Pages: 1 2 3 [4] 5   Go Down
Author Topic: New problems.. Aight im only boosting 5psi max. Damn Diaphragm  (Read 160898 times)
Re: VIDEO ON PAGE 3. I dont have a fuckin clue on whats going on!!!!
« Reply #90 on: March 18, 2009, 04:11:05 AM »
Does the car die if you put your handover the throttle body once it is started?
« Reply #91 on: March 18, 2009, 07:53:24 AM »
I didn't read all the responses but what does the maps look like? Have you tried to burn other maps?
« Reply #92 on: March 18, 2009, 11:29:32 AM »
I dont know Bs well. But here is a shot.
Does it have a egr?
Could it be possible that you have that mixed with a simular plug.
Datalogs help.
THIS IS PROBABLY WRONG  to say. But try and find a obd1 conversion and try out a S300. They have a iraqi for every sensor for whole car. and see which one is false reading and go from there.
Or a non hacked version or eCtune
no egr.  i cant get my hulog to connect with my laptop
yup it does die
im waiting for a burner right now.  here is a copy of my map attacthed .
« Reply #93 on: March 18, 2009, 12:10:53 PM »
Have you tried stock injectors/ecu yet?
« Reply #94 on: March 18, 2009, 12:41:06 PM »
yeah i tried that last night as well.... with a stock pm6.  same fuckin shit...
the thing thats trippin me out is that the car was running before....  i did notice why the old motor blew up.  Timing jumped...
Adam Hopkins
  • Peyton Manning
« Reply #95 on: March 18, 2009, 01:21:25 PM »
Plug wiring, Cam timing, Valve lash, too lean. Thats what I think it could be. If it was a vacuum leak then it would idle higher like you were giving it throttle. Air is what regulates the speed of an engine. Think about it for a second.
« Reply #96 on: March 18, 2009, 01:38:26 PM »
it seems to react fine when the car is cold.......
« Reply #97 on: March 18, 2009, 02:28:50 PM »
Know anyone who has a stock obdo mpfi dizzy laying around? Doesnt have to be for a b series just anyone that will get one bolt on so you can see if that fixes the problem
« Reply #98 on: March 18, 2009, 02:34:34 PM »
i tried that last night as well.  Grabbed another one from Turbo4life.  Same fuckin shit
« Reply #99 on: March 18, 2009, 02:36:26 PM »
Plugs fouled?
your car sucks
« Reply #100 on: March 18, 2009, 03:26:09 PM »
Any cels? how far in is you idle screw screwed in? I had a problem kinda like this a few yrs ago when I first got into fucking around with hondas. The idle screw was screwed in to far.
« Reply #101 on: March 18, 2009, 03:31:58 PM »
Plugs fouled?
your car sucks
new ngk 7's
i brought it out all the way....
« Reply #102 on: March 18, 2009, 03:53:20 PM »
have u used a timing light to see what your timing is when you fire it up? I know you said youve checked but idk, just throwing ideas out.
« Reply #103 on: March 18, 2009, 04:31:48 PM »
as i said.  when the car is cold it reacts fine..
i just got my burner in today so im going to play around with the chip today......I think it may have to do with something with the electronic advance
« Reply #104 on: March 18, 2009, 04:51:38 PM »
do you have vacuum going to the map sensor?  lol
« Reply #105 on: March 18, 2009, 05:03:49 PM »
straight from the the throttle body
Zeniceguycrx
« Reply #106 on: March 18, 2009, 05:10:32 PM »
sounds like a bad tune or timing
The 30psi king of rice
Zeniceguycrx
« Reply #107 on: March 18, 2009, 05:11:04 PM »
and from running like that you will need new plugs after about 15min
« Reply #108 on: March 18, 2009, 05:24:07 PM »
Which port on the throttle body?
« Reply #109 on: March 18, 2009, 05:49:38 PM »
There is one port on the TB that does not supply vacuum iirc and I believe it is for evap
« Reply #110 on: March 18, 2009, 08:25:02 PM »
the smaller of the 2
that is the bigger nipple for the evap for the red hose
anyway..  burner came in, finally got my hondalog to work in loop back mode via hyperterminal.  i should be all good...
you know what sucks.  i dont have an 02 hooked up but its been disabled via TE.
« Reply #111 on: March 19, 2009, 02:55:04 AM »
I fucking got it after 2 weeks of scratchin my head. I guess the stock pm6 that I had was bad as well. I borrowed a stock pr4 from turbo4life and it fired right up idled and was all good. Picking up a socketed ecu from him tomorrow to throw in. Then I can install the 450's back and call it a day. Thanks niggaz.
RHMT>the rest.
BoostForLife
« Reply #112 on: March 19, 2009, 02:59:41 AM »
this has to be sensor/wiring problem. Possibly ecu, try another if you have one. Also, try getting a datalogging cable and see exactly what your ecu reads and what it's doing.
I guess I was right after all.
Re: UPDATES PAGE 4. All figured out and shit... Thanks guys
« Reply #113 on: March 19, 2009, 02:39:30 PM »
CONRATS
Good Job,on some helping out
turbo1.5
« Reply #114 on: March 19, 2009, 10:04:45 PM »
Here's the bins. Please try them both out!
« Reply #115 on: March 19, 2009, 10:05:38 PM »
cool thanks nog
turbo1.5
« Reply #116 on: March 19, 2009, 10:17:26 PM »
No problem call me as soon as you try them out!
« Reply #117 on: March 19, 2009, 10:40:49 PM »
No more 15 psi pulls ;D
Zeniceguycrx
« Reply #118 on: March 20, 2009, 06:46:50 PM »
BAN!
unless you mean pull harder then 15psi
Re: New problems.. Aight im only boosting 5psi max. Damn Diaphragm
« Reply #119 on: March 21, 2009, 02:44:09 AM »
another fuckin piece of shit to go wrong.  Updated first post
Pages: 1 2 3 [4] 5   Go Up
