Pages: 1 2 3 [4] 5 6 7   Go Down
Author Topic: buks welding thread  (Read 311078 times)
Re: buks welding thread
« Reply #90 on: May 08, 2010, 10:25:51 PM »
The reddish brown halo in the HAZ.
jay
« Reply #91 on: May 09, 2010, 12:55:56 AM »
^^ thanks
so who wants to make me a collector cutting rig for my band saw :D
I want you to die
« Reply #92 on: May 09, 2010, 07:39:01 AM »
You have a bandsaw and a welder, you should be able to handle it
« Reply #93 on: May 09, 2010, 09:09:21 AM »
Jay mine is literally a piece of angle iron with a hole in it. Then I marks the saw for the angle and the angle iron for the length.
jay
« Reply #94 on: May 09, 2010, 10:15:45 AM »
can you take some pictures for me if you get some time :(
I want you to die
« Reply #95 on: May 09, 2010, 10:27:12 AM »
there is a thread already , look it up.
jay
« Reply #96 on: May 09, 2010, 11:25:29 AM »
yeah i saw that thread a while back but its just one pic of each setup lol
im a lazy fuck and i wanted detailed picccsss :(
I want you to die
« Reply #97 on: May 09, 2010, 11:26:47 AM »
Well go look again, i posted my ghetto jig. It's not that hard manifold fab master.
« Reply #98 on: May 09, 2010, 12:37:53 PM »
This is all part of being a fabricator. You have to be able to think for yourself. Getting inspiration from other peoples ideas is one thing, but you have to be able to get from point A to point D without being able to see points B and C sometimes.
jay
« Reply #99 on: May 09, 2010, 02:41:47 PM »
no welding today.. or tomorrow.. been working on my car all day today and picking up my cousin from the airport tomorrow
I want you to die
jay
« Reply #100 on: May 10, 2010, 01:00:55 AM »
would it be safe to remove the 6 gauge wire i ran to the corner of the basement to use it through the window to run the welder in my backyard?
is there a reason i cant keep moving the cord around flipping between outside and the basement>?
I want you to die
« Reply #101 on: May 10, 2010, 09:56:04 AM »
Household wire isn't meant to be moved around a lot and it's also not meant for the elements is would see outside. With that said I don't see why you couldn't do it a few times till you can get a proper extension cord.
jay
« Reply #102 on: May 11, 2010, 09:21:52 PM »
wait so it is safe to make an extention cord out of 6 gauge wire for the welder???
someone told me it wasnt :(
lame
ok so heres todays welding try.. i used acetone to clean still dont have the money to buy the proper regulator
anyways todays weld sucked cause i was tired as hell when i was welding and the acetone fuses werent helping.. especially when i brushed/cleaned with acetone between welds and i had a bunch of acetone dump on me so the fumes were raging.. bleh
root pass pre cleaning
root pass post cleaning
cap pass pre cleaning
cap pass post cleaning
I want you to die
« Reply #103 on: May 11, 2010, 09:32:09 PM »
you shouldnt have to clean off the welds when your done, do you have a fucking flow meter yet?
and youre using stainless filler right?
make sure the filler is clean before you use it, also try to keep your gloves clean.
jay
« Reply #104 on: May 11, 2010, 09:38:09 PM »
stainless filler yeah its clean before i use it buy my gloves are no where near clean XD
any other tips
i think since my welds arent improving and im just consistently laying down more or less the same ecact welds im prolly doing something seriously wrong
i will buy my regulator before the end of this week and ill also have a t setup for the gas line with a cut off valve for my back purge setup ill place the t directly off the bottle
I want you to die
« Reply #105 on: May 11, 2010, 10:25:40 PM »
Without a flowmeter, you are wasting your time and materials.
I use dedicated gloves for tig welding and a dedicated bench grinder for my tungsten.
hotrex
« Reply #106 on: May 11, 2010, 10:32:42 PM »
yup dedicated gloves and wheelfor tungsten and wire wheelforstainless only.
buk u either are way too hot traveling too slow and using not enough filler or u are having serious lack of gas coverage going too slow and using not enough filler.
as far as collector jigs go.,..  ill sell u mine.,
jay
« Reply #107 on: May 12, 2010, 08:18:49 AM »
my gloves are dedicated tig gloves but they got nastied up from back when i first started with the broken welder
so ill have to buy new ones
i think im gonna buy one of those mini ass bench grinders for tungsten only
yeah regulator coming up shortly.. found a car for my cousin going to pick it up this morning so ill make 500 bucks if its a good car.
ha.
I want you to die
« Reply #108 on: May 12, 2010, 11:50:35 AM »
this is what i use, but mine doesnt have the flex shaft or the variable speed=cheaper!!!
http://www.harborfreight.com/bench-grinder-with-flex-shaft-43533.html
« Reply #109 on: May 12, 2010, 01:46:13 PM »
fail
hotrex
« Reply #110 on: May 12, 2010, 06:55:38 PM »
pice o chit mang
« Reply #111 on: May 12, 2010, 08:52:02 PM »
works great for me
jay
« Reply #112 on: May 14, 2010, 11:09:44 PM »
no welding in a whileeeee
gonna be welding up some charge piping for a friend tomorrow or the next day tho
ha
I want you to die
jay
« Reply #113 on: May 15, 2010, 04:01:28 PM »
so what gauge material for charge piping?
ss?
or do mild steel then paint it?
dont really feel like getting into aluminum right now
I want you to die
« Reply #114 on: May 15, 2010, 04:54:54 PM »
ss?
16 gauge for charge piping. Material is your choice, mild steel is easier to work with but SS doesn't rust. so you choose. Usually if i get someone who doesn't want to powdercoat there piping or isn't super cheap i just go aluminum. As the price is the same for the most part as SS. And well it's just plain better hands down.
« Reply #115 on: May 15, 2010, 06:09:58 PM »
Buk, the way you are welding right now, stay away from aluminum. it is so much less forgiving than steel or SS. i have always done my own in mild steel and painted it, but to each their own
« Reply #116 on: May 15, 2010, 06:13:56 PM »
Buk, the way you are hacking it right now, stay away from aluminum.
fixed
jay
« Reply #117 on: May 15, 2010, 06:14:56 PM »
thanks again rhmt
im prolly gonna place an order for ss and ms real soon
wanna get started learning how to weld that thin shit
yeah i figured id be fucked as far as aluminum goes lol
what do you use to paint the mild steel?
also i remember reading some shit from a while back about mild steel charge piping rusting on the inside and fucking up motors.. lawl
i just thought why not paint em in and out?
bleh
I want you to die
jay
« Reply #118 on: May 15, 2010, 06:16:39 PM »
fixed
hacking my ass. i looked at my birdshit log mani today and the welds are almost identical.. as far as i know birdshit was a successful fabber seems to me i just need to perfect the bevveling process.. my current bevels are almost non existant if they were better it would tuck away the bead..
I want you to die
« Reply #119 on: May 15, 2010, 06:23:25 PM »
how thick is that shit?
Pages: 1 2 3 [4] 5 6 7   Go Up
