Pages: [1] 2 3 ... 7   Go Down
Author Topic: buks welding thread  (Read 309753 times)
jay
buks welding thread
« on: May 01, 2010, 09:32:31 PM »
ill start this off by saying i have a new found respect for welders everywhere
yall niggass be makin dis shit look ez O0
with that said..
i currently grade my
tack welds a c-
they look like ass but get the job done
i dont know why but i cant get a decent tack weld without using filler.. i suck ass
root pass a c+
came out surprisingly good.. since i dont have to hold the filler rod in the other hand im better able to lay down smooth and consistent beads i used 1/16th tungsten with no filler rod
filler pass an f+
i REALLY should have cleaned the metal after i did the root pass before i did a filler/cap pass :noel:
not having a welding table really sucks dick.. and i should have used 3/32nd for the cap/filler pass
right now im waiting for the metal to cool but im confident the next piece i weld up will be better
ill use 3/32nd for the cap pass and ill clean the metal between the root and the cap passes
shitty tack
root pass
filler pass
after cleaning (forgot to clean between root and filler passes.. doh!
tips would be greatly appreciated but if all you want to do is talk shit please post in the cummins discussion thread...
I want you to die
Re: buks welding thread
« Reply #1 on: May 01, 2010, 09:39:41 PM »
What are you making?  Pipe bombs?
jay
« Reply #2 on: May 01, 2010, 09:45:09 PM »
IRA style :noel:
I want you to die
« Reply #3 on: May 01, 2010, 09:59:47 PM »
WAY TOO hot Jay. Turn it down or move way faster. Whats you gas flow like? clean it better before you start.
« Reply #4 on: May 01, 2010, 10:20:09 PM »
dirty, dirty, dirty.......
you need to put a have decent bevel on that pipe. and clean/buff up the area arounf the weld some. Also  as csaddict said check your gas flow as thats pretty burned up looking.
jay
« Reply #5 on: May 01, 2010, 10:53:26 PM »
thanks yeah i like the heat where its at but i def neat to move faster
no idea where gas flow is at.. i dont have a flow meter yet :(
my friend has my angle grinder and my bench grinder has a grove going down the middle of the wheel from the bevels i made so the metal bounces around on it
i need a rest for the pipe and i need to bolt down the angle grinder so i can feel comfortable applying pressure to the metal to get a better bevel
sorry pictures are out of order and im pissed off so i dont care for reorganizing them
basically this time
tackweld was b- dont have a pic of it
root pass f-
i burned two holes right through the shit rofl from too much heat/not moving fast enough
filler pass f+ (again)
first time attempting a decent cap pass with 3/32nd and i kept dipping the damn filler rod into the wrong spot so it stuck.. and i had to use the torch to get it off XD
also i wasnt wearing a glove on the filler rod feeding hand being the typical dumbass that i am filler rod was short and it got hot so i had to drop it a couple times lol
i think attempt number 3 will be halfway decent
I want you to die
« Reply #6 on: May 01, 2010, 10:57:27 PM »
Turn the heat down, you don't know jack shit to be saying you "like where it's at". do as told and you will learn. Don't listen and i personally will just sit back and watch the fail insue.
jay
« Reply #7 on: May 01, 2010, 11:02:36 PM »
sorry..
attempt number 3 coming up with less heat
now that i have a newer board in my welder i cant set the max amps for when i have the pedal at 100% lol
what should i set max amps to
dc negative right
should i stick to 1/16th root and 3/32nd cap pass
I want you to die
narfdanarf
« Reply #8 on: May 01, 2010, 11:07:38 PM »
Do you not have any flat stock to practice the motion on before you move to pipe?  Also turn the damned amperage down, holes like that won't be caused by not moving fast enough, you are way way way way too hot.  Turn up the gas, buy a fucking flowmeter for fucks sake...actually on second thought you do have a regulator right, you're just missing the gauge?  Cleaning is important, but the correct motion and welder settings are at least 3 times more important, unless you're welding shit that's getting x-rayed.
Also I recommend you practice on some shit that is not stainless, it will handle the heat of a slow torch operator much better.
narfdanarf
« Reply #9 on: May 01, 2010, 11:10:16 PM »
I use 1/16" for everythign except really small places which I use some mig wire, and I use 3/32" for head/turbo flanges shit that needs a lot of filler.
jay
« Reply #10 on: May 01, 2010, 11:14:01 PM »
wish i had flat stock but local metal shop wants an arm and a leg for fucking flat shit even scraps.. i was like WHAT THE FUCK!!!
what amps should i be welding at yeah second try i was running alot hotter XD
i got a regulator just dont have the gauge :/
buying a flow meter really soon...
just dont have the money right now :/
thanks.. i think ill go back to trying 1/16th filler pass again :/
I want you to die
jay
« Reply #11 on: May 01, 2010, 11:27:15 PM »
waiting for peeps to chime in before i go at attempt #3 :(
I want you to die
bigwig
« Reply #12 on: May 01, 2010, 11:28:07 PM »
You need a flow meter.
