Cruise is the shit on long drives.
Thats begging for a boosted f2b!
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi276.photobucket.com%2Falbums%2Fkk32%2Fefssuck2%2FDC4%2FIMG_20131228_111209.jpg&hash=129b3b37c43a0049e593c9519d20852bd67972d0)
notice anything odd on this one? i had to do a double take.
Have you posted the turbo setup that is going on?
Damn you work fast!
You just want to feel those cams :D
I'd probably do the same tho. Wish I would've done my rings for turbo. Now Im screwed
I would throw the motor in, run it for a while then boost it.
Nicely done. Take out a shim ;)
Also how do you get them apart? You have a press?
Looking good dude. This thing gonna be ready for dyno day?thanks
Looks like it's coming along........needs turbo :D
What injector clips do you need?
Get rid of the mtf, its to think unless you have a K or J trans!
I use 10w40 motor oil in mine, but I've always thought honda mtf was the best.Get rid of the mtf, its to think unless you have a K or J trans!
I have never had an issue with it?? what do you suggest?
sounds like something is loose and rattling around in your distributor until it gets jammed in something and snapped those tangs?
IDK I'd open it up and check it out or just swap a new one on.
Ive had the same thing happen to me. Ended up being a bad bearing in the in the dizzy. But not felt fine.
Mine was the bearing in the dizzy. I didn't think I could pull it out. So I got a new dizzy from acuraoemparts.com for $112
You got the Bc's in there?
Good spring there? I've seen people have worn out springs and it not pull the belt tight and it slaps around.
I hate doing timing belts
I have nothing else to add at this time.
valves suck too, Never really bothered me doing suspension work except when I was working at an alignment place.I hate doing timing belts
my new hate is valve adjustments... i think it was suspension work before that.
How's the water pump? Only time I've seen a honda fuck a timing belt up is when the water pump seized up.
Honda valves bend so fucking easy, pistons could look mint and you could have 16 bent valves. You really need to get your hands on a leak down tester.http://www.harborfreight.com/cylinder-leak-down-tester-94190.html (http://www.harborfreight.com/cylinder-leak-down-tester-94190.html)
I would guess the timing belt skipping is more of his concern for bent valves.and last I heard the non vtak motors didn't have piston to valve clearance issues.
honda says that all honda motors are interference.Honda says a lot of false statements
but when the cams were 90 degrees out... That changes shit
Dam hope you get the problem sorted away :'(. I'm looking forward to this boosted love non-v boosted engines. Clean DC4 too an like the spoon steering wheel.
more pics of that crank pulley removal tool
I have the real deal, but wouldn't mind a backup
So what did I miss? you wake up on easter and decide to pull the head?
Why did you pull the head off, the borescope pics looked ok to me
what was your compression test numbers?
ill get some more pics later. its kinda stuck in the pulley lol.reminds me of the first time I attempted to remove the bitch pin in the shift linkage during an engine swap.
blah blah blahNissan Quest one of those shitty ones you gotta remove the engine mount to get to?
probably not? but car didnt run. so im going with she was right this time.do you know the difference?
You get this shit back together and in the car running yet?
Serpentine belt falls off and the alternator stops charging the battery, car dies and won't run shortly after.probably not? but car didnt run. so im going with she was right this time.do you know the difference?
i sell parts for a living, i know what a belt is.
no. not running. maybe tomorrow.
Word get this engine done!. Want to see it boosted already haha :P
Lol its a na honda..... they are all slow. Needs boost to be quick.
Where is Lee?
ostrich cable apparently has been taking a big shit on me. almost stranded my ass on the freeway in morning traffic today... awesome.... wonder how many other little issues have been caused by that...
hate.
hate.
I am experiencing similar issue with my ostrich, I'm about swap out the battery in mine. :noel:
Haha. Could it be the AEM unit is bad itself? Something crossed or fried inside. Didn't I read you got it from someone.i bought it off ebay. so who the fuck knows... actually no, i got it to fire off and run for a couple seconds in my buddies 00 Si.
The coil frying shit is crazy. Specially on two different cars.it only happened on the Integra.... i just have what seems like the same/similar no spark issue with both the DC4 and GVR4.
Never been a fan of Aem.......
So why did you pull the headlight again? And it will need to be replaced yes? Haha
No updates? Been to hot outside for you to work on shit?....lol got to love the unexpected NW heat.yeah dude. sucks. when I did the stuff Sunday I'm in jeans and light jacket with my kneepads on. test fitting and tack welding shit up. was kinda warm lol. I'm planning on getting up somewhat early tomorrow and welding most or all those pipes up before it gets 80°+ out.
Are you running crome free or crome pro?
Look nice. Sounds nice. Tweak tweak.
Is your intake air temp hooked up? Working? No code?
Km guessing that's what AIT is.
Congrats on getting her moving.
Now do you want to sell your stock wing for the CX. Just a question. Guy up here wants one. :)
130° ain't that bad. I've seen much worse. Heat wrap your shit up. Other than that if you let it heat soak and them start driving after a few what's your temps?
I want urrrrr wheels :(
Where's the video pull?
Private video fail.....
including full exhausts...
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi276.photobucket.com%2Falbums%2Fkk32%2Fefssuck2%2FDC4%2FIMG_20140522_181925.jpg&hash=991f48b70a465fc0b6566856debb7dc5b3438eaf)
Ok when is this ride up forsale?time to revisit this i guess.... fuck you... soon as i get it running again.
Since we know you will sell it. :noel:
NOVA!!!
i only took a quick look, but the guides didnt look cracked.... but i wont be using that head, i have a fresh one.
Nova!!! Nova!!! Nova!!! Nova!!! Nova!!! Nova!!!
Fix it, sell it............................ NOVA :evil:
what you want for the tool?
yesss, do some laping and maybe seals.
Then sell it as new
Dude, your already half way done taking the engine apart. Just pull it out and pull the pistons and inspect some shit.
