Pages: 1 2 3 [4] 5 6   Go Down
Author Topic: 350 or Bust - Love me some D: Getting a tune  (Read 148803 times)
Re: 350 or Bust - Love me some D mani half way there
« Reply #90 on: July 12, 2009, 09:24:31 PM »
By the way, I passed the Fundamentals of Engineering Exam with an 86, and I'll be attending Radford University in the Fall to earn my MBA.  So thanks for everyone wishing me the luck, it actually paid off.  Now hopefully I can get this car put together and hopefully run in the 8's on street tires at the local 1/8th mile strip
« Reply #91 on: July 13, 2009, 12:30:52 AM »
Congrats mang. ;D
« Reply #92 on: July 13, 2009, 11:23:34 AM »
The world needs more engineerings with the notion of ingenuity.
Good job
« Reply #93 on: July 13, 2009, 04:21:50 PM »
Looking good
You guys need to buy 12 watt pencil soldering irons if you want to do small joints.
speedjunky01
« Reply #94 on: July 13, 2009, 07:43:58 PM »
nice job on the mounts, i am doing the upper two mounts just like that and ES mounts in the lower 3
Re: 350 or Bust - Love me some D Manifold = Done like a cake
« Reply #95 on: July 29, 2009, 09:34:37 PM »
Update
3 out of 4 ain't bad
Finished, and don't worry Hotrex, the threaded part wasn't hard to weld to at all
Just need to get rid of the slag and clean it up a bit
Anyone have any suggestions for a high temp paint that will actually stay after use?
speedjunky01
« Reply #96 on: July 29, 2009, 09:38:01 PM »
nice job on the mani
where did you get the bends?
« Reply #97 on: July 29, 2009, 09:39:46 PM »
Ace Stainless like a year ago.  The ELs and the straights are sch. 40
AJxr
  • i aint ur buddy pal
« Reply #98 on: July 29, 2009, 09:46:18 PM »
im sort of a newb in the welding department, what are the strength differences between what you have hear and say something tig welded? i can mig weld and id like to make my own manifold but im not sure if id just be wasting the money if the thing is going to crack every 10 mins.
90 hatch
« Reply #99 on: July 29, 2009, 10:21:10 PM »
You can have something crack no matter what process you use.  If it is a quality welding job (i.e. proper filler material, proper voltage or amperage setting, proper flux or shielding gas) then it doesn't matter what type of welding takes place.  I have the ability to arc weld, and that's what I feel the most comfortable with so that's what I used.
I feel sure there is a more technical answer, but for what I'm doing and probably what you would be doing, how you weld is way more important than what you weld with.
« Reply #100 on: July 30, 2009, 07:40:55 PM »
that manifold is hilariously awesome.
way better than my splog
« Reply #101 on: July 30, 2009, 09:06:36 PM »
As for paint, I'm running some 2000 *F header paint from Advanced. Shit works great. Just follow the directions on the can. I believe it's VHT brand. Painted my manifold, turbine, and downpipe and they're all holding up fine so far. Sick build BTW.
« Reply #102 on: July 30, 2009, 09:51:04 PM »
that mani makes my dick hard
« Reply #103 on: July 30, 2009, 11:41:21 PM »
yes  :yes:
Re: 350 or Bust - Love me some D: Interfooler mounted
« Reply #104 on: August 01, 2009, 05:55:48 PM »
Huge 23 lb. intercooler bought off ApexSilver06MR for 100 bones shipped.  Great guy, great transaction.  It's in used shape but thats fine with me.  I plan on straightening out the bent fins when I get some free time
I had a bumber from a previous build that had most of the back cut out, just had to trim a little lower and it fits like a glove.  And of course, it started pouring right as I was finishing up
I had to remove the bumper support, trim the lower raidator support, and trim the upper rad/hood support to get it to fit like I wanted.  Here's a shot of how I attached it to the chassis.  I was pleased with how it turned out
Thats all for now.  Plan on starting the charge piping soon.  I need a HX/HY-35 outlet flange with a 3" hole so I can make an exhaust.  The other option is if someone has a 2.5" v-band assembly for cheap or even a used one foot pipe with the 2.5" v-band on it I'd be able to use the stock cast outlet flange.  Let me know what you got.