I also want you to own up to what really happened with this welding bullshit.
jay
« Reply #13 on: May 01, 2010, 11:33:00 PM »
gonna buy flow meter asap
bought a fucked up welder
paid 100 to get it checked out
gave me 875 dollar repair bill
guy at welding shop was cool as fuck and gave me the board to fix it for free
i tossed it in and welder still didnt work.. called him up and he was cool enough to install it for free but he said since hes doing it for free and on the side it would take him a while
3 weeks later.. welder fixed for free  :noel:
everything else in the thread was trolltasticallyfabulous
I want you to die
jay
I want you to die
narfdanarf
« Reply #15 on: May 01, 2010, 11:39:38 PM »
yes.
« Reply #16 on: May 01, 2010, 11:45:03 PM »
Buy the guy a bottle of booze, goddamn you.
jay
« Reply #17 on: May 01, 2010, 11:51:46 PM »
i offered to pay him he refused he said i know youll be a life long customer and thats all he wants
bleh
niggers need to tell me what amps i should be welding at
I want you to die
« Reply #18 on: May 01, 2010, 11:54:12 PM »
i set the machine at 80 amps for sch10, and use NO filler on the root and 1/16th on the cap/fill pass.  Use a bit less amps if 80 is to much.
Hotrodlincoln
« Reply #19 on: May 02, 2010, 12:16:17 AM »
pretty much what every one else has been saying. to hot, turn it down
kill yourself piss face
jay
« Reply #20 on: May 02, 2010, 12:43:14 AM »
thanks.
going to try attempt #3 right now.
I want you to die
« Reply #21 on: May 02, 2010, 01:09:47 AM »
bleh
buy him a bottle anyways. you'll get discounts for the rest of your life, and a friend to bullshit with everytime you go into the store.
jay
« Reply #22 on: May 02, 2010, 01:23:08 AM »
^^ rofl i might just do that
i got a shock on attempt number three
i think from the arc assist starter/hf start
was a nice shock too i was half asleep so it woke me the fuck up
pictures uploading.. fuck the g1.. this shit used to upload in seconds now it takes 15 minutes all the way up to an hour
anyways
used 1/16th set machine to 75 amps and still burned a hole through
then looked at the pipe and realized my chop saw wasnt cutting straight..
so the areas where the root pass cuts through is because the pipe is uneven there and not a flush fit so instead of the bevel falling in on itself it just makes a hole
so im gonna stop being lazy and finish setting up the band saw tomorrow
I want you to die
« Reply #23 on: May 02, 2010, 01:46:42 AM »
your fit up has to be perfect, there can't be gaps anywhere. this is not an option.  Your moving WAY to slow if you burning a hole at 75 amps.
try moving from side to side 1/4" while moving forward on the root just practicing the proper weave. I have done this when i was learning. i would do a dry run of what i was about to do when welding to get the speed/width down. this gives you something to copy when you welding. Trust me it works, also try getting into a rythum.
Yes the pipe might have some minor undercut/ripple to the root pass this is normal, you want a little groove to follow later when you have to add filler. If not the arc will wander and the bead width can become inconsistent.
jay
« Reply #24 on: May 02, 2010, 01:47:44 AM »
tack weld
root pass
too tired to finish organizing pics
I want you to die
jay
« Reply #25 on: May 02, 2010, 01:49:36 AM »
thanks.
i havent tried side to side yet.. just (sadly) up and down rofl
attempt #4 will be tomorrow
thank you rhmt!
I want you to die
jay
« Reply #26 on: May 02, 2010, 02:06:02 AM »
fyi i have epilepsy so i got shaky hands
so ittl take me a while to get this shit down XD
i havent played guitar in a while so the shaking has gotten worse.. whatever
correct me if im wrong..
but these welds are structurally sound right?
doesnt look like this shit is gonna crack.. they just look like shit right?
and other than burning through.. my root pass is fine right?
I want you to die
« Reply #27 on: May 02, 2010, 02:11:00 AM »
No theres not a whole lot about them other then you stuck to peices of metal together thats correct. At this time. Give it some time or alot. and it will start to make sense. But do not think your ready to go out and start making things.
narfdanarf
« Reply #28 on: May 02, 2010, 02:38:54 AM »
I'd go get some steel plate from lowes tomorrow and practice running straight lines on it. I think part of your problem is you're not letting the pipe cool enough between arcs.  If the pipe has been heatsoaked to hell you will have problems burning through.   Since you're new and your probably slow, i'd weld like a 1/2" and let it cool then weld another half inch and let it cool...ect ect.  Once your speed picks up you can move the length of your beads up without heatsoaking the shit out of the pipe.
Another tip, as you're looking at the puddle it needs to be a circle, if it's an oval you're moving too fast or you are too hot and it's not able to cool fully before you move.  It will come you just need practice.
jay
« Reply #29 on: May 02, 2010, 03:14:11 AM »
thanks but actually the holes happend when i first touched the torch to the material... im 80% sure they happend because the chop saw isnt doing straight cuts anymore and the pieces arent lining up
i will set up the bandsaw tomorrow and will confirm
i just got back from the basement and i did a pass over all 3 welds without filler and damn i could hold the torch there forever almost and it wouldnt burn through
it flattend out the bead and made it look alot more uniform but made it alot wider too
ill try to find some steel plate but right now yo no tango dinero and im sure id rather buy that regulator then get flat steel i hear ya on the puddle
i knew i was dragging the torch too fast lol  i wasnt able to get dimes worth shit (not that i really tried all that much) they were just a stack of ovals
meh
again thank you rhmt
I want you to die
Pages: [1] 2 3 ... 7   Go Up
