  :noel:
What is your plan now?
« Reply #117 on: April 03, 2012, 08:24:37 AM »
Ouch.
BTW, Welcome back.
+1  :noel:
Not sure if devcon would help, ill check back in im testing something that should be stronger.
robus
« Reply #118 on: April 04, 2012, 02:36:46 PM »
man that sucks! Is the reddevil going to live on or is this the end????
change of platform in your future? This might be fun (and more reliable)
JRW-RED BULL-subaru legacy LS1 (2)
reddevil
« Reply #119 on: April 05, 2012, 01:38:04 AM »
Some sort of devil will live on....
Cracking the block down soon to reuse the crank/rods/pistons and maybe even bearings if they are in good shape....  Gonna have to rebuild this one on a serious budget right now....
Pages: 1 2 3 [4] 5   Go Up
