Pages: 1 ... 3 4 [5] 6   Go Down
Author Topic: 350 or Bust - Love me some D: Getting a tune  (Read 148784 times)
Re: 350 or Bust - Love me some D: almost finished!
« Reply #120 on: October 02, 2009, 01:00:22 PM »
After playing around in crome for an hour, the car idles fine with the 880.  A little rich once the car warms up but 13 afr isn't horrible.  The problems I'm having I think can be attributed to the lack of preset injector battery offsets in the latest version of Crome.  I'm having to guess and test and right now I've got it idling decent with a 60 off set in the Fuel Table.
Does anyone know where I can find a fairly accurate offset value for the Precision 880s?  Should I find an older version of Crome and use those?  I'm a noob when it comes to tuning.
I had to use 65 for an offset on mine for 788cc Delphi injectors. ;D
I use Crome 1.5.3
I have cranking offset at 0.600
« Reply #121 on: October 02, 2009, 01:06:54 PM »
One day I'd love to take apart the case on the PLX and some how make the lcd display fit into where the stock clock is, or should be, CX doesn't have that luxury item
here is my m300 in my crx
« Reply #122 on: October 02, 2009, 02:13:17 PM »
I use Crome 1.5.3
I tried 65 before and it was a bit on the rich side at idle.  Cranking is 0.35 and I might bring that up a bit.  The only true cold start took a little while for it to kick over.
BTW I'm also using 1.5.3, it's the latest and greatest free version, I do believe.
ratcityrex, that's exactly what I'm talking about, except with the EG chassis, the clock is a bit higher and more toward a driver's view out the window.  For now, it's cool chilling where the radio went with the cheap-o boost gauge.
« Reply #123 on: October 02, 2009, 05:54:41 PM »
1.5.5 beta is out
« Reply #124 on: October 02, 2009, 07:00:41 PM »
1.5.5 beta is out
Shows how much I know about tooning
Car runs and is drivable.  I blew a coupler off the IC first pull.  I've been messing with the tip in and I can't get the car to not stumble for a second as soon as you slap the gas.  You ease the gas down, it does fine.  Any suggestions with what values I should have for the tip in and addt. tip in?
Also, what plugs would you run with this setup.  NGK R5671A-7, #4091 sound like a winner?
« Reply #125 on: October 02, 2009, 11:54:18 PM »
are you watching it with a wideband?  is your injector latency too low causing delay with the tipin?
Yes.  I've been trying to use FreeLog to datalog with.  I'm getting proper readings, it's just I don't see any boost values on the tables for FreeLog.  I'm not sure how to adjust the injector latency in Crome.  I'll have to do some more research on that.
« Reply #126 on: October 04, 2009, 02:02:08 PM »
1.5.5 beta is out
I think 1.5.5 is for the use of the Demon. I tried to DL and use it but I can not get it to work.
Re: 350 or Bust - Love me some D: NEED HELP tooning
« Reply #127 on: October 16, 2009, 03:49:16 PM »
OK
So now that I have some free time today, and the strip is open this evening, I'd like to get my car where I could at least make a few passes.  The problem I'm having is that I can't get FreeLog to work worth a damn in boost.  I can log and see everything like I should, I just add the extra columns in the MAP Scalar tab and the shit never makes it past atmospheric when I'm logging even though my boost gauge says I'm making boost.  I am using a Freescale 3bar in the stock casing.  I think the reason I can't get FreeLog to do shit is cause I'm going to have to change the equation for the MAP scalars in FreeLog.  I just don't know where that shit would be at on the program.  Help is much appreciated
Re: 350 or Bust - Love me some D: minor setback, big mess
« Reply #128 on: October 28, 2009, 05:32:18 PM »
So I had some free time today to mess with the tune, jump in it, let it idle to get to temp and then go do a 3rd gear pull on the low side of vtec to get afrs dialed in.  Right now I'm just using the rpm and afr readings in freelog and then make adjustments in Crome and repeat.  So first solid pull I get to about 6k and ALL SMOKEY HELL breaks loose.  First thought, I just blew the seals in the snail, even though I have a pop rivet as a restrictor.   So I make the turn that goes back down the hill to my house.  On the way, the oil light flickers a bit so I kill it and coast the rest of the way.  Get out and find this:
The damn oil feed line came off the fitting and rust proofed the ENTIRE engine bay.  That oil has less than 200 miles on it.  I'm pissed.  However, I messed up the oil pan gasket when I built the motor and it leaked some previously, so I guess now is as good a time as ever to go ahead and fix that seeing how there isn't hardly any oil left in the engine.  Too bad they don't sell brake clean in gallon jugs.  The good news, I have a solid mid to low 13 afr from 2k to 6k on the low side.  Gotta clean up the mess and then jump on the high side.
« Reply #129 on: October 28, 2009, 07:20:41 PM »
Did you figure out where to change it? If so where because its the same shit im gona be running into.