« Reply #105 on: August 02, 2009, 01:57:12 AM »
do me a favor? see that relay hanging of the back side of your drivers headlight? remove it and the wiring that attaches to it... just fallow it till it hits the harness on the pass side, save you 2lbs ::) and look cleaner since its for AC, and you dont have it...
btw looks ghetto, congrats... :yes:
« Reply #106 on: August 02, 2009, 02:01:54 AM »
It's on my to do list.  I was worried they were to something else other than the A/C and was going to look it up first but with the tip I'll just go ahead and remove it
« Reply #107 on: August 02, 2009, 02:14:32 AM »
naw its fuckin useless... my buddies car was in my garage for like the millionth time and that shit was annoying me so i just ripped it out when his back was turned lol... along with half of his PS shit still left in there... infact i have done it a couple times now, did it on a car i helped with a turbo install too...
just read/looked threw the hole post... cant wait to see this thing boosted! get it finished up yo!
Re: 350 or Bust - Love me some D: almost finished!
« Reply #108 on: September 18, 2009, 04:53:27 PM »
This just in:
Turbo doesn't spin at idle!  Can't wait to see what it does at 8k.  My camera broke so I've been taking pictures with this other camera that I don't have a cable for.  Turbo is on the car and getting oil, an 'exhaust' is on the car, charge piping and bov are on the car, only thing I have left is injectors/resistor box/tune.  The wideband sensor is there, just haven't got the controller hooked up yet.  Better update soon.
« Reply #109 on: September 28, 2009, 03:46:27 PM »
Turbo on and waiting for DP
Shot of the IC with the bumper off
Part of the cold side IC piping
BOV as close as I could get it to the TB
WIER flange, just needed tapped
The 200 amp drill bit
Post die grinder action
That is all for now, gotta get pictures of the oil line and return as well as the exhaust and hot side IC piping
« Reply #110 on: September 28, 2009, 11:13:13 PM »
Wow, how did I missed this thread ?! Awesome fabing sir!   :noel:
I should have let you buy these injectors lol
speedjunky01
« Reply #111 on: September 29, 2009, 09:08:46 PM »
well done thus far
keep up the good work, big intercoolers are a pint to fit, you are usualu left with an intercooler condom not a bumper
2nd_gen
« Reply #112 on: September 30, 2009, 03:57:57 AM »
super siiick welds!!!  :yes:
« Reply #113 on: September 30, 2009, 12:24:09 PM »
Good work! Keep it up :yes:
« Reply #114 on: September 30, 2009, 11:28:45 PM »
Got a question about these Precision 880 injectors.  Any help is most appreciated
They aren't as long as the stockers, are they cool to use?  Should I just get rid of those black plastic spacers and use flat washers until the fuel rail sits flush?  Also, I'm guessing I don't need that brown o-ring, right?
What have we here?  An excellent idea taken from a fellow rHMTer
Cutting boards make great gauge bezels.  I'm out of flat black rattle can magic so it's white until I go to the store again.  Gotta love inches of Hg egay boost gauges
Other useful thing I did today, dodge garage BOV mod.  On a scale of 1-10, it was an 3 for difficulty.  I'll let you know how it works soon enough
Resistor box was installed today as well as getting power to the wideband and running its ground to the t-stat housing.  One day I'd love to take apart the case on the PLX and some how make the lcd display fit into where the stock clock is, or should be, CX doesn't have that luxury item
« Last Edit: September 30, 2009, 11:30:37 PM by onlyflash944 »
« Reply #115 on: September 30, 2009, 11:37:17 PM »
injectors look same rail to mani length to me ???
Should be close because of that black slever or whatever it is on top of the stockers that crush when you tighten them down.  The 880 don't stick so far into the manifold.  Do they make it up with spray pattern?
« Reply #116 on: October 01, 2009, 12:58:03 PM »
I have the Delphi 75# which are the same as precision w/o the sticker and they bolted in fine. :yes:
« Reply #117 on: October 01, 2009, 07:40:29 PM »
yes its true.
dodge garage mod = compressor surge.  at least, it did for atticus.
« Reply #118 on: October 01, 2009, 11:52:27 PM »
Well I'm going to give it a shot, and if it doesn't work then I'll just hook a vac line from the turbo to the port I added.
« Reply #119 on: October 02, 2009, 12:57:30 PM »
After playing around in crome for an hour, the car idles fine with the 880.  A little rich once the car warms up but 13 afr isn't horrible.  The problems I'm having I think can be attributed to the lack of preset injector battery offsets in the latest version of Crome.  I'm having to guess and test and right now I've got it idling decent with a 60 off set in the Fuel Table.
Does anyone know where I can find a fairly accurate offset value for the Precision 880s?  Should I find an older version of Crome and use those?  I'm a noob when it comes to tuning.
Pages: 1 2 3 [4] 5 6   Go Up
