Pages: 1 ... 4 5 [6] 7 8 ... 31   Go Down
Author Topic: NOW WITH TWIN TURBO LQ4 ACTION~~~~~~~~~~~ 1966 RAT CITY RED ROCKET!!!~~~~~~~~  (Read 686629 times)
Re: ~~~~~~~~~~1966 RAT CITY RED ROCKET!!!~~~~~~~~~~~
« Reply #150 on: March 21, 2013, 10:10:05 PM »
Well got a bunch of little shit done in the last couple of days....
Drivers side suspension is all checked and tight.
Shock cover/bump stop is bolted on drivers side.
Ps bracket is painted and mounted
batt tray is painted and mounted
bumper and grill is all mounted and turn signals wired
hood latch painted and bolted in
headlight trim bezel is on
some wiring ran
wiper motor is painted and bolted in
Horns bolted on..
Not much but its all the little shit that takes time
« Reply #151 on: March 21, 2013, 10:19:36 PM »
wow, really is looking good. very simple. love it.
still does need a turbo tho.
« Reply #152 on: March 21, 2013, 10:57:12 PM »
Fuck I'm jelly.
carkrazed
« Reply #153 on: March 21, 2013, 11:39:50 PM »
Looks sweet...............I'm definitely a fan of simplicity. Almost as much as Russ is.
« Reply #154 on: March 21, 2013, 11:47:26 PM »
Fuck I'm jelly.
+10
Makes me so mad I let my 63 Buick go
« Reply #155 on: March 22, 2013, 12:06:44 AM »
There will be no Russ style simple in this build. End of story! Once its running, Ill come back and clean up all the wiring with some loom and all that good stuff.
« Reply #156 on: March 25, 2013, 01:41:48 PM »
Kinda ran into a wall. Lots of of little fab shit I have to do and not enugh time this last weekend, but I got a few more little things done
PS pump and belt in
Alt test fitted and belt length is good on it
Main relay cleaned up, wired up and bolted in
Voltage regulator cleaned up, wired up and bolted in
Wiper motor wiring hooked up and linkage bolted to it
throttle linkage bolted in the car now
horn wires hooked up
Drivers side suspension is all done and tq down.
Front wheels TQ'ed down
Started to fuck with shifter linkage bracket that mounts to the transmission so I can shift it through gears, but it looks like im gonna have to do some fab work on it because it doesn't just hook up. Its the wrong bracket. Think its for a floor shifter or cable and my linkage is just that , LINKAGE.
And the dipstick tube that I though was for the Powerglide Is defiantly for something else. Once the tube is in, the bracket for it to bolt to the transmission sits about 3/4" higher that the bolt hole. So I think Im gonna weld a washer to the tube or something.
and last but not least, I pulled the batt out of my integra to just test the wiring, and low and behold, All my wring on the car works. Horns, turn signals, brake lights and everything else except the radio because the fuse for it is missing.
« Reply #157 on: March 25, 2013, 01:52:52 PM »
Damn you have plenty of space for a hx-52!
« Reply #158 on: March 25, 2013, 03:12:46 PM »
This!!!
« Reply #159 on: March 25, 2013, 06:33:20 PM »
Or a $650 S475...
« Reply #160 on: March 25, 2013, 07:03:48 PM »
thinking more along the lines of some rhmt kkk turboS. Or a gtp38 or gt40 All of which I have access to.
« Reply #161 on: March 25, 2013, 07:13:44 PM »
... Or a pair of gtp38's or gt40's All of which I have access to.
Fixed.
« Reply #162 on: March 25, 2013, 08:24:21 PM »
Not going for a monster...........yet Just want lightning fast spool. Like a rhb5 on a d16
« Reply #163 on: March 25, 2013, 08:43:13 PM »
You will likely end up with monster back pressure, and no workable rpm range if you go to small.
« Reply #164 on: March 25, 2013, 10:57:16 PM »
Not going for a track car at all. Litterly I want to stand on the go pedal and have boost there at any range in the rpms. Even if it means giving up peak horsepower for the last 1k. I Mean if and when I boost it, if it make 450whp @ 3k, you can't tell me that it wouldn't be a fun ride to cruise around town in.
« Reply #165 on: March 25, 2013, 11:21:16 PM »
Size your converter properly and that's a non issue. Listen to dvst8r, he knows his V8 stuff.
« Reply #166 on: March 25, 2013, 11:41:58 PM »
I understand he knows what's up. I just don't want a lag monster.
« Reply #167 on: March 26, 2013, 12:02:29 AM »
Just keep in mind each of the 4 cylinders in that V8 have more displacement then a Honda H motor.
Also keep in mind that 450hp@3000rpm is almost 800ft lbs of torque, that is going to take a decent built transmission, and will burn the tires off at will. Sounds like you are trying to build a diesel.
« Last Edit: March 26, 2013, 12:07:41 AM by dvst8r »
« Reply #168 on: March 26, 2013, 12:29:00 AM »
Lol, ok. Let me rephrase that. I want 450tq @ 3k.....lol But to be 100% honest, I just want the car to move under its own power right now. I'll worry about boosting it later on.
« Reply #169 on: March 26, 2013, 09:43:38 AM »
You don't even need a turbo then. Lol.
« Reply #170 on: March 26, 2013, 10:13:34 AM »
You always need a turbo.....
« Reply #171 on: March 26, 2013, 10:51:01 AM »
So now you are talking like 250hp, depending on your current compression ratio, a cam swap will net you that and more...
As you may be realizing about now, making power at 3000rpm really isn't good for anything but pulling trailers.
« Reply #172 on: March 26, 2013, 11:11:47 AM »
Well it does have to tote my fat ass around....lol
« Reply #173 on: March 26, 2013, 12:17:13 PM »
I was kidding about no turbo. That's asinine. Lol. V8's are a whole different deal than 4 cylinders. I remember tuning a v8 for the first time. Maxed out the injectors at 2500-3k rpm then had to back tons of fuel out above that. It went against everything I was used to. Lol
« Reply #174 on: March 26, 2013, 12:53:02 PM »
And that's where I'm gonna be at too I belive. Whole new game for me. I mean who makes more tq than Hp anyways........lol
« Reply #175 on: March 26, 2013, 01:17:20 PM »
A diesel, certainly not a v8 gas with a proper cam and turbo...  :P
« Reply #176 on: March 26, 2013, 01:37:54 PM »
Ill be lucky if this motor makes 250whp na.
« Reply #177 on: March 26, 2013, 02:53:53 PM »
Not with the stock cam, but depending on compression ratio, with a different cam it should be able to pull that.
« Reply #178 on: March 26, 2013, 05:13:55 PM »
Well, from what I have gathered. My comp is about 9.5:1 and the cam that is in there is its a little hotter than a lt1 cam. Find out soon. They dyno day is less than 2 months away.
« Last Edit: March 26, 2013, 05:16:43 PM by ratcityrex »
« Reply #179 on: March 26, 2013, 06:21:08 PM »
My guess is about 270hp.
Pages: 1 ... 4 5 [6] 7 8 ... 31   Go Up