« Reply #130 on: December 14, 2009, 12:46:31 AM »
BUMP for getting a tune next week.
the grand wizzard of the interwebz gets the honors
I've been taking care of a bunch of little shit to get it ready for the trip to Asheville and back.  Pulled the oil pan, installed new gasket, fixed the small leak on the drain of the turbo (shitty gasket again), Fixed the oil feed line to the turbo so it hopefully won't come apart again, got something rigged up for the PCV that should get me there and back, finished an exhaust with a glasspack muffler so it exits at the rear of the vehicle instead of just behind the firewall, installed a 25 psi boost gauge (hoping to use most of that), and I still need to swap out an axle after a cv joint boot exploded a while back.  I ordered a camshaft with 3 day shipping from crower this past weekend, and it still hasn't got here.  If that gets here in time, I'll throw it in.
« Reply #131 on: December 14, 2009, 01:52:03 AM »
thats a pimp fmic sir
WOT
  • The Canadian
« Reply #132 on: December 14, 2009, 03:09:19 AM »
Lovin the manifold
Sucks about the turbo feed though, that would scare the shit outta me
« Reply #133 on: December 14, 2009, 04:36:11 PM »
Lovin the manifold
It did.  Thought of several bad things right of the bat, but once the low oil pressure light came on while making the trip back to the crib, I knew what happened.
Car is running great since I 'fixed' all the small stuff.  Shit makes 8ish psi with the waste gate arm unhooked from the flapper, on low side of the cam only.  Can't wait to see what JD can do with it!
Re: 350 or Bust - Love me some D: Getting a tune
« Reply #134 on: December 14, 2009, 09:21:57 PM »
Came back from a final exam to a package on my step with new cam and springs inside.  Going to try to get it installed tonight!
Then another final tomorrow and a paper due which I haven't started...
« Reply #135 on: December 15, 2009, 11:57:59 AM »
lol you got a dirty engine bay :P Nothing broken hopefully.
« Reply #136 on: December 15, 2009, 01:03:06 PM »
Nope, just oily.
Got the stock cam out, new springs swapped in and the new cam goes in today when I get some free time.  I'm such a dumb ass sometimes.  I spent 5 minutes trying to figure out why the crank wouldn't turn past a certian point.  I was thinking there was no way that the valve springs could hold that much force to keep the crank from spinning.  Then I took it out of gear and it was easy...
« Reply #137 on: December 15, 2009, 01:48:10 PM »
LOL good job!
« Reply #138 on: December 16, 2009, 12:29:22 AM »
Bumpstick installed and top end buttoned up.  Loading up the rust rocket now to head to Asheville.  I'll post pictures later.
« Reply #139 on: December 16, 2009, 12:40:35 AM »
Ill make an effort to get over to the shop to meet you dude.  No guarantees though lol.
« Reply #140 on: December 16, 2009, 01:37:09 AM »
Word.  Had to change the time to in the afternoon.  I should get there 3-4ish.
« Reply #141 on: December 18, 2009, 12:15:43 AM »
Well JD is awesome, my mechanic work, not so much.  Seems that the clutch wasn't holding once we started to make a few higher boost runs.  It's all brand new stuff, with like 1600 miles so the conclusion we came to was that oil must have gotten on the clutch from when I was swapping out the cam and springs.  Dissapointing for sure, but that's how it goes with cars.  I'm going to try to get the transmission out this weekend and clean everything up good on the clutch/pp/flywheel and reinstall everything then we will see what happens from there.  Also going to try to adapt the HY-35's integral waste gate setup to something that I can swap out lower boost cans for.  JD wasn't really excited about trying to tune 20 psi all at once, lol.  I didn't know any better but now I do.  Learned alot, and hopefully will get everything sorted out in due time!
We are supposed to get up to 12 inches of the wite stuff this weekend, so I have some work to do to get the car in my garage where I can work on it.  The good news is that it is WAY more drivable now that someone who knew what the heck they were doing was tuning the car.  I won't have to trailor it again to get it anywhere, which is a BIG plus.
« Reply #142 on: December 18, 2009, 06:54:37 AM »
JDFTW
« Reply #143 on: December 18, 2009, 04:10:27 PM »
Higher boost = 5 psi.  It was really saddening.  18+ psi actuator makes for a scary street tune experience, but the car wanted to move.  :/
For an 8.5:1 SOHC, it fucking ripped at 3000 rpms before the turbo began to spool (positive pressure at 3500, crackrocks and clutchspin at 4000).  I knew I loved that cam for a reason, but the only time I got to drive Blossfield's car with that cam on the street it had a GT28RS so it just made boost all the time.
« Reply #144 on: December 18, 2009, 06:44:27 PM »
what bumpstick?
« Reply #145 on: December 18, 2009, 06:55:52 PM »
Crower turbo cam.
« Reply #146 on: December 19, 2009, 12:09:28 AM »
Crower turbo cam.
What's the cam number?
« Last Edit: December 19, 2009, 12:20:24 AM by 92CXyD »
« Reply #147 on: December 19, 2009, 02:05:21 AM »
63441ZT
Beware, on crower's website, it is listed as a 'stage 2' even though the nomenclature points to 1.
t57b18
« Reply #148 on: January 01, 2010, 09:44:23 PM »
love the build   car looks like a fun  street car and with suprise  many  im shure good luck with your clutch issues..
« Reply #149 on: January 02, 2010, 08:03:33 AM »
Why didn't you guys spray a few cans of brake clean on the clutch through the pivot arm hole?
Pages: 1 ... 3 4 [5] 6   Go Up
