Author Topic: RHMT Motor mounts.. Not Poly or Derlin... 75% more RHTM Cost $2.46  (Read 33073 times)
Rawr's thread inspired me to tackle my own engine and tranny mounts , this is the rear tranny mount from an EG..
and yes, those are Hockey Pucks.  $1.23 Ea.
Don't need a press either.
Saws all
2 Hockey Pucks
Torch
Drill
Rivets
WD-40
Cut out the center
Cheap ass hockey puck (vulcanized hardass rubber)
Cut a bit off the bottom of the hockey puck
Take the old chunk with the steel insert.. heat the fuck out of the insert and push it put
Drill a big ass hole for the steel insert
Done
1 Hockey puck per side , I just pressed it in with the vice and some WD40, they were in there tight as hell , but for added security I drilled a few small holes in the top on each side and put rivets in them...
and thats my cheap ass GRM motor mount...
« Last Edit: April 30, 2009, 10:11:27 PM by Lowerit »
Re: RHMT Motor mounts.. Not Poly or Derlin... 75% more RHTM Cost $2.
« Reply #1 on: April 30, 2009, 10:08:13 PM »
I like that I may have to try that eventhough my window weld urethane filled are holding up pretty good so far. ;D
« Reply #2 on: April 30, 2009, 10:12:48 PM »
I'll give it a try. At least you don't need to wait for the urethane to dry out.
lilpooh21186
Re: RHMT Motor mounts.. Not Poly or Derlin... 75% more RHTM Cost $2.46
« Reply #3 on: April 30, 2009, 11:07:52 PM »
baller statis
Ecu chipping
basmaps
imburne
    • TurboByHOLSET
« Reply #5 on: April 30, 2009, 11:25:22 PM »
Keep it white brother  ;) Let us know how it feels.
« Reply #6 on: May 01, 2009, 01:53:03 AM »
mine have been on my DD for over a year and still look new.  high build urethane used for installing windshields.
« Reply #7 on: May 01, 2009, 07:04:25 PM »
I used to do this with VW's all the time, works great!
Toysrme
« Reply #8 on: May 01, 2009, 08:34:11 PM »
dogbone torque mount in my lexus is a hockey puck after the urathane window weld gave way. a year or so back.
mines doing good so far too.
« Reply #9 on: May 02, 2009, 12:53:04 PM »
A friend of mine just did this weeks ago, loves it. Best part is he got the hockey pucks for free from a friend who had ~20 left in his car when he bought it, so his entire cost was $0
caged
« Reply #10 on: May 04, 2009, 02:20:24 AM »
I just did my engine mount for my evo 2. Perfect size with no cutting required  :noel:. My pucks were 4$ each. Thanks for a great write up!
« Reply #11 on: May 04, 2009, 03:57:18 AM »
my rear mount, been on 3 cars and ~50,000+ mi so far
« Reply #12 on: May 05, 2009, 12:30:14 PM »
Piiiiimp
I need a torch
caged
« Reply #13 on: May 05, 2009, 05:54:48 PM »
Piiiiimp
I need a torch
I found it was quicker to use a flat blade screw driver and a hammer to chissil it out, then use the torch to burn whats left. I still managed to set the workshop smoke detector off lol.
« Last Edit: May 07, 2009, 01:38:26 AM by caged »
« Reply #14 on: May 06, 2009, 04:48:07 AM »
I still need a torch though. I used a drill, chisel, screw driver, hole saw......... fuck that liquid shit inside the driver side mounts....... gross shit in there
« Reply #15 on: May 06, 2009, 10:35:20 AM »
U don't need a real torch, just propane  $5 crap.
Eggylshatch
  • Pen15 Club President
« Reply #16 on: May 09, 2009, 11:30:58 PM »
I would want to use a little polyurethane in there with the hockey pucks to glue them in/together.  It would serve as your lubrication to slide the pucks in there too, and dry up solid as FUCK.
tersplat
« Reply #17 on: May 18, 2009, 02:50:27 PM »
been using them on my tercel for all 3 mounts for over a year not just like t_cel_t he's the one who gave me the idea with a wrieup he posted on tercelonline. they work great.
« Reply #18 on: May 18, 2009, 03:34:28 PM »
I had one of those explode leaving the line at mission raceway on slick's and when I poped the hood i was like WTF  :-X Shit looks nasty and went everywhere  :?:
« Reply #19 on: May 20, 2009, 09:05:48 AM »
I am going to be doing 3 more mounts this weekend. Will post up more pics. i think i am going to fill the centers with Poly as suggested.
« Reply #20 on: May 20, 2009, 09:16:10 AM »
Great idea I will be trying this after Wa. meet. ;D
